A Universal Question
Fat Guy on a Little Bike
Bikes: Two wheeled ones
Quoted: 1254 Post(s)
Liked 345 Times
I've seen them twice...braze on Universal center pull calipers. I saw them once on a Marastoni that I was outbid on, and once in CDM's garage. Does anyone know if these had a unique model number? How hens tooth are they? For reasons I won't immediately share, I'd like to source a pair.
Quoted: 1136 Post(s)
Liked 650 Times
There's always a possibility they were converted from regular center-mount calipers. People do this regularly with MAFAC and Dia Compe centerpulls.
If they are factory that would intrigue me as well...
Half way there
Quoted: 986 Post(s)
Liked 879 Times
I've seen these many years ago, though my memory is vague.. I'm not sure that they were conversions back then, though. Rather the frames were intentionally designed with bosses to fit. Sort of a precursor to cantilevers.
Quoted: 7346 Post(s)
Liked 2,452 Times
I've read that brakes like those work great. I've always been more than happy with regular MAFAC brakes and wonder how much better they can get.
Quoted: 821 Post(s)
Liked 255 Times
I didn't have that bike very long, but I recollect we used modded Kool Stop pads.
There was a clearance issue on the front with fenders, so we cut them down to 2/3rds length.
My buddy that refreshed the bike switched them to Compass centerpulls.
Not sure why, but probably because they were shiny and new.
I don't know that the Compass brakeset was an upgrade.
I'll try to get some pics and I'll add them to the thread down the road.
Likes For gomango:
Quoted: 3803 Post(s)
Liked 3,324 Times
Fratelli Pietra information online in English is limited.
Possible there may be detailed discussion of this on one or more of the Italian fora.
Another place to check would be the CR email list.
Perhaps @MauriceMoss will have some helpful information...
Likes For juvela:
Liked 650 Times
Any centerpull brakes utilizing the braze-on studs, regardless if Universal, MAFAC, Dia Compe, etc... require a specific mounting stud placement on the fork and frame, above the wheel. The studs are shorter and a different diameter than cantilever studs (except when using Paul centerpulls, which use standard cantilever studs). When I said "conversion" above, I mean replacing the hardware at the pivots in the brake calipers such that they can fit and pivot around braze-on studs instead of pivoting independently from the frame (as they do when mounted via one central bolt). I didn't mean converting a frame/fork.
Braze-on centerpulls were a popular option on custom and semi-custom frame in France for many decades, and even some production frames, such as Meral and I believe a couple of high-end Peugeot bikes built under contract by smaller builders. They generally use MAFAC brakes, though. I haven't seen Universal centerpulls being used, but I'm sure it's possible with the right pivot hardware.
Likes For TenGrainBread:
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
I think you need to immediately share why you'd like to source a pair.
Likes For Hudson308:
Bikes: 1987 Centurion Ironman Master, 1992 Koga Miyata Exerciser, 1992 Schwinn Crosscut
Quoted: 209 Post(s)
Liked 175 Times
I continue to be amazed...
How the heck do you guys KNOW SO MUCH???
Liked 345 Times
Well, I just make stuff up. It works with clients, and usually the IRS.
If it happens, it's a long ways down the road.
Liked 3,324 Times
Sidenote -
Once one gets seven decades back, and beyond, it is possible to encounter both centrepulls and cantilevers whose pivot posts are clamp-ons.
Sidenote -
Likes For juvela:
Likes For KonAaron Snake:
Liked 2,452 Times
I've learned a lot here.
Liked 3,324 Times
Quoted: 4722 Post(s)
Liked 3,036 Times
Like TenGrainBread, I suspect these were converted from standard centre-pull models. Brazed-on (aka direct mount) centre-pull brakes, while relatively rare, eliminate the weight and flex of the brake bridge. The latter increases both braking power and modulation. The downside is the added cost of the brazing operation for studs. One can argue the quantitative benefits but it is the nth degree type of detail that appealed to constructeurs and their high end clients.
Typically, when a company manufacturers a direct mount component, they also supply the brazed-on fitting to guarantee compatibility. This is why companies like Campagnolo and Shimano offered dropouts and shift lever bosses. Consequently, if a company offered direct mount brakes, you would expect to see matching bosses and this is the case when you look at the cantilevers in a MAFAC catalogue. Dia-Compe catalogues show brazed-on fittings for both their cantilever and centre-pull models (see scan) but the entries for the centre-pull brakes makes no specific mention of direct mount versions. This suggests that Dia-Compe considered demand for direct mount centre-pull brakes to be so small that they were either non-catalogued special orders or manufacturer conversions. Often, with niche products, it's less expensive for large volume manufacturers to offer a standard product than change the manufacturing, packaging and logistics process.
I have seen relatively few Universal catalogues but none that I have seen include direct mount fittings or brakes, either cantilever or centre-pull.
As an aside, I distinctively remember seeing my first direct mount centre-pull brakes, as it made such as impression on me. They were Dia-Compe on a 1976 Centurion Pro Tour.
It's also worth noting the current trend towards direct mount dual pivot brakes as an option to disc brakes, though the forks and stays use recessed threaded fittings, as opposed to protruding studs, as recessed fittings are more appropriate for carbon fibre frames.
Likes For T-Mar:
Liked 345 Times
Great post T-mar, and thank you.
I have to admit I'm curious about direct mount dual pivots, but, at the same time, I like going dual front, single rear for the mix of power and modulation. I've never used a dual pivot brake and wished it had more stopping power, so I'm wondering if this is a solution to a problem that doesn't exist.
I (briefly) owned one of those Centurions, but never really rode it. Stunning bike though.
IF I do start looking at this project, I'm still leaning direct mount center pull.
Liked 2,452 Times
You will find that dual pivots stop with slightly less effort than center pulls, but the difference is small for a strong person like you. Maybe you got a bad sample from dual pivots, because they really are excellent. And I remember Campagnolo's rationale for having a single pivot in the back, but I think it's silly. These brakes are not hard to control. Not that it's a bad setup, either, it's just not necessary or even optimal.
Each choice represents some kind of compromise.
Liked 345 Times
I have the campy dual/single combo...and I think they're onto something with it. I have AMPLE stopping power, and I like it's ability to flutter as well.
Quoted: 500 Post(s)
Liked 466 Times
After Gugificazione mods to the fork of the 1979 Miyata 912, I now have a braze-on centerpull front (so that I could use a front rack, bag, etc.) and bolt-on dual pivot (RX100 in this case) in back. Pads on both ends are Kool Stop salmons. Brake feel/lever travel with Campy/Sachs Ergo levers is good for both brakes. Since this photo, I’ve switched to Kool Stop Cyclocross Linear pads for a better fit against the 23mm wide rim. Works great!
Not sure if Universal 61’s would fit the same pivots, but I was also able to fit MAFAC Racers on the posts that’s @gugie used. I prefer the quieter operation and easier setup of the Dia-Compe (also lighter). Brake feel seems a bit nicer with DC.
Insane Bicycle Mechanic
Quoted: 797 Post(s)
Liked 694 Times
Developed my mental muscles lifting Schwinn Varsities onto shop racks.
The real reason: I lived through the '80's and '90's, a chaotic time for the bicycle business. Now I'm older than dirt and freely share my hard-won knowledge.
Jeff Wills
Jeff Wills
