Thinking of getting Specialized E5 frameset (from the Allez Comp)
Bikes: Marin Verona road bike, Cannondale F300
I've made various upgrades to my heavy '99 steel bike, e.g. new wheels, but I think the time has come to upgrade the frame. At first I toyed with the idea of getting an eBay carbon frame but I worry, not about their quality or durability, but whether the frame would fit well. It's frustrating that a lot of the eBay frames I'm interested in do not list the exact dimensions. Also, I like the idea of a quality frame (seems many here think the E5 frame is up there with the CAAD10, if not quite, but a lot cheaper) from a reputable company.
Finally, and I'm sure some would disagree with my tastes, I like the look of the Specialized frames with their bowed top tube and tall head tube.
With all that said, are there any other compact frameset I should consider in that price range?
Thanks.
Thanks.
nope. its the best frame out there. and you can buy it as just a frame. there are few within that price range but the spooky skeletor might be a contender.
Quoted: 42 Post(s)
I have an S-Works E5, the predecessor to the Allez E5. One of the best bikes I've ridden. It's up there with a CAAD 9 and I suspect CAAD 10 (haven't ridden the latter yet).
I currently ride a 2010 Allez Elite Comp. I love the bike so far but recently had the opportunity to rent a Tarmac while on vacation. The Tarmac was the same frame size, group set (105) and wheels but had a much better ride and seemed to take less effort in the climbs. I think the only real difference was saddle and stem. Frame geometry seems fairly comparable as well.
So - would the E5 be a straight forward way to upgrade by just moving everything from my Allez over? And if so - WHICH E5? There seem to be quite a range of different E5 designs on eBay. There are also some Tarmac frames on eBay right now...same thing?
https://shop.ebay.com/?_from=R40&_trk...All-Categories
Thanks in advance.
Thanks in advance.
There's just one E5 frame currently offered, or do you mean which year?
BTW, anyone know how much the E5 weighs?
Also found this white paper. - S-Works Tarmac E5 1358g / Carbon AL Monocoque
S-Works Tarmac Carbon 1165g / carbon
https://www.specialized.com/OA_MEDIA/pdf/Witchcraft.pdf
Don't know how I missed your post. Thanks for the info. The weight for the S-Works Tarmac E5 jives with what I found for the current E5 -- around 1360g for the 52cm size.
Alas, when I placed an order at the local Specialized dealer, I was told their system showed no availability till late May.
I'm now looking at a cheap carbon frame.
I found this link digging around the Specialized website - lists both an S-Works E5 and Tarmac E5 for 2006: https://www.specialized.com/us/en/bc/...1&menuItemId=0
