Best Bike Multitool
My EDC is a Crank Bros M10 but on my road bike I have been trying the Spurcycle tool and love it. My only complaints about both tools is neither of them use a JIS screwdriver which would be way better. However so far I haven't seen anyone do a tool with a JIS screwdriver.
I really do want to try the PB Swiss tool but I need to get their allen keys and Torx keys first for my tool box.
As far as shop tools, get the best in the basics at the very least. I didn't like the idea of buying cheaper tools and then rebuying tools later so I prefer to spend the money upfront and get what I want.
Id like to have a decent basic set to do many things I need and buy a few tools along the way as I need more..
But since the high end park tools is not in my budget and Id like to have something.. id settle for getting a basic set of good quality but lesser priced tools since right now I don't have any shop bike tools.
Clark W. Griswold
Quoted: 4230 Post(s)
Liked 3,841 Times
I know what you mean.. For me it's just so I have something rather than nothing.
Likes For veganbikes:
Sure sure, but at least getting your most used tools as top end as you can get makes the most sense. If you don't change a lot of pedals, then a cheap pedal wrench is probably not going to be so bad and likewise for another tool that is less used. However things like allen keys, a JIS screwdriver and a cable/housing cutter should be of good quality and you can get a decent ones for not a whole lot. The Pedro's L-Wrench set is about $35, a Vessel Megadora JIS screwdriver is about $11 and the Jagwire Housing cutter is about $40. That will get you done with most of the important stuff people do more often. If you have those and probably a good T25 torx key you can do quite a bit of normal maintenance. Depending on my chain situation I may get a good chain tool or a masterlink plyers (Wolf Tooth comes to mind as they are portable, good quality and store master links in them) but for most basic stuff the three tools will generally get you by fairly well.
M.
Likes For MEversbergII:
Yes I don't want to get Cheap tools.. when I said inexpensive.. I meant as for a kit.. I didn't wanna drop $300-700 off the cuff..
I was looking at this kit here..
BIKE HAND
and I was going to also get a few higher end frequently used tools as well.
I have good wire cutters and crimpers..
But if you guys have another kit in mind I will look at it.. or Instead I'll just get a toolbox and buy tools piece by piece like you listed.
BIKE HAND
WALSTIB
Those kits are ok. Definitely better than they use to be. I keep one of those type on my truck and Park Tool at home. But better is Pedro's. Not as good as Park but still well made and should last a lifetime.. I like to think Pedro's about like Craftsman and Park like Snap-On.
Clark W. Griswold
Liked 3,841 Times
BIKE HAND
BIKE HAND
Something else to consider. When doing quick repairs or adjustments on the road getting a tool that doesn’t consist of a bunch of tiny pieces that will get dropped and lost easily.
Likes For Mitkraft:
M.
Quoted: 972 Post(s)
Liked 572 Times
The one I currently carry is the Fix-It-Stick system.
On my folding commuter bike, a Tern, I carry a "Tern Tool", which has everything I need for normal maintenance.
For my bikes that use removable master links, I have a Wolf Tooth master link pliers with storage space for an extra link. I didn't actually *need* this tool, but I liked the design and construction.
Quoted: 241 Post(s)
Liked 231 Times
Cool tool was Cool (at 1 time they had a Ti version ).. Gerber bought them out as I understand
There is a multitool Wiki?
https://wiki.multitool.org/tiki-inde...page=Cool+Tool
Quoted: 212 Post(s)
Liked 83 Times
I have a Topeak 18 for my commuter/hybrid, and a Topeak 9 for my road bike. Both are good for on-the-road fixes but I wouldn't ever consider pulling them out of my saddle bag in the garage to do real work. I have real tools for when I'm at home. I also owned a Topeak Alien II for awhile. I wish I knew where that went. It, too, was a nice tool, though heavy.
I've found, in practice, that once I get a bike well dialed-in, I never need the tool while out riding. Even on rare occasion where I have a mechanical issue on the road, the multi-tool has never been the right tool for the job at hand. Actually, the only mechanical issue I've ever had where a tool (aside from tire levers) might have been useful was a snapped rear shift cable (25 miles from home). What I *should* have done is used a multi-tool to tune the high gears out of the rear derailleur, forcing it to stay in a middle gear. That way I could have done my shifting using the triple front crankset and would have made it home without calling for a lift. But that didn't occur to me, so I limped along my 11t rear cog to somewhere I could call for a ride.
So although I have one multi-tool for each bike, I find that about halfway through each biking season I'm sufficiently satisfied with the bike's condition, and I take the tools out of my seat bags because I know I'm going to be doing some excruciating climb where the psychological advantage of not carrying that extra 1/6th of a pound makes all the difference in the world. (Joking of course, but this is how we tend to think as we toil up a steep climb, isn't it?) And so far I've never been in a situation where I regret not having it with me, though I don't doubt that day will come eventually.
Of course my good fortune of not needing a multi-tool as I ride is probably a product of my riding habits. My normal rides originate from my home, take me somewhere 7 to 35 miles away, and then back to home again. If I were setting out on some multi-day touring adventure, my need for a portable tool would be greater. Because as it is, I check things over before I head out, and if something minor comes up along the ride I make a mental note of it and take care of it when I get home. That strategy isn't as effective if your ride doesn't start and end at home each day.
WALSTIB
Well I'm sure the fine folks at Pedro's would disagree with me on who's better. I'm just going by price of each compared and my own humble opinion. All bike tools probably will get the job done if everything runs smooth. But when part your working on have been tightened too tight, welded themselves together or bolts are rounded off you might kick yourself for buying one of those $50 cheap tool kits.
WALSTIB
Advocatus Diaboli
Quoted: 4696 Post(s)
Liked 1,512 Times
Advocatus Diaboli
Liked 1,512 Times
I'm a minimalist and can probably count on one hand the number of times during a ride I've needed a tool (other than levers).. For me, perfect is the SKS Tom7 for the just in case scenario. Though I'm intrigued by the prior mention of the Barstow chain tool.
SKS Tom7 MultiTool
SKS Tom7 MultiTool
WALSTIB
Not saying Park best at everything. But some of the standard tools a little more robust than Pedro's. But either fine to run a bike repair shop with.
Super Modest
Quoted: 10872 Post(s)
Liked 4,529 Times
If you really want it moved, I can move it but you're getting a lot of responses here. It's up to you.
Keep the chain tight!
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
I think it's cool! IMO, a few individual tools work better than a multi-tool and save weight because they only have what you might need. Saving weight and a working bike are both cool.
SE Wis
Quoted: 2716 Post(s)
Liked 3,332 Times
I picked up a set of "Fix-It-Sticks" at InterBike a couple years ago. I like the ability to interchange the hex bits so I can have all the ones I need.
I will continue to look at Tools and though I have found usefulness in multi-tools on a ride more so with friends I am riding with
I will end up probably buying tools piece by piece as I need them for my home set up. So I am not stuck with tons of tools I don't need
and don't use.
I knew of Pedros tire levers but did not know they had a whole line of tools I will look into them if they are quality tools for a
lesser price of Park.
as far as moving the post.. No you are right I got a good amount of response here.
Farmer tan
In tens of thousands of miles, I've only ever needed
Spoke wrench
4mm Allen key
5mm Allen key
Flat driver
Chain tool
1 lever
I've broken the Topeak Chain tool, so won't use aluminum chain tools any more.
The Pedros 6 Pack contains 3 of the above (spoke key, flat driver, 5mm, steel chain tool), so I just add a separate 4mm Allen key.
Spoke wrench
4mm Allen key
5mm Allen key
Flat driver
Chain tool
1 lever
I carry a Topeak. It’s about 3 years old. I’ve used the side scab tire irons to change flats out on the road. I also carry’s Swiss Army knife. Other than flats, I haven’t needed either, but I would want to be on a long ride without either.
Quoted: 17 Post(s)
Liked 5 Times
These days, it's been replaced by Wolf Tooth Pack Pliers and an I9 Matchstix.
