Need help with identifying the use of this tool.
Enock
It is as blue Park Tool spanner tool number SPA-3. I can not figure out what it is used for. The only thing I can find even mentioning it is this blog but it doesnt offer much explanation and it's a strange tool because the pins point in toward eachother. https://fernandoj.wordpress.com/2013...-do-with-them/
Likes For enock111:
Bikes: 68 SS, 72 Fuji Finest, 72 PX-10, 77 Pana Pro 7000, 84 Pinnarello Treviso NR, 84 Trek 520, 88 Project KOM, 90 Trek 750, 91 Trek 930
Quoted: 184 Post(s)
Liked 204 Times
I have the set of early 90's Park pin spanners (4 or 5) and that is one I have never used.
Likes For dmark:
Really Old Senior Member
It fits "some" lock rings.
Found with a 10 second search.
Quoted: 1572 Post(s)
Liked 643 Times
It's a solution in search of a problem.
If having it around bothers you, throw it away. Next week you'll figure out what it's for.
Likes For Retro Grouch:
Its not a use specific tool, from back in the day when tools were multifunctional. You chose a tool because it did what you needed it to do for that particular task at that particular time. I've got a full set of those Park tools in one of the drawers of my tool cabinet. If I've used it it was because it did what I needed done. Need a suggestion? It'd work great as a temporary tension clamp to hold bar wrap as you stop midway to do something else. Slide it on and the unsecured wrap won't unravel.
Quoted: 3375 Post(s)
Liked 5,513 Times
LOL!!!
This is a tool I needed for a job once:
But it was expensive, and I needed two of them to get the job done.
So I used some steel rod to make a second tool, but with a simpler design:
The job was assembling/disassembling the headset of a Kawasaki 650 Versys.
Only the factory tool is needed to loosen the locknut.
But when reassembling, you need a 2nd tool to just hold the lower locknut while using the factory tool to tighten the upper one.
Enock
Liked 5,513 Times
BTW Another oddity when I was working on that motorcycle:
I have the Park headset tools, and discovered to my delight that the largest components in the headset bearing installation kit, were the correct size to install the bearings on the Kawasaki's triple clamp.
Enock
I also like that you say "I see a trend where you expect us to be "Mr. Answer Man". I mean after all isn't bicycle maintenance a hobby and suppose to be fun? Also isnt the purpose of the forum to ask questions and find a "Mr. Answer Man" to things a 10 second search might not find. Nobody is forcing you to use this forum bud or to answer my thread so if you don't have any real knowledge of the subject please keep to yourself and I will gladly accept my spot on your ignore list if I means I don't get your responses.
Quoted: 836 Post(s)
Liked 1,061 Times
Used for this type of lockring. I've found this tool to be near useless for tight lockrings on BB's but as Shimagnolo noted in in post #9 it works great for setting the tension on motorcycle headset bearings.
Likes For Crankycrank:
Since you asked so nice. Direct from the pages of Park Tool Catalogue (no date). It is part of a set of Pin Spanners SPA 1-6
SPA-1 Green - Fits adjusting cone on most 3 piece cranks
SPA-2 Red - Fits adjusting cone on most gear clusters
SPA-3 Blue - Fits lock ring on most 3 piece cranks (This is what you show)
SPA-4 Yellow - Fits adjusting cone on most 1 piece cranks
SPA-5 - Set of above
SPA-6 - Shop quality adjustable pin spanner
The one you posted in another thread is half of a Frame and Fork End Alignment Gauge Set FFG-1. I have the other half.
Likes For coupster:
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Likes For JohnDThompson:
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
Tried searching for those with no result.... what would you call them beside lockring pliers
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
Old fart
Liked 3,400 Times
https://www.amazon.com/HOZAN-C-203-H.../dp/B003LBSLUG
Or, you can make your own from a set of slip-jaw pliers:
https://www.instructables.com/id/DIY-Lockring-Pliers/
Enock
I have the FFG-1 tool and have used it but had no idea that part came with it. Thanks for all the help!
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
