Pinarello ID: Need help
Bikes: 1973 Raleigh Super Course - 1981 Velo Sport Criterium - c.1988 Colnago Master Piu - 1991 Merlin Road - 1991 Eddy Merckx Corsa Extra - 1995 Pinarello Cromovan - c.1999 Lemond Maillot Jaune Team Saturn - 2002 Colnago C-40 - Also modern stuff
Quoted: 51 Post(s)
Liked 38 Times
Hello,
This is my catch of the day! This Pinarello is mounted with Campy 6 speed C-Record - except for the brake callipers - which seems to be 1986 (brake levers are from the 4th gen I think). I also have the original C-Record pedals with original straps and the original Rolls saddle, all in pretty good shape. The owner did not remember the model and I have a hard time identifying it. It has been repainted (see the columbus decal) and there is also something I could not see on any other Pinarello: rear brake cable brackets are welded bottom/left side of the top tube (see picture). Maybe it was welded by the painter (was repainted at Marinoni).
If someone can help with id/dating, it would ne greatly appreciated.
Thanks,
Francois
Thanks,
Francois
Quoted: 51 Post(s)
Liked 38 Times
Sorry, my images are crap ...
Bianchi Goddess
Quoted: 2926 Post(s)
Liked 2,921 Times
Pretty color
Sugar "Kane" Kowalczyk
Quoted: 51 Post(s)
Liked 38 Times
Quoted: 51 Post(s)
Liked 38 Times
Any idea about this bike and its uncommon rear brake cable lugs? Treviso 1984-85?
Or maybe someone can indicate a source of information On the web. I am short of search words on Google...
Quoted: 51 Post(s)
Liked 38 Times
I am just trying one more time to get pieces of info about this bike from some Pinarello gurus.
Thanks
Thanks
Steel IS Real
Not sure of course but I have an 85 Treviso Victory and the fork on mine is different(more flat) than the bike in this thread. Also mine did not have the GP engravings on the seat stays. So perhaps this may be a fancier model than a Treviso(Asolo/Montello?)
No pump peg on the headtube, as well as what looks to me a later bottom bracket design with "Pinarello" on it, my '85 simply has 2 slots cut in it.
My guess is later than 1986 for sure as you've already said in you original post.
Bottom ran brake cable lugs are interesting indeed!
Quoted: 51 Post(s)
Liked 38 Times
Thanks Sergey. Probably not a Montello. My understanding is that Montello all had the top tube internal rear brake cable routing as well as both seat stays chromed. The more I search about Italian bikes (Colnago's and Pinarello at least), the more confused I am
Quoted: 1078 Post(s)
Liked 1,896 Times
Montellos didn’t have a chainstay bridge and used SLX tubing. Typically the rear triangle was fully chromed. (Mine didn’t have any chrome, it does now )
I think yours has had the top tube replaced.
Quoted: 51 Post(s)
Liked 38 Times
I will try to ask the vendor. He was the original owner
Hard to see since it's been resprayed but what I see is OG537 (or is it GG537? Possible).
Also, if it's of any help, it has a Pinarello rear drop out, not a Campagnolo one.
Quoted: 51 Post(s)
Liked 38 Times
Thanks for you time on this P!N20, greatly appreciated.
Bikes: 1987 Pinarello Montello, 1996 Litespeed Classic, 1996 Colnago Master Light, 1997 Litespeed Ultimate, 2006 Opera Leonardo FP, 2006 Pinarello Paris FP, 1984 Pinarello Record, 89-ish Cornelo Profilo
Quoted: 148 Post(s)
Liked 119 Times
You seem to have researched thoroughly. Unfortunately, pre-84 info is pretty much impossible to come by.
FWIW, the fork and the bottom bracket look just like what's on my 87 Montello. Forks can be changed, so don't read too much into that. Montello's didnt have the BB bridge. They did have internal routing, except for the very first model, which was like a Treviso.
Treviso, (and all, AFAIK, of the mid-80s frames except Montello) had the cable routed along the top of the top tube with three attachment points.
What does your brake bridge look like?
Quoted: 148 Post(s)
Liked 119 Times
This is an interesting 1990 catalog page:
https://www.retrobike.co.uk/gallery2/...ogoTreviso.jpg
Montello here can be SL or SLX.
It's worth pointing out that your frame does not have a front derailleur hanger. Here's a page from an 85 catalog showing both with and without on a Treviso. I don't know that I've ever seen earlier than the 85 catalog. Maybe yours is an 84.
Quoted: 148 Post(s)
Liked 119 Times
I actually just came across an 81 catalog:
https://labibleduvelocataloguespinar...ello-1981.html
No help identifying your frame though. It's very possible the re-painter removed rusty cable lugs and added new ones where yours are. You could remove the paint in the right area and see what the base metal looks like. (Hope you realize I'm kidding)
Quoted: 51 Post(s)
Liked 38 Times
Exactly like the Treviso on the 85 catalogue image.
Ouf! Good that I read until the end this time . I think I will contact the seller to have more info on this.
So Treviso 84-85 is probably right. Thanks CyclingFool95. Concerning pre-84 info, here is a link where you will find info about 79 and 82 bulgier.net - /pics/bike/Catalogs/.
Liked 1,896 Times
Interesting, I’m not sure when the Pinarello stamped dropouts were introduced. I would have said 87, but that’s just a guess.
