For the love of English 3 speeds...
Bikes: 1951 Sun Wasp, 1953 Armstrong Consort, 1975 Raleigh Competition, 1980 Apollo Gran Sport, 1988 Schwinn Voyageur, Mystery MTB
Quoted: 359 Post(s)
Liked 465 Times
The interesting thing is that I bought two sets of Duro whitewall tires within a few months of each other for two different bikes. The set on the 1958 Sports had a lot of premature cracking of the sidewalls that kept worsening. The set I put on my 1970 Sprite were better. They were the same model of tire and bought fairly close together in time. With a cheaper tire, I guess you get the quality control variations too. I moved on from the Duro whitewalls to newer Schwalbe whitewalls, and the ride improved greatly on the 1958 Sports. You really do gain a lot when you move from the really cheap tires to more of a mid-level tire (I guess the Schwalbe is more mid level than economy level for these).
Bikes: 1983 Trek 600, 1972 Raleigh Sports Step Thru, 1963 Rudge Sports, 2007 Dahon MuP8, Dahon Speed, Public Mixte 8-speed IGH, mid-70s Peugeot Mixte AW conversion, Riv Platypus
Quoted: 350 Post(s)
Liked 24 Times
I see the source as Popperfoto/Getty Images but not an ad that uses it. But I can hardly follow the Daily Mail page at all, it's so jumpy. One photo shows a kid on an American Stingray or similar, not the Chopper at all.
Quoted: 515 Post(s)
Liked 167 Times
I think it's a third or better of the way down via that link. But I saw her there.
Quoted: 515 Post(s)
Liked 167 Times
Go 4 images down, see video, then go down another 8 images? The ninth should be an image of her. More like only a fifth of the way down.
The text directly below her photo says; Producton of the original Chopper bike ceased in August 1983, as BMX bikes became the fashionable choice.
Liked 8 Times
I finished my old BSA project last weekend. I started 10 yrs ago with a rusty frame which I think is about 1920s. Had that sandblasted and painted , then put an old secondhand set of Westwood’s on it with an Eadie coaster brake rear hub that barely stopped.
Over the years I’ve gathered an old Major Jones stem, old Lauterwassers, new alloy Pashley rims, some rebuilt tandem brake hums with 3 speed gears. Not sure of era of the hubs - they looks 70s to me but have date stamp 00-5.
it rides beautifully.
Quoted: 515 Post(s)
Liked 167 Times
Liked 8 Times
not a patch on discs or modern alloy-rimmed calipers.
but a zillion times better than a cracked Eadie coaster brake !
Likes For AL NZ:
Quoted: 1299 Post(s)
Liked 103 Times
Great job on this. What a perfect way to put such an old roadster frame back in use. Excellent choice of components.
Inflate Hard
Inflate Hard
Quoted: 350 Post(s)
Liked 24 Times
Quoted: 350 Post(s)
Liked 24 Times
Here's the link; https://www.dailymail.co.uk/news/art...otorsport.html
Quoted: 350 Post(s)
Liked 24 Times
Quoted: 515 Post(s)
Liked 167 Times
That Daily Mail page is hard chewing for my PC. The best I can pull up is the photo, but there's no copy to indicate where it might have run or the theme of the ad. Raleigh wouldn't run the photo as a space advertisement with no text. I wonder if the girl is someone who was recognizable at the time, and maybe copies of the photo were intended to be signed by her and handed out at Raleigh PR events.
I agree, the girl looks like somebody we should know, or at least would have liked to.
Quoted: 350 Post(s)
Liked 24 Times
Hey Neal! Long time, no see. Curious about your Jeunet conversion! Coincidentally, I converted an old Jeunet 630 to 3-spd IGH awhile back, but never tried to convert it to 650B. It's limited by its clearances for anything larger than 700x28. The front fork (original) has so little vertical clearance that I had to file the daruma nut so that the tire didn't rub, but it has plenty of width. The rear triangle has gobs of vertical room and requires a long-reach brake, but the chain stays are far too narrow. Can't win! Too bad, because I find the Reynolds frame to be supremely flexy and fast. It would probably work best configured as the skinny tire road bike it was intended to be.
Quoted: 359 Post(s)
Liked 465 Times
1972 Raleigh Sports Step-Through
Here is the bike I found for about $50. It is a '72 Sports by hub date, with the older style chain ring and proper brake levers. The hand grips are so small. Of course, it sat in the seller's shed for years. A quick eye will notice the fork - I think it is off a French bike of some kind since the 'crown' matches the fork on my AO8. In any case I have a matching Raleigh fork in sky blue for it. The hub is free, as is the seat post. I was happy to find that the oil port cover is still in place on the AW. The shifter is missing its by-1972 plastic cover. I might replace the shifter if I can find an older one in the parts bin at my local co-op. All components are in place and in dire need a clean and rebuild. My girlfriend doesn't ride fast, and likes a comfortable pace. I was thinking of a 20T or 21T sprocket to replace the 18T one on the bike. Is 22T too far? Some misguided person tried to paint the downtube, but I'm thinking I could polish it off somehow. How do you fellows remove unwanted paint?
Speaking of paint, I think this bike could be a candidate for my first paint job. There is a lot of surface rust on the fenders. I remember that Chief got the rust off somehow and clearcoated the fenders. I could try that if I'm not feeling ambitious. What does it look like to paint a frame, and do it reasonably well? I would remove the metal plate off of the steerer tube and of course recreate the white tailed fender. Thoughts? At any rate this bike will get a tear down, polish, and rebuild. I'm tempted to add CR18 wheels to the list, but can they still be found in 40H? This will be an all-rounder for my girlfriend come spring. I figured lighter wheels would help. I'm thinking whitewall Schwalbe Delta Cruiser tires instead of the Panaracers on my Raleigh. Fourth photo is a 1962 dated SA dynohub that I found for my IGH Peugeot commuter wheel build.
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 443 Times
Liked 443 Times
Quoted: 515 Post(s)
Liked 167 Times
Liked 103 Times
Inflate Hard
Inflate Hard
Liked 443 Times
It was pretty easy...
I dropped the photo into Google image search and
she came up on page 2.....
Ula dance now?
<iframe width="560" height="315" src="https://www.youtube.com/embed/yeBfVrJ2UiY" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Ula dance now?
Quoted: 350 Post(s)
Liked 24 Times
Ula dance now?
Ula dance now?
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
Liked 103 Times
Ula dance now?
Ula dance now?
Inflate Hard
Inflate Hard
Liked 443 Times
A Raleigh Trent Tourist
For sale here in Toronto at $1000.00........
You would think that someone trying to sell a bike like this would do a
little market research before listing.
Liked 443 Times
Bikes: 1975 Raleigh Superbe, Abeni Triatlon, 1992 GT Timberline custom "neo-klunker", 1988 Miyata Valley Runner Townie
Quoted: 21 Post(s)
Liked 34 Times
Picked up a couple of NOS SA hubs from an LBS that's closing down. Hidden among the boxes of Shimano 333's and Tourney running gear.
A 1978 AW 28 hole and a 1996 Sprinter 36 hole with all the accessories bar the cable. I hadn't heard of the Sprinter 5-speed before, opinions online seem to be 50/50 good/bad about it. I think I'll lace it up for my Miyata Valley Runner, which I was planning on doing up with an AW, and see how it goes.
