Tire pressure guess with Frame pump only.
Quoted: 9 Post(s)
Should I even be worried about exceeding the advised PSI limit on my tires with a simple frame pump?
It's a decent lezyne pump, and I pump the tires until it gets pretty hard to put more air through it.
It works fine and with 25mm tires, smooth roads and 78kg bodyweight, I want them pretty hard.
So my question is, is it easy to exceed the pressure with a hand pump?
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
I have a Bontrager floor pump and put 100psi in the 25mm tire. I think the max on the tires is 120psi. When I get past 90psi a single pump only puts a few psi in so there's no way to accidentally hit 120psi.
Likes For GlennR:
Quoted: 2604 Post(s)
Liked 1,933 Times
Never say never; for all I know you're an NFL linebacker who'll stop for 20 seconds between pumping to rest and recuperate.
But I agree, it's unlikely you'll exceed 120 psi with an ordinary frame pump. You'll probably get tired or bored before you blow the tire up.
Likes For pdlamb:
Quoted: 283 Post(s)
Liked 262 Times
Pump it up to where you want with your floor pump. Now pinch your tire with your thumb and forefinger. Do it again tomorrow. Now you know what it feels like, and you won’t exceed that with your hand pump.
Likes For grizzly59:
with a frame pump, you'd need to be a gorilla to put in 120 psi in a 25mm tire, but even before that, he pump will probably break at 90 psi
Ever tried to hold a 120lb dumbell with just 2 fingers? that's the sort of effort it'll take at 120 psi
Likes For aclinjury:
Quoted: 18376 Post(s)
Liked 4,512 Times
It might take you a few hours pumping, but you should be able to get a decent amount of pressure with your air shock pump. Most are rated at about 300 psi.
Of course, most should have a gauge when new.
Likes For CliffordK:
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
From flat count the number of strokes. I’m the opposite. I NEED 110 psi rear and 100 psi front otherwise I will pinch flat.
Lezyne Long.
Front 205
Rear 230
but I’d did buy the hose with a gauge and use presto to Scheader adapter.
Lezyne Long.
Front 205
Rear 230
Likes For biker128pedal:
Quoted: 1062 Post(s)
Liked 665 Times
One of my habits is to make a mental note of how much my tires pooch out under my weight. That's my gauge when I'm out on the road. In practical terms, my arm strength and/or the compression ratio of the pump are likely to limit the ultimate pressure that I reach. On larger tires, boredom.
Likes For Gresp15C:
Quoted: 550 Post(s)
Liked 325 Times
Silca frame pumps use a 3/4" piston totaling 0.439 square inches which would require 53 pounds of force to achieve 120 psi.
Other frame pumps made for road bikes are similar.
Likes For Drew Eckhardt:
Pump your tyre up until it compresses by 15% under your weight, for instance I have found that my 25c tyre needs around 85psi on my rear and 80psi on my front with my weight of 79kg. But without a gauge on my hand pump I just pump it up then sit on the bike and if it compresses too much I just add more air. I only know the psi because I have a track pump at home where I usually inflate my tyres.
Likes For sledgefisher:
Lopsided biped
Bikes: 2017 Day 6 Cyclone (the Buick); 2015 Simcoe Deluxe (the Xebec); Street Strider 3i (the not-a-bike); GreenSpeed Anura (the Black Swan)
Quoted: 316 Post(s)
Liked 160 Times
You could get one of these ...
https://cyclingspares.com/bicycle-pu...-9-9cm-silver/
It only delivers about a teaspoon of air at a stroke. Your arm will fall off before you can overinflate the tire.
Likes For rollagain:
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Can’t tell from your posts if your only pump is the frame pump. If you don’t have another pump with a gauge or a separate gauge, then you are just guessing at tire pressure.
Likes For JanMM:
Full size frame pumps work fine at 90 psi, which is achievable using cyclist's little T-rex arms.
Hardly.
Hardly.
Quoted: 550 Post(s)
Liked 325 Times
That's just theory. Real world is different. My Lezyne handpump says "160 psi". Yet, when I pump a tire until I can no longer pump due to arm pump, it was 80 psi when I got home and measure the pressure with a guage. Nobody is pumping their tires to 120 psi with a frame pump, especially not with noodle t-rex arms.
My Blackburn (discontinued, because worthless micropumps are all the rage) gets me to 90 psi with 100 strokes.
With an optimum cycling weight of 136 pounds at 5'10", I have scrawny t-rex arms.
Zefal HPX users report reaching 120 psi easily, although I assume they're large enough to require that.
Likes For Gio800:
Quoted: 643 Post(s)
Liked 1,526 Times
Pump your tires up to within a couple of PSI of normal then put your frame pump on and see how much effort is needed to get any more air into it. This will give you a reference for when you have to pump it up out on the road. Having fixed a fair number of flats with a mini pump, I find that overfilling is about the last thing I expect to happen.
Likes For Ogsarg:
Quoted: 630 Post(s)
Liked 369 Times
You could also get one of these and monitor your pressure. Or use a bluetooth pump?
https://www.sram.com/en/quarq/models/wh-trwz-a1
On Your Left
Liked 2,433 Times
My wife has valve caps that came on her Specalized Roll that have a pressure indicator, green=OK and red=low.
I can tell you that yesterday I was on a ride and after a few miles realized I didn't pump up my tires before leaving. I have latex tubes and they tend to drop 10psi even over night. I normally ride 90/100 and the back felt sluggish, squishy and bouncy. I decided to continue on and visit the LBS not far away and top up.
How we did it back then..
Learn what the proper inflation pressure feel like, floor pump with a gauge,
then when you have to top it up on the road, you will know what adequate feels like..
Bikes: 1984 Fuji Club, Suntour ARX; 2013 Lynskey Peloton, mostly 105 with Ultegra rear derailleur, Enve 2.0 fork; 2020 Masi Giramondo 700c, full Deore with TRP dual piston mech disk brakes
Quoted: 324 Post(s)
Liked 81 Times
You can buy a small cheap little PSI gauge from Topeak, it fits in my saddle bag.
I also use and like the Lezyne pump, but since you have one of those you can get a inline pen hose gauge from Lezyne, which I don't think will be all the accurate since it's a ball float type of gauge, anyway you remove your old hose and replace it with the new one. I prefer the separate gauge because I transfer between several bikes, while one is the Lezyne, the 2nd one is a Topeak and the other is a Zefal frame pump, none of which have gauges so having one gauge I move around fits me the best.
Lopsided biped
Quoted: 316 Post(s)
Liked 160 Times
Quoted: 4560 Post(s)
Liked 2,802 Times
I have a mini pump with a gauge. More trouble than it's worth. It's a nice looking, well made "Pro Bike Tools" mini pump. But it's the least functional of my four mini pumps, by far the most difficult to pump. And it tends to either shut the Presta valve or unscrew the entire core.
My Topeak RaceRockets and Blackburn Core Slim are far better mini pumps. No gauge but it doesn't matter. I just pump until it's ridiculously difficult -- around 200-300 strokes -- then ride. It's usually around 60-90 psi, depending on the tire and pump. Good enough to finish a ride.
Quoted: 324 Post(s)
Liked 81 Times
This site tested a bunch of pumps and will tell you how many strokes it took to get to a specifc PSI: https://cyclingtips.com/2019/08/the-...ike-45-tested/
