I Own a Supercycle KrossRoads, How Can I Make The Gearing Suck Less?
Quoted: 24 Post(s)
I hate skipping/choppy gearing with a passion. The local bike shop basically gave up on the bike because the rear derailleur is permanently bolted to the frame...with a flimsy aluminum bolt. It's constantly falling out of alignment, to the point where I need to adjust the fine tuner before every ride. That only minimizes the skipping though, it goes into hiding, waiting for the perfect moment to throw me off the pedals while I'm standing up, trying to climb a hill. Is there any way to salvage this? Would converting it to a 3 speed or 7 speed solve the problem? I'd be willing to do either one. It's not a terrible bike in general, I like the height of the frame combined with the 29" wheels. The weight is good. All in all it's alright for the light/moderate city trail riding that I do. I don't need disc brakes, the lightest strongest frame, or whatever else goes into the 1000$+ 1-7 speeds from the "premium" manufacturers. I appreciate the value that made in china offers, I just want steady gearing.
Quoted: 24 Post(s)
Yeah, I know that. There is nothing wrong with it aside from the gearing issues, and I don't need 21 gears. So I can either gather some useful input on which setup would be more likely to fix the problem (ditch the rear derailleur or the front, 3 speed or 7?), or I can just experiment and figure it out for myself. I live in Canada, so most of what you recommend isn't going to be viable or a good value. Chinese products are exponentially cheaper here than American imports. Canadian options are few and far between. I hope this clarifies my goal so that we can get back on topic. I don't want a new bike, I want to repair what I have. The bike is functional, let's focus on improving the functionality.
What is the tooth counts of the cogs and chainrings?
Did you learn to do math to calculate ratios ? the crank number turns the hub number in a gear ratio..
what are those ratios?
Quoted: 24 Post(s)
Nope, don't know much about any of this. The only lead I have from the bike repair shop is that the rear derailleur is loosely attached, constantly going out of alignment. So my guess is that it needs to go. The problem is that leaves me with a 3 speed, where I'd prefer a 7 speed. I'm hopeful that I may be able to bypass/remove the rear set and upgrade the front set of gears. Is that a common modification around here?
Quoted: 1572 Post(s)
Liked 643 Times
Quoted: 1818 Post(s)
Liked 1,693 Times
Your derailleur can be replaced, the bolt attaching it to the frame can be removed and it is possible to purchase a better one. You have a run of the mill Shimano Tourney derailleur. It can be changed for a higher end Shimano derailleur
Quoted: 67 Post(s)
Liked 83 Times
Quoted: 1182 Post(s)
Liked 833 Times
Most derailleur hangers on aluminum frame bikes are made to break if the derailleur is impacted, and are replaceable. Is it the bolt(s) holding the hanger to the frame that come loose, or is it the bolt holding the derailleur to the hanger that comes loose? You can keep the hanger to frame bolts tight by using a blue Locktite. You may have stripped threads on the frame or the hanger.
Quoted: 523 Post(s)
Liked 228 Times
A good reason to read the reviews before you buy
I looked up your bike online and it is a Canadian Tire exclusive priced at $400. It is a one-size-fits-all with only one frame size so you must be lucky to be the one person who actually fits the bike. It didn't take much time reading the reviews to find your problem. It gets a 2.3 out of 5 stars at the Canadian Tire site. There are three reviews. Two are titled "Disappointed" and the third says "Almost Perfect". Both of the "disappointed" owners write about the lousy gear system. Complete with misspellings:
"Very Dissapointed
Does not shift at all will only stya in one combination of gear selection, The seat post I raised and notice within a week it was all rusty (in a week) Not being able to shift is a pain I have no way of adjusting like a bike shop where they can clamp the bike a adjust while peddling and Ishouldnt have to anyway. Sorry to those who bought one hope your experience is beeter than mine."
Disappointing
Disappointing
Purchased this bike at the Bathurst NB location, because it was the only store that had it available in the province during a sale. Got it home and had to tighten everything up and started to drive. It worked okay at first, but quickly changed. The bike wouldn't shift gears and then the bearings went on the rear tire and on the pedals after one month...the 40% off price was useless as it cost almost twice that to make it road worthy again. Do not recommend buying this...Canadian Tire is really going downhill on product quality and customer service...hardly worth visiting anymore!
I agree with the suggestion you cut your losses and try a different bike. This one will only give you headaches.
Quoted: 24 Post(s)
Quoted: 24 Post(s)
I don't see any way to remove the derailleur without damaging the frame. It isn't just bolted on with a removable bolt, it's welded to the frame. Replacing it wasn't an option, and the bike shop is certainly willing to take my $ to upgrade various other parts. I don't have any money into this bike, so I guess I'll just get rid of it. I don't want to make the same mistake again though. What should I know about 21 speed vs 7-10 speed options? Is one typically more reliable than the other for smooth shifting?
Liked 1,693 Times
21 speeds means that you have a rear derailleur with a 7 cog freewheel or cassette along with a crankset having 3 chainrings. For the most part today, bikes with "21 speeds" use very low quality components. Fewer "speeds" might well mean even cheaper parts and poorer quality. I find it very hard to believe that your rear derailleur cannot be replaced. I have worked on various bikes for over 40 years and have not yet seen a rear derailleur that was welded onto any bike frame. Find a better bike mechanic
Quoted: 67 Post(s)
Liked 83 Times
That makes you especially unqualified to come up with a plain to rectify your situation. Your situation is probably unrectifiable, but even if it was, you would not be the man for the job.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
If it is indeed welded to the frame, I would not sink another penny into the bike.
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
Same here. I've worked on plenty of the lowest end Walmart bikes (like $89 'full suspension' 21 speeds ) and all had removable derailleurs. And I was able to get all to shift at least 'so-so', where one could get every gear and not fear dying from a dropped chain or missed shift.
Liked 941 Times
I think new members need a minimum of 10 posts before they can post pics.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
This bike seems to be the very definition of a Big Box "Bicycle Shaped Object". Reminds me of Craftsman tools as they evolved: Lots of features, none of which work very well. Or the features worked but the tool function sucked. But you seem to have considered this and made a rational (if not hopeful) choice. In any case, your next choice is whether to invest in fixing a bike where other parts and features may break or stop working. It may be a situation of "no choice" in that you don't have money for a new bike (or at least, you don't have money for a new bike that's much better than this one and won't have the same problems). But if you fix the RD, the fork may start leaking. etc. Still, you may want to try it: the bike fits and has worked pretty well.
If you decide to give it a shot, know that nothing is "permanently bolted". That's an oxymoron! By definition, bolts come out. If the bolt has been fixed with loctite you can heat it a bit to remove it. Worst case, you can drill* a bolt out and chase the threads. But I'd remove the derailleur, check the hanger alignment, and either replace the RD with a new one or try the old one.
*Really worst case: you use something called Electrical Discharge Machining (EDM) to erode the bolt out. But that's on another level of cost.
Lopsided biped
Bikes: 2017 Day 6 Cyclone (the Buick); 2015 Simcoe Deluxe (the Xebec); Street Strider 3i (the not-a-bike); GreenSpeed Anura (the Black Swan)
Quoted: 316 Post(s)
Liked 160 Times
I looked it up and happened to see a list of features, including "steel V-brakes". Another victim customer complained that theirs broke twice in six days and that Canadian Tire wouldn't refund their money but said they'd "fix it."
IMO, the only "fix" for this thing is very big and noisy and operates at somewhere above 3000 degrees F.
Cut your losses now, and don't even ride it again; it's hazardous.
I feel badly that this happened to you.
Considering it's a high-priced BSO, almost anything could be wrong with it. If the frame isn't bent, you could replace the rear derailleur. Or the freewheel. Or the chain. Or the shifters. They're all standard parts, if cheap. "Cheap" as in "sucky," not as in "inexpensive."
Is the chain long enough to go around the big/big combination without bending something?
Quoted: 24 Post(s)
This isn't my first time on an internet forum. I'd really appreciate it if we can cut past the elitist forum bashing and focus on the facts though. I started this thread because I want to learn what is causing the problem, and how to avoid it in the future. It looks like I'm going to be replacing the bike. So getting back to the task at hand, where does this problem typically arise from? Is it typically an issue with the rear 7 speed derailleurs, or the front 3 speed derailleurs?
My initial assumption is the more cogs you put on a gear set, the higher the margin for shifting errors. Is that an accurate starting assumption folks? I imagine it is even more complex when you need to align 2 sets of cogs with each other. Single speed is simply not an option for me, and 3 speeds probably isn't enough either. I want a new (or slightly used) bike that I can get over the local hills with. So what should I be looking for? Should I avoid anything with a rear derailleur, front derailleur, multiple cogs, greater than 5-6 gears per cog? Is it better to have 2 cogs with 3-5 gears, or one cog with 7-10? I'm here to learn what to buy, not just to learn all the specifics of why my particular bike is garbage.
Bad example
Quoted: 823 Post(s)
Liked 203 Times
Yeah now I'm remembering other problems with it. The brakes haven't failed after a summer of riding, but they are loose on either side of the tire, so it's half braked most of the time.
My own feeling is that a seven speed rear is pretty good and can be adequate for most riding. The benefit of more gears in the back is that the steps between the gear ratios are smaller, which makes it easier to match your cadence to the terrain (and thus make it a bit easier to ride.) as for the front, that depends on your terrain. If you have major hills, look at a triple crank so you can have a small granny gear. I live in Seattle, which is very hilly, so I typically run triple cranks with a 24 or 26 tooth small gear.
