For the love of English 3 speeds...
Location: Southport, North Carolina, USA & Pevensey, East Sussex, UK
Bikes: 1)1992 Trek 970, 2)2010 Trek 6500, 3)1973 Colnago Super, 4)1955 Freddie Grubb Meteor. 5)1993 Airborne Ti-Hag Titanium. 6)1936 BSA 602DX Roadster. 7)1957 Philips P2 Sports. 8)1955 Dayton Roadmaster. 9)1948 Humber Clubman. 10) 1949 Sunbeam WA3 Wayfarer
Quoted: 157 Post(s)
Liked 85 Times
Raleigh Superb for Auction in UK - Watsons Auctions
This is not for me as I now have too many bikes but looks to potentially be a bargain as bikes usually sell quite cheaply here:-
Web Address: https://www.watsonsauctioneers.co.uk...p?lot_id=59350
Quoted: 1854 Post(s)
Liked 661 Times
For me, I think it depends on the originality of the bike in question, if the bike is fairly complete with original parts it seems a shame to turn it into something else when it is perfectly restorable and when you think about it people did those long & touring rides on them back in the day. On the other hand if there really is not much re-usable other than the frame, then building what you describe is perfectly legitimate and at least the frame survives. If you are having to climb serious hills then I can understand the need for a granny gear and there are sprung chain tensioners I have seen on eBay by Cyclo and I am sure I have seen one by Campagnolo but they are not common.
I have recently restored a Freddie Grubb Road Bike from 1955 but there were no usable original parts on it so basically it was just a frame, so I rebuilt it with full Campagnolo parts from late 50's to late 60's so it is not how a 1955 bicycle would have looked but at least I can ride it and enjoy using it. I saved it from the scrap heap. Conversely I am soon to restore a 1948 Humber Clubman and I am going to great lengths to bring it back to 'as new' original condition as it has almost all original restorable parts. I am only venturing how I see it and I am sure others may view it differently to me. Hope this helps.
I'd love to get the Cyclo parts, but I think they attach to a braze-on (two small bolt holes) under the chainstay that this frame does not have. Or were there some that used a claw?
Quoted: 1299 Post(s)
Liked 103 Times
Inflate Hard
Inflate Hard
Phyllo-buster
Quoted: 2295 Post(s)
Liked 2,045 Times
There is a Cyclo clamp-on rear derailleur for the 3 speed versions. I think it's the Standard model. Looking for online pics but can't find one. I'll keep looking
Bikes: 1983 Trek 600, 1972 Raleigh Sports Step Thru, 1963 Rudge Sports, 2007 Dahon MuP8, Dahon Speed, Public Mixte 8-speed IGH, mid-70s Peugeot Mixte AW conversion, Riv Platypus
Quoted: 350 Post(s)
Liked 24 Times
I was in a bike shop a while back and was asking about cotter pins.
The owner said:
"Why bother? We just cut the cranks off and replace with a cartridge..."
I stopped in yesterday (I do like the guy) to see if
he had a source for Westwood rims and he just said
"No, you can't get them."
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
I have a complete NIB Cyclo Benelux conversion kit that does not require the stay bolts. I'll post a pic and I could be persuaded to part with it.
Liked 661 Times
Quoted: 350 Post(s)
Liked 24 Times
Yes, I have found some fine riding there. The issue is the public transit situation, which is not great. Did I say not great? It is mostly abysmal. Metro North to Poughkeepsie, or to Middletown/Otisville/Port Jervis is good and I use those routes frequently. But it should be possible (it was a long time ago) to reach that New Paltz/kingston/Saugerties axis by train. And Amtrak for points north of Poughkeepsie on the east side of the river--don't get me started; Hudson is a great base for day rides but the round trip by train is $120! And Amtrak doesn't allow full size bikes on this route; I use the foldcycle but it's still annoying they're not willing to put up a few bike hooks, or would be except Amtrak is always between a rock and a hard place in everything. The bus is way less than half the price, but it's nearly three hours one way to Saugerties.
Liked 2,446 Times
Here you go. Note the claw mount. Cogs are 15-17-24.
Quoted: 157 Post(s)
Liked 85 Times
For the Grubb, how did you handle the chainset? On mine, I had extraordinary difficulty with the drive side cotter pin, and I do not want that again. That's why I'm thinkiing of a Cyclotourist. Does the Grubb have a Raleigh-threaded BB?
Normally I have never had a problem with Cotterpins one just has to be careful and not force the issue as that usually ends in disaster. Others have written many posts on Cotterpin removal. With a bike restoration I like to take everything apart even reluctant parts so I know I can get them apart again in the future. I have just finished restoring a 1936 BSA and I had no trouble removing the cotter-pins even though I doubt they had ever been removed before.
Cyclo Gear Changers did attach via a bracket that formed part of the frame but I am sure they also has a bracketed version. The other route you could go is to convert your 3 Speed to a dual sprocket and use say a Cyclo Benelux Mark 7 changer which uses the optional bracket clamp via the wheel nut as also does Campagnolo. I have never done this conversion through others in this thread I think have done.
Here are some modern chain Tensioners that are readily available and I am sure there are many others out there chain Reaction and Tredz also supply them, Hope this all helps:-
Quoted: 157 Post(s)
Liked 85 Times
Quoted: 350 Post(s)
Liked 24 Times
What I look for are project bikes. Something that needs work to be useful again. Each project is like a puzzle. Each has it's own possibilities and limitations. There are 3 paths you can take. Preservation, restoration and customization. Usually it ends up being a combination of two or even all three of these.
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 439 Times
Liked 439 Times
I plan on using as many original parts on the '30 Hercules.
The wheels are the main issue.
For example, if I were to find a good
DL-1 donor bike I'd have no problem
swapping out the wheels and making it a 3 speed.
I'll repaint the bike but don't have the skills to pinstripe
and I'm too cheap to pay someone else...
I can however, reproduce the decals.
Liked 439 Times
the wheel would cost me $56.00 CDN
taxes and duty @ $16.60
Shipping ?
So probably $100.00 in total
which is really not a lot these days.
Liked 439 Times
The bike shop owner in A Boy, A Girl, and a Bike is no prize but your fellow, unless he was kidding around, sounds rather horrifying to me. Shops all have that big book of parts; even if he doesn't want to stock something like cotter pins, what's his excuse for not offering a special order? If you need the best quality you have to get them from Bikesmith, but any shop can order the mass produced ones. Bike Shop Mike here has been in the business for close to 40 years and although he's not sentimental he understands the appeal of bikes from long ago. He owns two Land Sharks and still, last summer, he restored a late 70s Fuji Newest for his own use and if he runs across it will jump on just the right PX10.
I bet if he opened up that supply catalogue he'd find something....
He did bring up a pair of old wheels from the basement..
They were too rough for me and I said I'd pass.
He then replied that they're not for sale anyway..
Go figure.
Quoted: 157 Post(s)
Liked 85 Times
They do supply Westwood Rims only both 32 and 40 hole versions, they will quote you shipping international if you can't find one anywhere else. I did post the link in my original post. Hope that helps.
Bikes: 1951 Sun Wasp, 1953 Armstrong Consort, 1975 Raleigh Competition, 1980 Apollo Gran Sport, 1988 Schwinn Voyageur, Mystery MTB
Quoted: 359 Post(s)
Liked 457 Times
Derelict Raleigh Sports
Well folks I managed to get my hands on an old derelict 1979 Raleigh Sports step through. It is a Canadian made model from what I understand about the white painted seat tube. The hub is dated August '79. I plan to use the brake parts on my 1950 Superbe after I clean them up, a long with the various clips (especially the chain guard clips). Have a look see. I will practice hub rebuilds with the AW from this bike. The wheels are shot.
Bikes: 1965 Dilecta Le Blanc, 1956 Royal Nord, 1972 Raleigh Sports, 1972 CCM Turismo,1976 SuperCycle Excalibur, 2014 Salsa Vaya, 2017 Felt DD70, 2019 Giant Lafree and others
Quoted: 351 Post(s)
Liked 588 Times
We are what we reflect. We are the changes that we bring to this world. Ride often. -Geo.-
Liked 439 Times
The time and money spent hunting down a few clips etc can really add up.
Amazon.ca examples
Indicator chain @ $53.00 + shipping
https://www.amazon.ca/Sturmey-Archer...ateway&sr=8-39
Axle key (indicator screws into) @ $53.00 + shipping
https://www.amazon.ca/Sturmey-Archer...ateway&sr=8-56
Here's another axle key @ $138.00!!!!!!
https://www.amazon.ca/Sturmey-Archer...ateway&sr=8-82
I'm sure no one in their right mind would order these but.....
Senior member
Quoted: 942 Post(s)
Liked 656 Times
Port Dover has more palm trees than Odessa.
Phyllo-buster
Liked 2,045 Times
Interesting about the serial number. My R20 has NDxxxxxxxx so I guess it was made in England then exported to Canada?
Ive been calling it a Canadian model.
Quoted: 350 Post(s)
Liked 24 Times
Senior member
Quoted: 942 Post(s)
Liked 656 Times
