eZip-iZip-Currie parts-n-such
Old 02-03-16, 03:38 AM
DrkAngel
DrkAngel's Avatar
Bikes: Various "modded" eZips and multiple econversions
Cool eZip-iZip-Currie parts-n-such
I thought it would be handy to consolidate my eZip parts finds in one place.
40 Amp fuses for the RMB battery packs - 5 for $1 & shipping
Big shipping discount on multiple purchases!
Just click on pictures to go to Link.
36V controller with proper connectors - plug-n-play
Will lose PAS function - $37.50
ACS Southpaw LHS 1/2 x 1/8 x 16T Freewheel - $13.93
Easy 25% speed upgrade for eZips and many iZips! and others?
DNP Epoch 7spd 28-30-32 to 11T Freewheel - $34
Upgrades EZip w/44T Front Sprocket to near 30mph pedal assist (90 crank rpm) 20mph (60 crank rpm)
More sizes - 11- 28,30,32,34T - $32
72 CUSTOM LENGTH STAINLESS 13G SPOKES - $26 + $5 shipping
18-260mm & 18-258mm Spokes required for eZip rear wheel, 36-260mm for front.
150 13g Nipples
NEW!
8,9,11,13T Motor Sprocket Upgrade, (Currie, eZip, iZip) - $18 includes shipping
Plug-n-Play - except you will need longer chain
Good fit, good alignment, just lengthen chain and all set to go!
OEM eZip top speed @24V w/9T sprocket = 15mph.
15mph / 9T x 13T = 21.66mph (20mph USA "legal" - reasonable expectation)
eZip Rear Brake Pads - $5.95
Most notably, the older eZips require a "deep" brake pad for the rear wheel ... this work nicely!
Back Brake Pads
My1018z 24V 450w motor - $99
7s - Tenergy Intelligent 2A Charger for 25.9V 7S Li-ion / Li-Polymer Battery Pack - $23.99
Bulk charger with "safety charging algorithms"
Great budget item but 4.2V per bank - not a balancing charger!
Gotta rip one open and try to trim voltage ... will report.
Update! - Simple voltage trimming method!
Other Tenergy chargers should have similar circuits.
10s - Tenergy Smart Charger for 37V 10-Cell 2A Li-ion/LIPO Battery Pack w/ Tamiya - $18.49
Special price w/Tamiya! Add your own connector.
eZip Trailz parts - In Stock! .... mostly ...
Much more here - non-eZip specific parts - eBike Toolbox bargains
DrkAngel is offline
Old 02-03-16, 03:40 AM
DrkAngel
DrkAngel's Avatar
Motor Freewheel Adapter
Freewheel adapters for the Currie gear reduction motors are now available!
13, 14 an 15T freewheel compatible!
11mm ID w/4mm keyway ... Less than $17 ! - New Link
Also,
Now available,
Adapters for 16T and larger freewheels! ... Less than $17 !
Staton-inc
Ordering up both and will report ... likely ... within a week!
DrkAngel is offline
Old 02-03-16, 03:42 AM
DrkAngel
DrkAngel's Avatar
Cool
JST-XH 2S-8S Battery Balance Board Adapter - for iMax B8+ and others
- $1.79 +$1.99 shipping .99 per additional
4 x 7s Balance cable
- $6.59 w/$1.74 shipping
2 x 8s Balance cable
- $4.99 w/ $1.74 shipping
10pcs JST-XH 8S 30cm Lipo Balance Wire Extension Charged Cable Lead Cord for RC
- $11.88
Tenergy Intelligent 2A Charger for 25.9V 7S Li-ion / Li-Polymer Battery Pack -- Anderson Connector - $14.95
Unbelievable price!
Great for 25.9V Li-ion, as 24V SLA replacement.
10pcs Balance Wire Extension 30cm - 3s, 4s, 5s, 6s, 7s, 8s, 10s, 12s!... $4-$14 w/free ship
They appear to be silicone?
NEW sizes!
8T/9T/11T/13T Motor Sprocket Upgrade, (Currie, eZip, iZip) - $18 includes shipping
DrkAngel is offline
Old 02-03-16, 03:43 AM
DrkAngel
DrkAngel's Avatar
Cool OEM Parts - Sources
OEM parts at reasonable shipping rates.
Most important!
Most items are "in stock"!
eZip Electric Bike Parts
IZIP Electric Bike Parts
Currie Parts
DrkAngel is offline
Old 02-03-16, 03:44 AM
DrkAngel
DrkAngel's Avatar
Cool Larger LHS Freewheels
Staton-inc.com has the 22T, but that is only a 10% reduction.
- $14.38
You might want to wait ...
I just took a ride in the cold and suffered a 2-3mph speed handicap.
Not sure if will fit ... might be too large of a diameter ...
But possible to put together a 27T.
$17.95 + $15.95 = $33.90
DrkAngel is offline
Old 02-03-16, 03:46 AM
DrkAngel
DrkAngel's Avatar
Cool
On\off\on Battery Switch 30A 250V
Came as momentary, Disassemble and remove 2 springs for eZip use
Keep level - to prevent contact movement. Must be repositioned if upset from original position.
Dull knife or small screwdriver, pry alternately on each side of switch (next to rocker pin) to lift button.
lift out the 2 springs.
Push button back in till snaps in place
(Momentary position could be used in a precharge resistor application )
- 2-pcs $4.40 replaced "stiff" switch
UPDATE = Labeled "20A"!
Better price - same item? - 2 for $1.33
Limited Availability 5x 30A - $5 picture shows "30A"
YIYUN YK31C 24-36V compatible controller 28A
Requires connectors adapted!
- ±$12 I run 25.9V (20mph) & 33.3V (25mph Turbo).
eZIP Electric Bike 36 Hole 3/8'' Axle Double Threaded Rear Hub
Appears threaded "properly" - other replacements had poor thread job!
- $29.99 delivered Not purchased yet
DrkAngel is offline
DrkAngel
DrkAngel's Avatar
13 Tooth 11mm Bore Sprocket for 1/2"x1/8" Bicycle Chain
Direct replacement for oem 9T (requires 2T longer chain)
+20mph@24V w/XYD-16 motor,
++20mph@24V w/M1018z motor
+++20mph@25.9V - Larger chainring or Epoch 11T rear cog recommended ... if you want to pedal assist ...
Now <$10 delivered!
DrkAngel is offline
Old 02-03-16, 03:47 AM
DrkAngel
DrkAngel's Avatar
Cool Brushes
Shopping, from Australia, is excessive but same for multiple of item.
MY1016 Brush Assembly might fit MY1018Z and XYD-16 but compare pictures to yours
MY1018z
DrkAngel is offline
Old 02-03-16, 03:49 AM
DrkAngel
DrkAngel's Avatar
Cool Motor Sprockets
Bargain prices on 9T and 13T motor sprockets for MY1016z motor.
Confirmed compatible with MY1018Z and XYD-16 motors
< $6 delivered
< $7 delivered
DrkAngel is offline
Old 02-03-16, 03:55 AM
DrkAngel
DrkAngel's Avatar
Cool 24V-36V+ Controller
Just installed a Yi-Yun YK31c 24V 500w controller on another eZip.
Decided to test voltage limits:
Worked right past 50.4V. (44.4V fully charged).
Stopped testing at 50.7V ... 50V caps!
Might replace with 63V caps ... picked them up last Winter.
Very versatile controller!
And cheap enough to keep a couple spares handy.
No PAS function
Adds:
key lock option;
full voltage brake light output;
charging port (possibly disables accidental use while charger connected??)
DrkAngel is offline
Old 02-03-16, 03:57 AM
DrkAngel
DrkAngel's Avatar
Cool Wheel Freewheels - Direct Replacements!
16T - 18T - 20T ACS Crossfire LHS (Left Hand Screw) freewheels - $17.59
Direct replacement for the crappy eZip - iZip motor side freewheels, without the external removal tangs that required alignment modifications!
DrkAngel is offline
Old 02-03-16, 04:00 AM
DrkAngel
DrkAngel's Avatar
9T - 11T - 13T sprockets available , for the MY1018z, MY1016Z3, XYD-16
Sprockets $14.95
Same page for the 4mm key - $ .95
Shipped from USA
Shipping $ unknown
DrkAngel is offline
Old 02-09-16, 05:41 PM
DrkAngel
DrkAngel's Avatar
Most important!
Currie Parts
More
Currie Parts
DrkAngel is offline
Old 05-15-16, 11:51 AM
jocharas
The link for the sprockets is not working. I am looking for an 8T 11mm bore sprocket that will work with the Currie my1080z motors. If anyone has any ideas of where to gt one it would be much appreciated. Also, thanks you Drkangel for all you great posts over the years - very helpful.
jocharas is offline
Old 06-21-18, 11:58 AM
madmulcher
i have a 2013 izip zuma that unfortunately has spokes breaking on rear wheel. i've been told they have 2.3mm which i presume is 13g or 14g spokes. i've been refused repair by local mechanics who either don't have the spokes or say it needs more work than the spoke repair. thus i'm resolved to repair on my own. would you know what length spokes i need or how i can determine and or have handy spoke repair youtube link or the like?
madmulcher is offline
Old 05-02-19, 10:51 AM
GeneEZip
Batteries for Sale for EZip
Are the batteries for the Ezip that you have put todether for sale?
GeneEZip is offline
Old 05-02-19, 08:11 PM
GeneEZip
Sorry, I'm not a spammer. I just bought the Ezip and was reading up on conversion when I found your postings.
No attempt here to spam on my part. Just thought you might build batteries for others.
Thanks,
No reply neccessary.
GeneEZip is offline
Old 09-13-19, 04:57 PM
stewartg672
I am interested in the 13t izip motor gear.What is the price including shipping?
stewartg672 is offline
Nebell
Electric Bikes
9
05-05-19 06:46 PM
DrkAngel
Electric Bikes
21
05-25-17 07:43 AM
DrkAngel
Electric Bikes
3
07-27-14 05:28 AM
DiabloScott
21
12-19-13 09:27 PM
