The Great Deal / Sale Thread
#3101
well for $4 and some patience you can get https://www.ebay.com/itm/110942514763...84.m1497.l2649 probably made in the same factory.
#3102
#3103
Fixie Infamous
Bikes: 2007 CAAD Optimo Track, 2012 Cannondale CAAD10, 1996 GT Force restomod, 2015 Cannondale CAADX
Quoted: 54 Post(s)
Dude.... just go to walmart, and drop 15 bucks on some lights...
#3104
This.
I got some cheap Schwinn "froggy" style lights from walmart. They come in white & red and wrap around handlebars/forks/seat stays - and I'm pleasantly surprised how well they've worked.
Bright as ****, and mine have lasted over a year with getting rained on and dinged up. I've given out a few to friends and family that ride and they've worked great.
They have 3 modes too (solid, blinking, and then a strobe type)
#3105
This.
#3106
The taillight is going to suck. It will be bright enough, but only when you are aimed perfectly along one angle looking into it. Which is useless. That will not matter though because after you change the batteries once the lens will not stay snapped to the body. The mounting and removing feature will be ass.
The headlight should work for about a day or two. Then the threads that hold the pieces together will stop working, either because the body cracks or because they suck to begin with. The mount will be useless. The removable carrier that holds the batteries will crack.
You should take $4, put it in an envelope, write CHINA on it, and drop it in the mailbox. Start mourning the loss now.
#3108
Quoted: 14 Post(s)
Handlebar shims for $2.80 https://www.amazon.com/gp/product/B00...A32VWUEWIQ35R3 Shipping is $5 but this brand of shim is carried at several other stores and can easily be price matched.
#3109
Quoted: 1332 Post(s)
Liked 398 Times
$65 Zoncolan. I know I'm thinkin' about it...
#3112
THE STUFFED
Bikes: R. Sachs Road; EAI Bareknuckle; S-Works Enduro
Quoted: 361 Post(s)
Liked 20 Times
Which color would you get out of the two there? I'm leaning toward the lampre colors.
#3114
Bikes: Civilian Le Roi Le Veut, Kazane Track, Ciocc Designer '84, Serotta Colorado AL 25th anniversary, '85 Guerciotti Pista, '84 Trek 660, Volume Credence
Thats been happening for awhile I believe. I always use that code to get the discount even if it doesnt pop up at the bottom. Works every time.
#3116
Still kicking.
Appreciate the old bikes more than the new.
#3117
good way to test one out. see if i like it.
#3123
Fixie Infamous
Quoted: 54 Post(s)
That's cheap as hell. I'm about due for a new chain on the Kilo too. I might be able to settle on gold.
#3124
Your cog is slipping.
