Is DT swiss hub grease Molykote TP-42 with just colouring?
Is DT swiss rear hub ratchet grease Molykote TP-42 with just colouring?
the DT hub grease was sooooo expensive
like $25 for just 20g
so I went searching for same substance and I saw this unconfirmed claim on somewhere
Quoted: 1188 Post(s)
Liked 1,154 Times
You have to use DT grease or otherwise your hub will asplode.
Anyway a quick LMGTFY says right there it's TP-42 with extra oil added... https://www.bikebug.com/dt-swiss-spe...-p-107685.html
Likes For Trevtassie:
Thank you!
I did a google search too but just wanted to make sure. thank you for heads up that I missed.
Quoted: 836 Post(s)
Liked 1,061 Times
There is probably nothing special about the DT grease but getting the correct viscosity is the most important part. I'm the type of person who hates buying overpriced special bike lubes that are no different than what I can get for a tenth the price at the auto parts store and willing to spend a couple hours of net searching to find a proper substitute to save a few bucks. But $15 will get you the DT stuff that will last, probably a couple decades of use so not all that bad. https://www.ebay.com/itm/DT-Swiss-St...4383.l4275.c10 Just a matter of how much is your time worth really.
Likes For Crankycrank:
https://www.motionindustries.com/pro...yABEgKqdPD_BwE
I see nothing wrong with using any high quality grease. I use this on my hubs and freehub bodies https://www.totallybelted.com/Lubrip...dge-p1203.html
Likes For davidad:
Likes For jimincalif:
A few years ago, I got some standard grease, mixed in some 3 in 1 oil drop by drop till the viscosity looked good (ie a wee bit runnier than standard grease) and been using in my 240 hubs ever since. Never missed engaging even in sub freezing temps and reasonably quiet too.
Quoted: 836 Post(s)
Liked 1,061 Times
I've actually done the grease/oil mixing thing too. Works fine, sort of a roll your own viscosity!
