Can someone please explain why tubulars?
#76
Quoted: 2337 Post(s)
Liked 2,813 Times
i got these at ~$30 each...... have not ridden them yet, but the build quality seems good based on visual inspection and mounting unglued to stretch...easy mount on mavic 330 rims..... .should ride next weekend
https://www.googleadservices.com/pag...BoCgLUQAvD_BwE
CHALLENGE ELITE PRO 220 TPI TUBULAR ROAD TYRE
- Use: Road Training
- Tire Width: 25 mm
- Internal Rim Width: 13-15 mm
- Weight: 295 gr
- TPI: 220
- Casing: Poly
- Flat protection: PPS
- BAR: 7-12
- PSI: 100-175
- Inner tube: butyl
#77
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4336 Post(s)
Liked 2,977 Times
probikekit.com has Vitorria Rally tubulars for $22.50. I’ll order a pair and give them a try.
I have three bikes that now have tubulars - the Serotta, Schwinn Peloton and a Della Santa. All came to me that way. So, I either figure this out or start changing those to clinchers. I’d rather keep the tubulars.
And yeah, Vittoria Rally is a poor tire choice. Look for some 27mm Vittoria, Challenge, or Veloflex, and expect to spend $50-$70 each.
One of the other local shops (about the same distance to the west as the other shop is to the east) did not know what a tubular tire was. Scratch them as help.
#78
Quoted: 809 Post(s)
Liked 1,018 Times
I've got to agree. Riding tubulars, even if you end up not liking them will give you the experience. This thread is making me think that perhaps I should have a set of tubulars. Maybe, I'll try the tape instead of glue.
My experience and the reason that I am thinking about it again, is that I never got pinch flats, which was a problem with my skinny training clinchers and they rode nice. I think they had less rolling resistance, but, I really don't know. Of course, now I am riding clinchers, however, they are wider. That is another way to avoid pinch flats.
#79
Suggestion: Pick one bike, maybe the one with the best tubular wheels, and make that your tubular bike and get some nice tires to go with it. Then you can switch the other two to clinchers if you want. You can read articles and watch videos and practice mounting the tires without glue so you'll know what you're getting in to. What you don't want, is three bikes with mediocre tires that you don't like.
I actually bought some sew-ups from a local Performance right off the shelf, and the cashier had ever seen such a thing before. They had good prices and stupid staff. Another time,another LBS, I brought a tubular wheel in asking about sealant for my flat. The guy offered to sell me a Slime TUBE. I said "this is a sew-up"... <blank glossy clueless eyes>... "So you don't want this tube?"
#80
Quoted: 1361 Post(s)
Liked 423 Times
Suggest lurking the following thread>
https://www.bikeforums.net/classic-v...y-tubular.html
BTW: Think to have my new fave tubular glue. Made in France, Pastali brand by Zefal.
(I say 'think' because I've yet to see how well it reacts in very hot temp days.)
Nice consistency, sets up within a half hour for tire mount. Like the tackness that stays on aluminum surface for when an unglued spare is mounted roadside. I'm using one 27gm (tube container) per wheel. It cleans up remarkably well, especially should any excess get on the sidewall. I let it mostly cure and then simply rub off the emulsion, ---no cleaners or chem.
Note: I don't know if its suitable for carbon tubular rims.
#81
Interesting. What is it that you like mainly? The ease of use? Pastali has been around forever. That's about the one glue that I've never used. Is it milky white like (old) Tubasti, or something else?
#82
Tubulars and rims are light (low angular momentum), fold up compact such that several can be carried under the saddle, low rolling resistance, quick change when there is a flat, no pitch flat issues .... That being said, I quit riding tubulars 30 years ago. They are now expensive and still difficult to patch - requires some learning curve to make a patch. And where I was riding was plagued with goat head thorns. Always carried three spares and many times over an 18 mile ride used all three spares. I now ride tubeless on all my bikes and have not experienced a flat in over 5,000 miles. They are heavier than tubulars but the puncture and pinch flat issue associated with tubes is pretty much no longer a worry. Just my thoughts on the query ...
#83
Liked 423 Times
#84
Quoted: 7346 Post(s)
Liked 2,452 Times
Jobst Brandt did rolling resistance tests and found that tubulars have more rolling resistance than clinchers, but that's not the most important thing. The fact that they feel better might mean that they reduce rider fatigue on long rides.
#85
Quoted: 378 Post(s)
Liked 1,409 Times
As humans, we experience all the variables at the same time, with no instruments other than our hands, heinies, and hooves. The Conti rep at NAHBS said they can make tubulars roll a lot easier than clinchers, purely by design, but there's no benefit for Continental or any tire maker, given the very high price they'd have to have for them.
With the broad range of wheels now being used, it's likely a wash, if that, especially given equal pricing, between tubulars and clinchers.
On a narrow, low-profile C&V rim, my position is that a decent mid-grade tubular is preferable to most clinchers, for comfort, road feel, and I'd toss in rolling resistance, just for grins.
Once you get into something like an A23 rim, I can't see how you can get definitively better than something clincher like a Conti GP4000SII 700x25/23, or a Veloflex Master. Holy cow they're smooth.
I've always wondered, as a tangent topic, do tires get "better" as they wear in? Either mine do, or I just get used to them. Not sure which.
#86
Quoted: 378 Post(s)
Liked 1,409 Times
#87
Quoted: 378 Post(s)
Liked 1,409 Times
Once they fork over the cash, and get them mounted, they tend to stay mounted until worn out.
There's an investment in wheels, glue/tape, time and tires. A switch is not taken lightly.
There are a lot of Denali's for sale, for example....and Walmart bikes.
#88
https://yarchive.net/bike/rolling_resistance.html
But remember that more rolling resistance does not always mean less speed. In fact, more deformation produces more speed when the surface is less smooth - up to a point. This is why you roll faster on gravel and dirt with less pressure in a tire. This is also why I think supple tubulars produce the feeling of smoothness and speed especially when riding on less than perfect tarmac.
#89
Liked 423 Times
Much as I appreciate those who test and report, most of it is useless. The inconsistency and variables present in real actual use are far from those test results. Then, theres folks who base it on PB and time. Again, those variables widely range because of the rider and his/her condition at that moment.
Not one single test has ever been presented with true consistency. So that blips out all and every test report. Sorry.
To do it right, you need a constant.
And how?
Firstly, get rid of the human variable. That's right. A fully motorized 'bike' POWERING 100% during the test period. These test should not be lab rolling road either but same course outside - be it gravel, tarmac, wet dry etc.. Report temperature / ambient to actual tire (pre - during- post) etc. Next, get into the topic of acceleration, constant speeds, to braking.
But again, its really a waste of time for manufactures to go through these test and measures in order to sell and toot marketing. When compared to motor vehicle markets, the bike tire market is miniscule plus the bicycle is a slow speed vehicle and that 99.9% of cyclist don't care to know or want to decipher tire test.
And how?
#91
Liked 2,452 Times
True, testing bicycles is very tricky.
#92
Quoted: 1827 Post(s)
Liked 3,367 Times
And how?
And how?
The tire companies have tried to get rid of the humans, and ended up with their steel drum tests. Everyone seemed happy for a long time, and pumped up their tires to crazy high pressures.
I think there was always an understanding that high pressures were really only good for smooth surfaces, and I swear I read a comment about this in an old Cyclo-Pedia catalog 40 years ago... but Jan H. did pick up the baton and run some tests with humans riding on rough surfaces. Not bad for a poorly funded individual. I keep waiting for Continental or some other tire company to carry out similar tests. The results, in general, were that rough surfaces demanded lower pressures for the lowest resistance (and lower pressures demanded a larger tire cross section if you don't want pinch flats).
In engineering, it can be tough to run really proper tests. There are usually limiting factors that make it hard or impractical to fully duplicate the way that the device gets used by the customer, so simplifications are made. The hard part is figuring out how close the test is to reality, and how useful the test results will be. If you have the time and money, you run the fully realistic test and you run the simplified test, and compare results. Other times, the realistic test would take 5 years or longer and the product would be obsolete by the time the test was finished, so you just do the best you can.
For bike tires, it seems like the plan was to run a reasonably decent test on the steel drums, and only change if the customers complain loudly.
Steve in Peoria
#93
Reduced weight - less rotating mass on the largest diameter "flywheel" - and there are two on every bicycle.
The reduced weight comes from 1. No need for 4 steel hoops in the tires and their inertia 2. No need for 4 flanges on the rims and their inertia 3. The tires tended toward the thin and light end of the spectrum.
#94
Bikes: I have a few
Quoted: 340 Post(s)
Liked 209 Times
And they come in skin-wall. . . Please tell how they work out !
#95
Quoted: 786 Post(s)
Liked 517 Times
Why tubulars? Because this:
https://twitter.com/Milano_Sanremo/s...20152217993216
#96
Baloney on that part above, but I agree with the rest of his post.
You don't peel off both sides of the tape; you mount one side of the tape to the rim, keeping the plastic between the tire and the tape. Then you stretch-mount the tire, and can move it and center it and twist it into spaghetti if you want, but it's not stuck to the rim at all. Once you have it centered and right, valve lined up perfectly, etc, you inflate it a bit more, then slowly pull the remaining plastic film off. It comes out just fine. Even then you can adjust it.
A sixth grader can do it in 10 minutes. No set of problems, no mess, no time wasted. No tubasti on your khakis.
Re: that pic of the tire that needs a LOT of stretching. Keep at it. That looks like a real mo-fo, and I'm not sure why. What the other guy said works pretty well. You need to be able to stretch along the entire circumference of the tire, it appears, to gain the elasticity you need. And I'm done with the big words.
You are also very correct that a sixth grader can do it. Only verified sixth grader I knew who glued the old way would have been George Noyes, who grew up to be a somewhat famous team wrench. Have known several boy racers who got tired of waiting for Dad and picked up the glue tube. Wasn't keeping track of whether they were in 6, or 7, or 8. My little brother began gluing when in 8th grade, don't recall he asked for any help or instructions, just grabbed my glue tube and did it. My own gluing began when I purchased my first lightweight bike summer between 9th and 10th grade and it was Tubulars Not Glued. It was a 15 mile ride home and no bikes on the train. They handed me a tube of glue. I went outside, sat down on the sidewalk, and glued. Maybe 30 seconds of verbal instructions. They were nice enough to come out and offer me a rag and some mineral spirits when I was done and to check my work. But no help. If you can't glue 'em you shouldn't ride 'em. Oh yeah, this is all with red glue, now extinct, and much messier than any current glue. Not harder, way way messier.
Didn't know her yet, my wife picked up gluing at about same age. Guy who volunteered to help her didn't know how either. They got it done and it worked. It has always been real simple. No one wants to believe it is simple.
Glue tubes are very specifically sized to glue one pair of tires. Usually if you don't waste it on stupid mistakes there's a bit left over after two tires. That extra dries out before you get to the next tire. If you want to use a whole tube on one tire you could, won't hurt anything, just some extra mess. If you are building up six layers of glue, may God help you, I can't.
#97
Clement Scatto? Antiques for display only. Boulder cautions against use.
Vittoria CX from Taiwan? Caveat emptor. Sure it was a Vittoria at all? They possibly could have had some made in ROC but not likely.
Challenge Vulcano? Vulcano has been a label used on bottom end exploding tires for as long as I can remember. It's in the name.
Continental tubies below Sonderklasse are odd ducks, more Conti than tubular.
Tufos are plain odd ducks however you look at it.
Vittoria Rally is low end. Have seen them recently at Merlin @ 2 for $20. Rideable but don't expect much.
If you automatically gravitate towards flukes and freaks you won't have good experiences.
#98
Quoted: 4792 Post(s)
Liked 3,918 Times
How long was I asleep this time? Ten years or thirty? That newfangled tape you describe seems to be pretty well established. And that system should work. Still wildly overpriced, not necessary, and Not Traditional. It should work. And sell.
As posted above, I was a Tubasti fan for all but my race wheels. I'd use plenty in the early days of a new rim. Once I had a good base, I put a rather thin layer on. Being Tubasti, I could always reliably pull the tires off for a road change, but they were well stuck. And the spare would be well stuck when I got home. (I never "pre-glued" a spare. Never carried glue. My spares were usually old repaired tires but sometimes new. Figured it was a toss. New and tight. Old and had seen glue before. All worked. Never cleaned rims. Just check to make sure the buildup was solidly on and lumps were manageable.
I had to come here to find out how hard life was with sewups. I never knew.
Ben
#99
Bikes: 2005 Seven Odonata (DuraAce /Reynolds),1983 Trek 950 (Mavic/Suntour/Regina), 1986 Stumpjumper Shimano/Suntour/Regina), 1986 MASI 3V, (Campy/Mavic/Regina) 1995 Schwinn LeTour (Suntour/Wienmann/Phil/Shimano/Regina): All Brooks Saddles
Quoted: 25 Post(s)
Tubulars
Ok ,
I know one point tubulars were the only way to go , but as clinchers have improved significantly over time there seems to be no point to running them. I've been told they had a good ride, but they are messy, complicated and not as easy to change as a clincher . They also seem to be very expensive, so please can someone tell me why anyone still uses them other than they like being very old school?
#100
Until very recent years glue failure stories came in two flavors. First was like yours, tape didn't work. The other was red glue left alone for more than a year - or maybe three - got dried out, cracked, let go. Referees here used to do occasional starting line glue check, Carl Wilkins told me he could tell by the color of the edges when glue was too old. Since they flatted in rather less than three years dried out glue didn't happen that much. Otherwise it always worked and no way to screw it up.
