Good Chain Lube??? Mines WD40. :P
#126
Quoted: 3351 Post(s)
Liked 5,400 Times
I have used many bike chain lubes, tri-flow, 3in1. I have many quarts of synthetic hypoid 80-90 weight gear oil. Using an old tri-flow bottle, one little drop per link on a clean and dry chain. Clean with Park tool chain cleaner and repeat. Nothing like the smell of synthetic hypoid gear oil in the morning!!
#127
Mad bike riding scientist
Quoted: 6133 Post(s)
Liked 4,067 Times
Concerning the WD40 debate here, there seems to be some confusion about the term "lubricant". Obviously, the stuff can lubricate things, but that doesn't mean it's a legitimate lubricant, in the context used here.
The stuff lubricates, but only in the short term, but it is not an acceptable lubricant for mechanical devices.
Water is also a "lubricant", that's why vehicles stop less efficiently on wet roads, but that doesn't mean water is something you would classify as a "lubricant", and therefore use on mechanical devices, which is basically the 'logic' that keeps popping up here.
Further, similar heavy petroleum distillate is used in both WD40 and Triflow. I don’t know of anyone who would say that Triflow isn’t a “lubricant”. WD40, in an aerosol form, suffers from overspray but it’s as an adequate lubricant.
Stuart Black
Stuart Black
Likes For cyccommute:
#128
Professional amateur
Bikes: Does a Big Wheel count ?
Quoted: 295 Post(s)
Liked 133 Times
Blah,blah,blah. WD40 sucks as a lubricant, for most everything beyond a squeaky door hinge ( and that's largely due to it's penetrative qualities, and it still doesn't last), that's why any and everybody that know anything about bikes, firearms, motorcycles, etc. almost universally recommend it not be used as a lubricant for those things. As I said, WD40, and virtually any other liquid, is in certain circumstance, technically a "lubricant", but for realistic, long-term applications, it generally ain't.
Likes For Brocephus:
#129
Bikes: SuperSix Evo | Revolt
Quoted: 732 Post(s)
Liked 814 Times
I have used many brands over my 50 years of cycling. Currently I find DuPont Telfon Chain-Saver to meet my needs. I purchased from Amazon here: https://www.amazon.com/gp/product/B0...ustomerReviews
#130
Liked 4,067 Times
So you got nothin’ but uninformed opinion.
Science says you are wrong. There’s lots of people out there that think they know a lot but really don’t. Frankly for a bicycle chain...let’s keep this on topic...there’s not much of anything that you can use that is vastly superior to anything else. That is borne out by the fact that chain wear is about the same independent of what you use for lubrication. Nor does anything work longer than anything else. They all have their limitations.
Stuart Black
Stuart Black
#131
Quoted: 295 Post(s)
Liked 133 Times
So, if WD40 is such a terrific all-purpose lubricant.....then why did they release this wide range if new purpose-specific lubricants? Seems like it would've been cheaper and easier to just advertise the amazing, universal capabilities of their well-known base product, if it really was all that.
But, in their wisdom, they realized that the planet is now widely aware of WD40's shortcomings, in a great many applications, so they decided to meet the demand with a variety of new and improved products, rather than buck the empirically-based consensus that WD40 is of limited value as a true lubricant.
#132
Fredly Fredster
#133
Quoted: 295 Post(s)
Liked 133 Times
Cool, but I'm not quite sure what your point it. This new bike-specific version is widely known of, and has already been mentioned in this thread, and I vaguely alluded to it in my post. But the stuff you bought, obviously isn't plain, "original recipe" WD40, which is what's currently being debated.
I would assume this new product, being designed and marketed specifically as a bike lube, would be at least decent, and it's very existence is what I cited as evidence and acknowledgment that the original formula isn't very good for this application.
#134
Fredly Fredster
#135
Likes For clengman:
#136
I can only offer practical experience and not theory, heresay, bias or naysayers opinion. And WD40 works as a chain lubricant and as a bonus it cleans your chain.
The reason wd40 as a brand also has a bicycle chain specific cleaner is to make more money. The same reason lysol has 15 different bowl cleaners.
My other "practical experience" is with eco sheep lube, motor oil and white lithium aerosol. The sheep stuff is so very, very messy and it gets every where even the tires. However it does work. The motor oil is not near as messy and it works too , but you can't tell if the chain is dirty or not. Finally white lithium spray. I'm not sure how effective or long lasting it was because it gummed up and attracted dirt like you wouldn't believe. (I ummhum....used wd40 to clean it off). Personally I think dirt harms the chain more than not keeping it smothered in oil but what do I know. I only have a degree from the school of hard knocks.
If you decide to use the WD40 method, here's some experienced advice.
1. Spray only from the top of the chain.
2. Use a rag as a back stop when spraying.
3. Use same rag to wipe excess from chain.
4. Reapply every time you wash your bike or every 250-300 Miles which ever comes first.
5. Enjoy having a clean, lubed chain.
WARNING, WARNING: THE PRECEDING ADVICE WILL NOT WORK IF YOU HAVE REMOVED MANUFACTERES ORIGINAL LUBE!!!
#137
Quoted: 295 Post(s)
Liked 133 Times
I guess they put a ball bearing inside, and tell users to shake vigorously before use, just so no one will suspect that it's literally the same stuff that they've been selling for decades. Yeah, nice catch.
#138
Quoted: 295 Post(s)
Liked 133 Times
How & Why You Should Use Garage Door Lubricant
Choosing the Right Lubricant
There’s always some question as to what types of garage door lubricants are okay and what shouldn’t be used at all. Whatever you do, don’t spray WD-40 on your garage door parts. People commonly confuse this product, which has rust-destroying and degreasing properties with a lubricant because it generally helps metal parts move better. That action is from the cleaning, not from true lubrication.Instead of WD-40, choose a silicone spray or white lithium grease to lubricate those moving parts. Aerosols are especially well-suited for injection into small moving parts, and these materials won’t attract dust or gum up like mechanic’s grease or engine oil. With the right lubricants, you may find your garage door singing a different tune next time you open the door after a long day at work.
#139
I have used it, works great. there was an extensive test done by a laboratory using dyno with a bicycle drive train set up. Testing perhaps a hundred different types of (costly) chain lube, and paraffin wax came out with the lowest friction, least wear. And it was cheap.
I made a mix of paraffin wax and powered graphite (sold as lock lubricant), smeared it on the chain (after I cleaned it) and used a heat gun to get it to melt into the chain. I did not even have to remove the chain from the bike, I did it right on the bicycle.
I clean the chain with a Pedro's chain pig, using simple green, or other de-greaser. than use carb cleaner and compressed air. by doing it all on the bike, I will actually do it more often since it is not as much effort. Than I rub or smear on the wax and graphite mixture and heat it with a heat gun so it melts into the moving parts. it only costs about $3 for the wax, and $1 for the graphite lube, which give me enough to last for years.
It has never shifted better, does not attract dust and grit, cheap, and according to the tests, should allow my chain to last the longest.
In my damp climate, particularly on my mountain/trail bike, it is important to use a dry lube unless you want de-grease and re-lube your chain after each ride. I have had chains wear out very fast even using the costly specialty chain lube from my LBS. I will never use specialty chain lube again, no reason to.
Paraffin wax mixed with graphite has got to the best chain lube ever discovered.
#140
Liked 4,067 Times
Stuart Black
Stuart Black
#141
Liked 4,067 Times
If you look at the SDS for a number of garage door lubricants like I just did, you’ll find about the same list of ingredients as WD40. In many cases, they have the same CAS number. That says to this chemist that there is little to no difference.
Stuart Black
Stuart Black
#143
Quoted: 350 Post(s)
Liked 203 Times
It’s traditional to provide a link...or at least quotes...when you post something that you took from elsewhere. There might be valid reasons to avoid WD40 or the text may be from someone who is trying to sell a product.
You will be amaze how companies sell the same product but with different colors and/or scent. Just look at the SDS for comparison.
#144
No, he wouldn't be amazed. He is a long-time qualified and respected expert in chemistry, which amateurs, who have done some lazy on-line research, think they can outrank. This thread in the past couple of days of posting has been entertaining at least. There have been product discussed that I won't use on my bikes, but not necessarily WD40.
#145
Quoted: 350 Post(s)
Liked 203 Times
#147
Quoted: 941 Post(s)
Liked 319 Times
#148
Bikes: 1984 Fuji Club, Suntour ARX; 2013 Lynskey Peloton, mostly 105 with Ultegra rear derailleur, Enve 2.0 fork; 2020 Masi Giramondo 700c, full Deore with TRP dual piston mech disk brakes
Quoted: 324 Post(s)
Liked 81 Times
Regardless, WD40 is a lubricant.
#150
it is sold as a dry lubricant for locks, it is simply a fine silvery powder sold in a tube. A small tube costs about $1 USD, larger tubes are a better deal (see the link below).
I saw some tests as a lubricant on bicycle chains and it was favorable except it does not repel moisture or prevent rust (we have a wet climate). So I heated the paraffin wax in a metal can, and mixed in some of the graphite.
https://www.amazon.com/Graphite-Lubr...9Q7SQ05FHV375P
