Picked up the old Vello today!
Quoted: 29 Post(s)
Liked 38 Times
Finally made it back downtown to pick up the Norwegian Vello bike.
I was told it and it’s companion folding bike had been in the back of the warehouse for well over ten years, and no one remembers where they came from.
Quoted: 3811 Post(s)
Liked 3,337 Times
The second one was produced by DBS in Sandnes, Norway on the southwest coast.
DBS stands for Den Beste Sykkel. Founded by Jonas Oeglaend. Company did mainly adult practical transportation machines and juvenile models. Also did a few sports models.
They had some high end sports bikes done for them in the eighties by Daccordi of Italy.
Liked 3,337 Times
Vello is also a DBS badge.
The Apache serie was produced 1972-80.
The one-piece chainsets on both machines appear to be Fauber.
Pedals Union (DE).
On the Apache left brake lever appears CLB and right more Weinmann-esque. One or the other must be a replacement.
Kombi serie launched 1962; do not know how long produced.
Here is a listing for a Vello sports model -
https://www.finn.no/159903176
This Wiki entry gives some history and background on DBS -
https://no.wikipedia.org/wiki/DBS
Pedals Union (DE).
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
Aha, I just KNEW that wheel was attached to something cool. 😁 That Kombi Bird sticker is awesome. 👍
Quoted: 29 Post(s)
Liked 38 Times
For those that were asking, the tires are 26x1 1/2.
The rims are alloy, the fenders are stainless steel, and the tires appear to be original with the brand VIKING marked on them. The rear knobby tire is marked “Cross” probably for “crossover” or “cross country”
I was able to force some air through the odd two-piece presta style stems, and the tires are holding at the moment.
I so far removed the bells as they were toast, and the “Lucifer” generator which is frozen. I’ll see if I can free it up.
The drum brakes and the shifter are working perfectly.
Can anyone recommend a gentle de-greaser? I want to be cautious cleaning it up so I don’t damage the finish or decals.
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
You bought it!!! Sweet bike.
I've had good luck wiping down with mineral spirits, then using a cleaner/wax like Maguires.
You may want to replace the tubes, just for ease of filling.
Quoted: 29 Post(s)
Liked 38 Times
Thank you for the responses! I’ll try the dish soap first and mineral spirits on stubborn residue.
Snall world, I have been using Meguires cleaner wax on the Schwinn bikes. Works great to remove dirt and oxidation at once on painted surfaces.
PS: on that Kombi bicycle, it may not be a single speed. The rear hub looks identical to a German two speed kickback hub.
Quoted: 1627 Post(s)
Liked 630 Times
That Vello is stupid cool. By which I mean, it's simultaneously really stupid and really cool. Rare combo.
The folder looks like a hundred million other "shopping bikes" made all over Europe and Asia over the last 50 years. But on that subject, if you want a good read, check out Tim Moore's "The Cyclist Who Went out In the Cold." Very funny epic tale of a guy who bloody-mindedly rode the length of the old Iron Curtain on just such a bike. https://road.cc/content/review/22275...-went-out-cold
Liked 3,337 Times
Great to see you are moving forward with the bikes!
The Jonas Oeglaend concern produced cycles in the Sandnes facility for about a century - 1895-1996. They had to close the manufacturing operation due to low cost imports from abroad but have kept the name going through contract built machines done in other lands.
Since you have a Kombi you might like to see this Kombi tandem we had here at the forum -
https://www.bikeforums.net/classic-v...bi-tandem.html
This DBS example bears some similarities to your items -
https://www.bikeforums.net/classic-v...on-needed.html
If you would wish to learn more of the company and their produce you might have a visit to this Norwegian cycling forum -
https://www.terrengsykkel.no/ubb/
Quoted: 29 Post(s)
Liked 38 Times
Thank you for the info!
I didn’t buy the Kombi, but I’m thinking about going back to get it because I do like it, and it’s in almost as excellent condition as the Apache.
Liked 3,337 Times
Wondering anent the Apache's dashboard.
Since it is empty - without instruments, it gives rise to conjecture as to whether or not it is "factory."
The combination of stick shift and dashboard suggest automobile attributes as seen on some American cycles of yesteryear...
Quoted: 29 Post(s)
Liked 38 Times
I wondered that myself, but a period factory photo shows the dashboard to be original and correct. I’m guessing it allowed you to bolt on accessories if desired.
Quoted: 29 Post(s)
Liked 38 Times
She cleaned up pretty well!
This bike has a generous amount of aluminum alloys and stainless steel, making cleanup a breeze compared to most old bikes I’ve tackled.
The combination of dish soap and cleaner wax took care of most of it.
Now to go after the 3-speed hub which is stuck in first gear.
I will try putting some machine oil into the oil hole to see if it will free it up. After that, I’m open to suggestions, since I’ve never worked on a 3-speed before.
Likes For Retroman69:
Quoted: 29 Post(s)
Liked 38 Times
Well, that was easy.
A little oil and elbow grease got the hub free and shifting smoothly and perfectly.
Brakes were already tight and well adjusted.
now a fully functional bike!
Liked 3,337 Times
Thanks for the updates and sharing the progress - coming along most nicely!
While the bike did not come fitted with the wheel lock or lamp bracket shown in the brochure image it does have a Schieffer-Klutt frame pump and Rampinelli (REG) pump holder set.
With the banana seat and sissy bar arrangement it is interesting to see how the user is expected to do their seat height adjustment. A choice of four heights is offered.
Partially Sane.
Quoted: 972 Post(s)
Liked 643 Times
Looking good there. 👍 I guess I misunderstood you before, I thought you bought both bikes. Not to worry, you chose the right one, in my opinion. And don't feel pressured about going back for the other one. Unless you have someone to go riding with, lol. 😁😉
Quoted: 2363 Post(s)
Liked 1,749 Times
BTW< to the OP - cool clock.
Quoted: 29 Post(s)
Liked 38 Times
Thank you guys!
If that folder is a two-speed, I’m interested in it, as I’ve always wanted one.
Thats a George Nelson clock, I’m insane for mid-century-modern stuff and my furniture and decor is almost nothing but.
Took the Vello bike out for its first ride after finally replacing the inner tubes. It rides beautifully! Tight, no squeaks or rattles. It has excellent gearing, and those drum brakes are awesome. That weirdo seat is surprisingly comfortable.
Nice little bike!
Nice little bike!
