Steel is Real.. Explain?
Sunshine
Quoted: 10873 Post(s)
Liked 7,354 Times
Ok I keep hearing and seeing quotes about "Steel is Real".
What is with the fascination? I am assuming it is related to steel framed bikes.. but why is this the thing now?
Im not mocking steel bikes.. they are robust.. very rugged.. But aren't they a bit heavy too?
With everyone trying to be light and go carbon.. Im seeing so much "Steel is Real"
But reasons for that rhyme are...
- people like the look of traditional sized tubes and the simplified frame fabrication.
- people dont think a bike needs to be so laterally stiff that it cant at all flex in order to be fast or have fun.
- people equate the inherent spring of steel compared to other materials with comfort.
- people dont understand geometry and think that their relaxed old 80s bike is more comfortable than their modern massive carbon tube aggressive TT bike because of material when its actually also due to geometry and tires.
- people like to buck the trends and go against what is being heavily marketed or most popular.
There are a ton of reasons the saying is popular. A lot of the reason though is that it rhymes.
Likes For mstateglfr:
Quoted: 4227 Post(s)
Liked 2,487 Times
The reason it's real is because it can be welded or brazed.into a strong durable structure which will last for a very long time...Carbon is just a bunch of plastic held together with some epoxy and it's weak and fragile.
Likes For wolfchild:
Likes For Kovkov:
Quoted: 169 Post(s)
Liked 84 Times
I find aluminum to be a harsh ride.
Carbon is a bit softer until it isn't.
Steel is a smoother ride.
There are 2 kinds of steel frames. There are the cheap ones that are heavy as heck and then the ones that are built with better tubing and lighter. Were my Giant TCR frame to die, I'd likely get a custom steel frame to replace it.
Likes For bakerjw:
Bikes: '84 Peugeot PH10LE
Quoted: 397 Post(s)
Liked 55 Times
If you're used to one type of frame material that isn't steel, or never had a steel bike (e.g. only aluminum or carbon bikes), then you should be pleasantly surprised by the different riding characteristics of steel.
Sure it's a little heavier. But let's stop taking ourselves too seriously. Unless you're doing the Giro, who are you fooling? "Steel is real" is not a dig on new designs ... but there was little wrong with bike design prior to carbon and aluminum (and titanium, though I do like my titanium bikes).
Jon
Likes For Jon T:
Quoted: 663 Post(s)
Liked 496 Times
Not yet mentioned, in this era of the need for sustainability, is the fact that steel and even aluminum frames can be recycled. I wonder if anyone else has noticed how most everything we buy comes in packaging that is then thrown away. Half of what we but is trash and the other half becomes trash soon thereafter.
Likes For berner:
Quoted: 1218 Post(s)
Liked 6 Times
Steel.....it's the keepsake of the nostalgic crowd. Newer materials and carbon layups allowing you to control inherent flex and rigidity will surpass "Steel ride flex".
Technology advances in time......because I have never seen the old steel bike crowd pull up in their horse and buggy. Just sayin!
Likes For Slick Madone:
Quoted: 7620 Post(s)
Liked 3,432 Times
In other words, people are using a catch phrase to amplify their personal preferences.
Likes For Maelochs:
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 735 Times
Modern production of steel tubes allows stiffness and flex to be controlled. Tube shape, butting profiles and construction can make a frame as flexy or stiff as anyone wants. It is expensive and a good builder can build the bike with any handling and ride characteristics desired.
I have a 15.9 lb steel bike. That's ready to ride weight. Steel can be built almost as light as any other material. Like other materials, weight is inversely proportional to cost. Vari Wall S3 tubes are not cheap.
My steel frame weighs less than most wheelsets.
-Tim-
-Tim-
Likes For TimothyH:
Likes For jlaw:
Quoted: 95 Post(s)
Liked 12 Times
What is Carbon Fiber? | ZOLTEK
Likes For satrain18:
Likes For jlaw:
Quoted: 575 Post(s)
Liked 985 Times
If chromoly were discovered today, it would be hailed the greatest material.
Likes For DorkDisk:
Likes For Lemond1985:
Quoted: 95 Post(s)
Liked 12 Times
-Tim-
-Tim-
The only reason why it's so light is because it's a fixed gear, i.e., no derailleurs, extra chainrings, cassette cogs, or shift levers to add weight. Also the fork and handlebars are carbon fiber instead of steel in aluminum respectfully.
- Soli Deo Gloria -
Liked 735 Times
My entire point is that the idea that it is impossible to make light, strong and stiff steel bikes simply isn't true.
-Tim-
Likes For TimothyH:
Liked 3,432 Times
My favorite color is fastest and it sounds the best, too.
Likes For Maelochs:
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Similar Question...
could be asked on a oenophile or sommelier web forum comparing good enough box wines from Costo with an exquisite vintage. Some folks may never have the capacity or opportunity to get it.
Why would I need a Lamborghini Huracan when my Geo Metro gets me from point A to point B? Why, indeed.
Why is an ethereal perfume gracing the neck of a beautiful woman so intoxicating? Isn't Avon Crystal Aura on the girl at the BowlAmerica good enough?
Ride a superior steel bike and find out why...
Likes For Phil_gretz:
Sunshine
Liked 7,354 Times
Sunshine
Liked 7,354 Times
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,094 Times
