Strong Wheels
Bikes: Modified 26 inch frame Schwinn Varsity with 700c wheels and 10 speed cassette hub. Ryan Vanguard recumbent. 67cm 27"x1 1/4" Schwinn Sports Tourer from the 1980's. 1980's 68cm Nishiki Sebring with 700c aero wheels, 30 speeds, flat bar bicycle.
Quoted: 131 Post(s)
Liked 141 Times
Low spoke count wheels.
I'm 6ft 5in, 265lbs. At the higher weights we Clydesdales ride at, rim strength, overall spoke strength, and hub strength do matter. I 've pulled spokes through a disc brake specific rim, ie very lightly constructed with no rim brake area. I've broken so many spokes over the years. I've never had even a cheap hub ever give me trouble. I've had good luck with all Sun CR18 rims from 36 hole 27 x 1 1/4 in, 36 hole 700c, to a 36 hole 20 in, on a recumbent front, and never had a spoke pull through or fail in any other way. I have worn out a rear CR 18 from brake use on a recumbent. I'm a great believer in the 36 hole Velocity Chukker rim for 700c. That rim is virtually indestructible. I like to use 13/14 gauge spokes and have had no failures with them at 36 holes. I've also used straight 14 gauge spokes with little trouble. The spokes always break at the bend on the hub if I get a broken one. I have owned a low spoke count set of 26 in MTB wheels and noticed the rims were deep dish aluminum with lots of material and the spokes were 12 gauge or bigger. That wheelset was robust and never gave me any issues. It was also faster than my older box construction 36 hole rims. Bicycles are tested very thoroughly for strength and failure points. All bicycles have an upper weight limit as do the wheels, seatpost, handlebars ect. Tom Ritchey has a very good video out where he discusses how strong he had to make carbon forks before they would pass the European bicycle strength tests. Materials do matter and I would like to see some honest data being collected about our experiences with various bicycling products that we all use. Making a good reliable set of wheels is crucial to the safety and pleasure of our cycling experience.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Nor have I. I’ve never broken a hub at the flange. Most people haven’t. It’s really not much of an issue. I look at bearing quality more than I look at strength when it comes to hubs.
A point about spoke pull through and rim cracking. It can happen due to two different mechanisms. If the spokes are too tight...i.e. pull too hard on the rim...a rim can crack and the spoke can pull through. However, if the spoke is too loose, the same can happen. Loose spokes cause more flex at the rim and stresses the rim which eventually cracks.
Stuart Black
Stuart Black
Quoted: 131 Post(s)
Liked 141 Times
bicycle wheel strength
6 ft 5in at 265 lbs. A little more information in this already overloaded discussion. I had a rear wheel with a very lightweight Velocity Blunt 29'er rime that allowed the spokes to pull through. This rim is built very lightly with no rim brake lands. I build my own wheels and as anyone knows that build wheels spoke tension is on the preventative maintenance list after a wheel is built. They tend to work loose and usually just one will get very loose and cause spokes to break on either side of it. So we check spoke tension regularly, especially right after the build. This rim always had loose spokes, not just one but generally. I would tighten them and they would all loosen up again. Never had a wheel do that before. The front wheel with the same rim was not having issues. After really looking it over one day I noticed the entire wheel was failing at all the spoke holes and they were gradually being pulled to the hub. There was cracking starting to happen and deformation around the holes. I believe the Blunt 29er is just built too light for our weights. I never actually broke a spoke and they were all straight 14 gauge. The deep dish MTB wheels I spoke of in my previous reply were Veulta brand and did have a very thick spoke. The spoke was 2.6mm or bigger. That is why the wheel handled my weight for years with no complaint. 24 14guage spokes would never have handled my weight with so few spokes. Check your low spoke count wheels and see if they are using very big spokes. Sometimes the spokes are flattened for wind resistance reduction so check around the nipple end for diameter. If they are 14 gauge then that is too few spokes for our weight catagory. If they are 12 or 13 guage or bigger then they can handle our weights with an appropriate rim.. Deep dish rims are very good at rolling faster than box shaped rims. I believe it is because of the engineered deep semi I beam shape that makes the rim much stronger in a load applied direction. The end result is they flex less under load, than a box shaped rim and thus roll better.
Quoted: 131 Post(s)
Liked 141 Times
Clarification. The Velocity Blunt 29er was a 36 hole build.
Quoted: 131 Post(s)
Liked 141 Times
More wheel thoughts and ramblings.
Clarification. Deep dish rims are a form of box beam. The strength comes from the end plates and the webs. In this case the spoke lands act as one end plate. The rims floor acts as the other end plate. The curved sides of the dish act as the webs. As the webs get taller the rim gets stronger if all other aspects are engineered to the new strength levels. These deep dish rims resist load deformation in a vertical direction much better than a smaller webbed box beam rim. Using my much less than scientific bell speedometer I noticed a 2mph gain in average speed on my rides with new deep dish wheels. I was quite surprised and thrilled with this performance upgrade. I've since noticed this performance gain on other bicycles that had small box rims replaced by much deeper dish rims. For our weight category I suggest looking at the heavier built deep dish rims for performance and safe longevity.
I'm now paranoid of the wheels that came on my new-to-me bike: 16 spoke front, 24 spoke rear. I'm more concerned about the front, if only because I may get stranded if a front spoke pops. I could probably make it home if a rear spoke broke while out on a ride. (For reference, I'm 244ish lbs at the moment, though slowly but surely dropping weight.)
I'd like to upgrade the front wheel at least to a 20-24 spoke rim. I've been browsing Wheelbuilder.com and am considering a front wheel using the DT Swiss R 460 rim and a White Industries T11 front hub.
Is there anything else I should consider? I may eventually upgrade the rear wheel, but for the present I'm more concerned with being able to get home if a spoke pops, not necessarily performance.
As this is premium stuff,
you can sell them and get an equally premium wheel set with 32 spoke front and 36 spoke rear..
(or 28/32)
the 2 relevant companies make those parts too..
Dealer offer a trade in for your brand new wheels in trade for something more pragmatic?
My 24 spoke wheels are 349 16" (rear a 36 hole hub, skipping holes.. )
230 # , 71 years old..
Liked 4,218 Times
First, your posts would be easier to read if you would break them up. Use a paragraph or two. As it stands now, your posts are just one giant run-on sentence.
I don't know why you are saying that this is an "overloaded" discussion. If people don't want to read it, they don't have to. If people want to be informed, read away.
I'm not following what you mean by "with no rim brake lands".
This is exactly what I was talking about above. Loose spokes are just as detrimental to rims as spokes that are too tight. You rim didn't break because it was "too light". It broke because you didn't build properly. Spokes that loosen often says to me that you weren't using a thread preparation. Spokes can also break at the head because the tension/detension cycle allows the head of the spoke to move about too much. I've experienced loose spokes and I could hear a "tink" each time the spoke lifted off the ground. It was much more noticeable a low speed, of course.
And, again, that is why your rim pulled through. It wasn't because of high spoke tension but because of low spoke tension. I've had some rims that have cracked down the middle on the secondary wall between spoke holes. The inability to properly tighten the spoke manifests the same way and will eventually lead to cracking at the spoke hole.
Again, I question the 2.6mm cross section of the spoke. Those are very rarely used in any wheel. The thickest spoke on a "production" wheel I've ever seen were on a Libertas tandem and those were 13 (2.3mm) straight gauge spokes.
Deep cross section rims roll (slightly) faster because of the aerodynamic shape. They aren't going to roll faster...at least perceptively faster...because they are stiffer in the vertical direction.
Stuart Black
Stuart Black
Quoted: 131 Post(s)
Liked 141 Times
Vuelta Team SL37 Hand Built Alloy Straight Pull Clincher Road Wheelset. The Vuelta website lists the spoke diameter at 4mm. These type of wheels with larger spoke diameters are on a lot of bicycle wheels and allow heavier riders the benefits of safe aerodynamic deep dish wheelsets.
Bikes: ParleeZ5/Parlee Chebacco/Trek Farley/Cannondale Slice/Burley Tandem
Quoted: 19 Post(s)
Liked 10 Times
My weight has fluctuated from 310 to 195 and everywhere in between and I have rode cheap Shimano wheels to top of the line Mavic wheels. I have broke three spokes on the rear on a set of Shimano R500's when I was over 300lbs. That's it, I own a set of Mavic Elite S that have over 20000km and a set of Mavic Ultimate Carbone Tubulars that have over 40k on them. Ride smart, avoid potholes and curbs and don't be bunny hoping **** and almost any wheel set will hold up. Get what gives you piece of mind but don't fret to hard especially at your weight.
Liked 4,218 Times
Stuart Black
Stuart Black
Quoted: 131 Post(s)
Liked 141 Times
Spoke size
Cyccummute I don't know whether to believe your description or to just believe Vuelta's website when they say a spoke is 4mm. I guess I'll have to go with Vuelta since I did own a pair of these type of wheels and the spokes were bigger than 2.6mm. And no they did not neck down to any 2mm sizes. I worried about a broken spoke and measured mine. I think the spokes for Vuelta are proprietary to their design so spokes might be only available from them. They never caused problems. You might take a good caliper and go find a set of these wheels and start measuring the spoke size for yourself.
Liked 4,218 Times
And, as I'm very unlikely to buy a $350 wheelset that I would have zero use for, I doubt that I'm likely to be able to measure one. If you have one and post a picture of the measurement, I'll agree but until I see the measurement, I'm still skeptical.
Stuart Black
Stuart Black
Quoted: 131 Post(s)
Liked 141 Times
Lets talk Worksman wheels
A very popular bicycle in the New York City area is the Worksman. These are heavy duty bicycles meant for hard commercial service. Worksman is happy to sell you one of these bicycles. I own a Worksman Cycletruck. Worksman wheels come with 10 (3.05mm) gauge spokes. They also are equipped with rims that amount to small motorcyle rims. Wheels are available in 26 inch and 20 inch sizes. These bicycles are used in a lot of industrial locations and I had them at my work. The 10 gauge spokes are straight gauge and are not necked down. These wheels have very high loading ratings. It doesn't take much of an internet search to find both 10 gauge spokes and 12 (2.6mm) gauge spoked wheelsets in 26 inch size. A lot of what is termed Heavy Duty bicycles are sold with these extra strong wheelsets. There are a number of them in my city that are used by people for their daily lives. Usually these bicycles are coaster brake equipped and meant for heavy duty hauling service. I'm finding that electric motor aided bicycles often have 12 gauge spokes for durability though these are on the edges of what a bicycle is. As for doubts that Vuelta measured their spokes at their flattened widest instead of diameter I can't answer that. If anyone doubts the 10 gauge spokes used on bicycles please refer to the Worksman website. Bicycle rims are not all the same, thicker spokes have higher load ratings. More spokes per wheel carry more weight. Pretty simple.
Liked 4,218 Times
I have a drawer full of spokes at the shop...probably close to 1000...that we salvage from wheels that can't be reused for various reasons (usually related to worn rims). Not a single one of them is a 10 gauge or 3.0mm spoke. Not a one of them is a 12 gauge (2.6mm) or even a 13 gauge (2.3mm). There aren't even any in there that are triple butted with a 2.3mm head. There are a smattering of 2.0/1.8/2.0 double butted spokes and even a few 1.8mm and 1.8/1.5/1.8mm spokes. The vast majority of spokes are 2.0mm straight gauge spokes, probably around 99% or even higher. The number of 3.0mm spokes out in the world is vanishingly low.
As for their load capability, it's not due to the rims. For those bikes that use 3.0mm spokes, it's the spokes that do all of the heavy lifting (or, rather, "hanging").
To be clear, I'm a proponent of stronger spokes. The triple butted spokes are a better compromise than trying to use a 2.6mm spoke. The flange holes on nearly every hub made is drilled to 2.5mm. That's so that the threads will pass through the hub. A 2.6mm spoke would require a different hub or drilling out an existing hub. Drilling an existing hub is fraught with its own problems.
Stuart Black
Stuart Black
Having formally weighted as little as you and having been through many wheel sets, I offer my humble opinion(s).
Your concerned regarding your 16/24 wheels may be justified and replacing them with something more durable is probably justifiable. If you're riding for health, fitness and weight loss, then, you aren't racing and reduced spoke counts serve no purpose.
My take on things is: For health, fitness, weight loss and training purposes, the most important trait of my wheels is their long term durability and long intervals between service.
The DT R460 you mention will build up into a fine wheelset. As would a DT R511 or Velocity Deep V or HED Belgium C2.
More important to wheel longevity and durability is the combination of spoke count, spoke diameter and most importantly tension balancing of the spokes.
Since these aren't race wheels, there's no decernable advantage or reason to reduce the count from the 32 that all the above are available in. There also would be any reason why you couldn't get perfect service from a 28 front in combination with a 32 rear. So, at least from my perspective, I would look at a 32/32 or 28/32 set.
For spoke selection, the choices are pretty simple. The most basic being between straight gauge and double butted. Many of us who build our own clyde worthy wheels, and several shops that sell a lot of clyde wheels (such as Leonard Zinn) will concur that double butted spokes provide for a superior wheel and cost hardly anything. So, I would go, and have gone repeatedly, with DT Comp spokes, with brass nipples.
The most important and most often overlooked aspect of clyde wheel durability is spoke tension balancing. It is, by far, the most important aspect. And, requires either an initial builder with both the patience to do so and the equipment to laterally load the rim and hubs, or, that you have a suitably skilled wheelsmith to do the tension balancing after a very short breakin. I can not tell you how many bicycle technicians have claimed to me to be able to properly maintain wheels, but, fail in this regard. Being willing to visit numerous shops to find your wheelsmith or invest in the tools yourself and start practicing (if you're mechanically inclined).
Hubs: There are plenty of options, but, to be honest, simple 32 hole Shimano Ultegras or 105s provide everything I need for good training wheels, and, they're quiet. If I were to shop up scale from there, I would look for sealed bearings and perhaps a star drive type ratchet, but, most certainly still a steel freehub body.
That's my take on simple clyde training wheels.
Birth Certificate, Passport, Marriage License Driver's License and Residency Permit all say I'm a Fred. I guess there's no denying it.
Fullcount
9
07-28-18 05:26 PM
