Go Back  Bike Forums > Bike Forums > Fitting Your Bike
Between sizes?!
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Between sizes?!
Old 11-09-18, 01:34 PM
Korina
Happy banana slug
Korina's Avatar
Quoted: 1530 Post(s)
Liked 1,527 Times in 915 Posts
Between sizes?!
I've been riding size small bikes forever, and they're okay, if a bit cramped; I always assumed that was normal. I test rode this 48cm Kona Dew Plus and it fit like it was custom made for me; I didn't want to take it back to the shop! Unfortunately, the top tube hits bone. I also rode a women's Specialized Sirrus in medium, and ran into the same issue. What do I do with this knowledge? The only thing I can think of is to put on smaller wheels, but that would lower the bottom bracket, never a good idea. Stick with the smaller size and do what I can to make it fit? ...?
Any advice would be greatly appreciated.TIA.
Korina is offline
Old 11-10-18, 04:05 PM
tangerineowl
Bikes: Curve Grovel v2 ti
Quoted: 257 Post(s)
Liked 90 Times in 74 Posts
Look up the geo chart of that 48cm Kona. Take note of the stack, reach, and standover.
Hunt around online for a flatbar with similar stack and reach, but a lower standover.
tangerineowl is offline
Old 11-10-18, 07:42 PM
Carbonfiberboy
just another gosling
Carbonfiberboy's Avatar
Quoted: 3877 Post(s)
Liked 1,929 Times in 1,377 Posts
You actually don't need standover height. You need to be able to reach the ground with one toe, and that's it. However if you don't have that, it's a problem.
The usual thing for a too-short reach is a longer stem. How does your current bike feel cramped?
Results matter
Carbonfiberboy is offline
Old 11-10-18, 11:41 PM
Clyde1820
Bikes: 1996 Trek 970 ZX Single Track 2x11
Quoted: 614 Post(s)
Liked 563 Times in 427 Posts
Originally Posted by Korina
I test rode this 48cm Kona Dew Plus and it fit like it was custom made for me ... Unfortunately, the top tube hits bone.
How about the Kona Coco, size=Med? It's of similar frame material, components spec, and the geometry is pretty close to the Kona Dew 48cm bike.
But the Coco has a step-through frame design. And the minor differences in reach/stack should easily be dealt with via simple changes in stem/bar/saddle.
Dew v Coco:
TT: 556mm / 550mm
ST: 480mm / 470mm
HT: 140mm / 130mm
stack: 573mm / 566mm
reach: 392mm / 388mm
standover: 745mm / 547mm
frame: 6061 butted aluminum
fork: Kona Project II aluminum
brakes: disc
derailleurs: Altus & Acera / Alivio & Acera
MSRP: $700 / $750
Clyde1820 is offline
Old 11-12-18, 11:21 AM
Korina
Happy banana slug
Korina's Avatar
It feels like the top tube is too short; I can't stretch my back out quite as much as I'd like. Also, when I stand, I'm right up against the stem. My stem is stock; the specs just say 'Giant Sport' with no indication of the length, but it's pretty long. I thought standover was about emergency stops? A top tube touching bone could do considerable damage.
Korina is offline
Old 11-12-18, 11:26 AM
Korina
Happy banana slug
Korina's Avatar
While that Coco is a rather cool-looking bike, I have an unreasonable dislike of step-through frames. Maybe I'll look at it some more. Thanks for doing the research!
Korina is offline
Old 11-12-18, 10:36 PM
Carbonfiberboy
I'm saying, "try a much longer stem." The stem on the bike to which you link looks short to me. I'm a roadie though and don't know what's normal for MTB bikes. On a road bike, 120mm would not be excessive. It's a cheap thing to try anyway.
I've never made an emergency stop which required me to put both feet on the ground. I for sure don't have the reflexes to unclip both feet while bringing the rear wheel off the ground with the front brake. In that case one would drop the butt off the back of the saddle anyway. The one thing you couldn't do would be to drag both feet on the ground in event of a complete brake failure.
Results matter
Old 11-13-18, 08:11 AM
rhm
multimodal commuter
rhm's Avatar
Quoted: 1908 Post(s)
Liked 574 Times in 339 Posts
Have you tried the 46 cm frame size? It has smaller wheels, and lower bottom bracket, and therefore lower top tube and lower standover height. With the lower BB it may also have shorter crank arms (which is a good thing, in my opinion). If the shorter reach makes it feels cramped, you can always use a longer stem.
www.rhmsaddles.com.
rhm is offline
Old 11-16-18, 12:07 PM
wipekitty
vespertine member
wipekitty's Avatar
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times in 163 Posts
Another vote here for trying a longer stem
IMO, going with compact geometry is also on the right track. I'm no geometry expert, but I wonder if there might be similar bikes with an even more dramatic slope in the top tube (*not* a step through).
I'm quite a bit bigger than the OP, but personally, I've had good luck going with larger sizes and compact geometry; with a horizontal top tube, I usually have to size way down and then put on some kind of crazy long stem to be comfortable. My significant other's 56cm vintage Centurion is delightful once I'm on it- but there is no way to get a foot on the ground without injury.
wipekitty is offline
Old 11-21-18, 03:47 PM
Korina
Happy banana slug
Korina's Avatar
Looking at the geometry here, there's no sizes listed for the crank arms, so they're all likely 170. Bottom bracket height is the same for all sizes, and the wheels are listed as 650 x 47. Looks like the difference is in the head tube and seat tube lengths. The top tube is quite a bit shorter, which is one of the big issues for me. A longer stem can only do so much.
Korina is offline
zinedrei
Fitting Your Bike
2
06-17-19 05:42 AM
joejack951
Road Cycling
59
01-28-18 07:11 AM
Bolo Grubb
Fitting Your Bike
4
07-29-16 10:16 PM
Fastfwd01
Road Cycling
25
07-20-15 03:06 PM
wchevron
Fitting Your Bike
4
10-20-14 11:16 PM
