Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
Fuji Track Elite
Old 08-18-18, 12:20 PM
  #126
tobukog
Quoted: 117 Post(s)
Liked 23 Times in 14 Posts
You can use both sides normally. Most track racers don't use a lock ring. You do have to use a lock ring if you use a carrier style cassette system.
tobukog is offline
Old 08-18-18, 03:45 PM
  #127
krispenhartung
krispenhartung's Avatar
Bikes: S-Works Venge Dura-Ace DI2, KTM Strada 4000, Fuji Norcom Straight 1.3 (TT), Fuji Track Elite, BMC Trackmachine TR02
Quoted: 100 Post(s)
Liked 3 Times in 2 Posts
Ah, very interesting! Thanks.
krispenhartung is offline
Old 08-18-18, 07:13 PM
  #128
Dalai
Quoted: 89 Post(s)
Liked 8 Times in 6 Posts
Originally Posted by krispenhartung
so these Oval rear wheels on these elites have cog threads on both sides. However, one side has fewer threads and if you put a cog on it, there's not room for a lock ring. I have no idea what's going on here. Can anyone explain? Is that for a different type of cog?
Sounds like a flip flop hub. One side for track cog and lock ring, the other for a free wheel... Common on wheels built for use either fixed or single speed.
Dalai is offline
Old 08-20-18, 08:18 AM
  #129
Hrothgar42
Quoted: 24 Post(s)
While it does sound like the wheels could be flip-flop from that description, they are not.
Hrothgar42 is offline
Old 08-20-18, 09:01 AM
  #130
topflightpro
topflightpro's Avatar
Quoted: 1851 Post(s)
Liked 679 Times in 430 Posts
Is it possible that they are flip-flop with a fixed/free option?
topflightpro is offline
Old 08-26-18, 09:51 AM
  #131
krispenhartung
Quoted: 100 Post(s)
What do you think...too tight? I have set it up with this clearance with 52:15, which is the largest chain ring/cog size I would use for all configurations. I can gear up to 100 inches by adding a 14t cog and everything in between with smaller chain rings, with plenty of clearance on my chain stay. But despite the aerodynamics of the tight clearance, are there dangers in it being that tight? I might be taken out by a small pebble. ;-)
Old 08-26-18, 10:16 AM
  #132
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
Liked 50 Times in 37 Posts
no real danger other than something jamming between tyre/cutout. My old aluminum P3 did that once and it left a gnarly gnash in the cutout. That was on (a bad) road of course, and I used to run it very tight. I can't imagine it's a problem on the track. Shorter distance for it to go if you ever pull a wheel
Morelock is offline
Old 08-26-18, 11:44 AM
  #133
krispenhartung
Quoted: 100 Post(s)
Unfortunately, the way chains link together I'm not able to back off in a small increment. The next shorter size of chain with 52:15 puts my axle bolts about in the middle of the chain stay, which means if I put a 51:14 or 51:15 on it, its way back toward the end of the chain stay.
Old 08-26-18, 04:21 PM
  #134
Baby Puke
Bikes: Marin Stelvio, Pogliaghi SL, Panasonic NJS, Dolan DF4, Intense Pro24 BMX
Quoted: 365 Post(s)
Liked 87 Times in 58 Posts
A half link can be a helpful thing to have around, but you have plenty of clearance in the photo. Unless you're riding in gravel?
Baby Puke is offline
Old 08-26-18, 04:22 PM
  #135
krispenhartung
Quoted: 100 Post(s)
Ha ha...no gravel! Don't think I've seen a cyclocross velodrome, but that would be interesting.
Old 08-26-18, 10:02 PM
  #136
700wheel
Quoted: 144 Post(s)
Liked 14 Times in 11 Posts
The nearest thing might be a damp grass track race - your Fuji would jam up with muddy grass.
700wheel is offline
Old 08-26-18, 11:39 PM
  #137
Baby Puke
Quoted: 365 Post(s)
BTW, @krispenhartung, cool looking chain- what is it?
Old 08-27-18, 06:28 AM
  #138
krispenhartung
Quoted: 100 Post(s)
That’s one of those Izumi Eco chains. I’ve been trying them out.
Old 08-30-18, 12:13 PM
  #139
krispenhartung
Quoted: 100 Post(s)
Has anyone experienced any issues with your saddle not staying tight on the rails and the nose going down? I have experienced this both with my Fuji Track Elite and my Fuji Norcom Straight TT bike, both of which use the same saddle tightening mechanism. I'm not sure what to do. I am tightening it to spec -- 12nm. It's driving me nuts.
Old 08-30-18, 01:03 PM
  #140
carleton
Elitist
carleton's Avatar
Quoted: 1386 Post(s)
Liked 92 Times in 77 Posts
Any pics (even product pics from the website) of the seatpost in question?
This is a common problem among clamps that use a one-bolt design. They seem to work based on friction. These work fine when the rider is in the center of the saddle. But, if one rides "on the rivet", it's subject to tilt...even under smaller riders.
This is why 2-bolt systems (like Thomson and many others) are prized. The bolts work in opposition of each other, one keeping the other from giving up.
carleton is offline
Old 08-30-18, 01:12 PM
  #141
krispenhartung
Quoted: 100 Post(s)
Here is the pain in the butt:
Old 08-30-18, 02:00 PM
  #142
krispenhartung
Quoted: 100 Post(s)
I called the dealer here and they said try some of that carbon paste/grit. Put it all over the inside mechanism that allows it to rotate the saddle up and down.
Old 08-30-18, 03:20 PM
  #143
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
Rail size/clamp size issues is my first guess. Most carbon rails are bigger than metal ones.
Ritchey sells a carbon specific clamp that should fit. (the topper Fuji uses on the Track Elites is a WCS 1-bolt clampset)
Morelock is offline
Old 08-30-18, 03:44 PM
  #144
krispenhartung
Quoted: 100 Post(s)
That may be worth a try, though I have seen this slippage on both carbon and non-carbon rails. I also just put some carbon grit paste on there so we'll see how it holds up on the track tomorrow night.
Would you off hand know the specific product and model of Ritchey clamb that it compatible with the Fuji clamp?
It just seems like poor design to me. The contraption that holds the rails and tightens down sits on another piece that has a sort of a quarter size rotator cup. Reminds me of how a bone ball joint rotates in a rotator cup.
So when you tighten down the bolts, all it does is tighten down on the rails (which works fine for keeping the rails from sliding forward and backward), but also tightens down the ball joint, which is entirely inefficient at keeping the whole thing from rotating up and down on the cup, which is totally slick metal with no resistance at all. . Just seems wrong.
Old 08-30-18, 03:45 PM
  #145
krispenhartung
Quoted: 100 Post(s)
It this it? https://us.ritcheylogic.com/us_en/wc...seatpost-clamp
Old 08-30-18, 04:03 PM
  #146
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
That's it. There are a couple of different size carbon rails fyi, I know some of the Fizik's are bigger/smaller than most.
Strange to have seen it slipping with metal rails as well. This is the same topper a lot of TT/tri (P5,etc) bikes switched to last generation and they generally get glowing reviews. I've wrenched a couple of them and never had anyone complain about slipping. Is there any chance the bolt is loosening? Checked the threads/use blue loctite?
I still think the right piece for the carbon rails would help, but I also think you should disassemble everything on the topper and look for anything that seems out of place. The metal rails should have been rock solid.
Morelock is offline
Old 08-30-18, 04:11 PM
  #147
krispenhartung
Quoted: 100 Post(s)
I ordered the new clamp, based on the Fizik carbon rail spec. I'll add some locktite a swell in addition to the carbon paste.
Old 09-01-18, 04:29 PM
  #148
carleton
Elitist
carleton's Avatar
Are carbon rails worth it?
Riding the track, you are more likely to break rails than on the road. I've seen averaged-sized racers both crack the saddle frame or break rails when hitting bumps on tracks.
I'd go for steel or "Kium" (whatever that is that Fizik uses) over titanium or carbon rails, even if I were of average weight.
I think carbon rails are simply for the weight weenie crowd and a way for companies to charge double for the same saddle.
carleton is offline
Old 09-01-18, 05:17 PM
  #149
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
Yeah but not all tracks have Dick Lane pot holes
Morelock is offline
Old 09-01-18, 06:27 PM
  #150
Jared.
Uninformed Senior Member
Bikes: Dolan Pre Cursa, Cannondale R400
Quoted: 7 Post(s)
True you could have the "speed bumps" and "launch ramps" of Kissena.
Jared. is offline
