From 14 mph to faster
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
Right. Remember too, a lot of the MPH averages posted around BF is on group rides, where drafting can easily add 2-3 mph or more to ones average.
I’m riding a Fuji Jari gravel bike with 28mm road tires right now.
1x11drivetrain. I’m thinking a bigger chain ring up front.
Charlotte, NC. No big hills but virtually no level terrain either.
Thanks for all the advice! I do have tendinitis on the top of the right foot (certainly holds me back a bit).
I didn稚 think of that. I知 trying to hook up with a group ride that averages 16 to 18 in the slow group. So maybe I知 not that far off that.
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,559 Times
Unless you're regularly spinning out your top gear (which I doubt), that won't help at all.
Likes For ThermionicScott:
What kind of bike are you riding?
What kind of tires are on it? Mountain? Road? A hybrid tire?
Is the seat adjusted well?
Are you heavy? > 250#
There are a lot of variables. Sometimes it just takes conditioning. A few years back I was riding up a grade that used to kill me and I passed someone struggling along. He was on a road bike and not overweight. He commented that I should at least act like it was hard for me. He was a newer rider and I wasn't. I was better conditioned. The day will come when he will ride the grade without a problem.
Likes For Rajflyboy:
Location: Rural Missouri - mostly central and southeastern
Bikes: 2003 LeMond -various other junk bikes
Quoted: 78 Post(s)
Liked 43 Times
How do I bust through this barrier ?
The reason I answered your question with "you don't" - is because I doubt that your next exercise gains will take a form of "busting through barriers."
Since I know nothing about your situation - I can hardly expect to successfully offer specific advice. So I'll just rehash a few things that seem important to me.
First of all, if you want achieve a goal - you have to have a good and accurate way of measuring where you are now. (same bike/same tires/same weather/same odometer
Secondly, you have spend some of your training (or riding) time not testing yourself. This means you must purposely ride slowly for good periods of time.
And finally, you have to make your attempts at improvement incremental. This means you set out very short, but very intense sessions of riding.
And finally - always listen to your body - to be able to ride really hard - you have to learn to rest even harder.
Good luck - keep the rubber side down.
Likes For Richard Cranium:
Quoted: 169 Post(s)
Liked 84 Times
You've got a good bike for getting stronger. A 2x10 would probably be a bit better but what you have will work.
My Giant TCR has 700cX28 tubeless tires on it so the tires are not a real issue.
I doubt that you are running out of gears.
A decent cycling computer (I run a Garmin Edge 500) will show you a lot of good data such as cadence, heart rate, speed, etc...
Whatever you do. For all that is HOLY... Do not ever look at Strava.
Is some of this purely Mental? Can it be a mental barrier as much as a physical one ?
Im not a strava fan.
Super Moderator
Quoted: 1173 Post(s)
Liked 919 Times
Yes, you have to be motivated to train harder, and endure the pain that goes along with it.
When you say you average 14 mph what do you mean exactly? Is this 14 mph average over an entire ride? If so, what's your terrain and traffic situation like? Or is it 14 mph cruising speed on level ground?
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,094 Times
I知 riding a Fuji Jari gravel bike with 28mm road tires right now.
1x11drivetrain. I知 thinking a bigger chain ring up front.
So you have extensor tendonitis? You might want to talk to a doctor about your footwear in general, and your bike footwear and pedals in particular.
Are you riding flat, clipless, or toe-clip pedals? I have no idea if that makes a difference for tendonitis, but it sounds like something worth checking out. I know that type of tendonitis is usually related to footwear, but I'm not a doctor and I don't play one on Bike Forums.
Tragically Ignorant
Liked 9,094 Times
Likes For bakerjw:
Quoted: 741 Post(s)
Liked 816 Times
Group rides. I was a steady 12-13 mph average until I joined a club. Even riding with 2 or 3 riders will boost your average. Besides drafting help, you will probably ride further, faster and maybe on roads that you would never think of going alone. Also depends how you measure the average. My Garmin pauses at stop light, coffee stops, etc. It only records and measures rolling time, which can make a big difference. On group rides, I'm usually 15-16 mph, sometimes into the 17s. When I rode solo, my average is also around 14-15mph. Don't obsess over the speed, just ride more, and you will ride faster.
Quoted: 18302 Post(s)
Liked 4,470 Times
There are a lot of variables. Distances, hills, roads, etc.
I have several bikes, and find that each bike has its own natural speed.
I struggle to keep my speed up on my Tricross. It seems like my road bike likes to roll about 2mph to 3 mph faster.
For my commuting, errands, whatnot, I'm often late going towards town, and go pretty quick, and then just grind on my way back home, often with a little extra load.
Intervals should work to increase your average speed.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
I think everyone including OP already knows that it takes physical training, time and effort to get faster. So inferentially, some common questions that he may be looking for:
Will road-specific equipment other than what he describes be appreciably faster?
Sure.
Is the speed he has now decent given his bike and how he describes his routes?
I'd say yes, that's nothing to be ashamed of, and if you need that validated just fire up Strava and make a long segment out of some of your usual routes.
Is it feasible for him to get significantly faster by training?
Again, skipping all the "it depends" stuff, there's no reason why he couldn't expect to gain several mph in average speed on the same equipment, same routes, by putting in a year of training.
Sure.
Quoted: 1572 Post(s)
Liked 642 Times
14 MPH is an interesting data point. It is about the speed at which aero drag losses surpass all the other things that are holding you back combined. If you want to go faster than that, work on your aero position on the bike.
How important is speed to you and what are you willing to do to achieve it? Training is definitely part of it, but you'll probably never reach 20 mph on a mountain bike.
Non omnino gravis
All that stuff about tires in this thread, and you're probably fine in that regard!
I have tried about everything and flats with 5 10痴 work best for me and the tendinitis. I may try buying a pair of 5 10 clipless and see how that works.
Doctors have said rest or slow down some with walking/exercising even though that sounds counterproductive to good health.
