F8 set screw
Bikes: Tcr advanced sl & Protos
Quoted: 116 Post(s)
Liked 60 Times
F8 set screw
Does anyone know the size of the set screws for the seatpost? Shop rounded one out using a hex instead of torx.
Thanks
Thanks
Quoted: 6193 Post(s)
Liked 4,808 Times
I guess you are asking about the Pinarello? Since the other F8 should be another forum. Doesn't the shop know how to call and find out?
You should chide them for not having the right tool for the task.
Likes For Iride01:
I don't suppose you could measure them, like at a home depot or something? Pinarello appears to ship both 5mm and 6mm screws, according to eBay.
Likes For upthywazzoo:
Quoted: 116 Post(s)
Liked 60 Times
The guy that built it used a torx. The guy that fitted me jammed a hex in there before I knew it was a torx. Though I was suspicious remembering reading something like that.
Quoted: 116 Post(s)
Liked 60 Times
That’s why I was hoping I could find some. I did see the eBay ones and they were like 30$. I know spend x$ on a bike and...
still 30$ foe set screws isn’t cool
Liked 4,808 Times
$30.00 for a set screw? You must have been desperate not to look elsewhere. Fastenal stores are all around and supply many of the local industries with screws, bolts and other fasteners. Also many cities and areas that have had manufacturing industry for longer than I've been alive will have a fastener (bolts, screws, etc) supplier somewhere in the industrial park that will be even cheaper than Fastenal.
I've even had such suppliers just give me the single screw, bolt, o-ring or other small part simply because they didn't want to waste time entering an invoice.
Quoted: 116 Post(s)
Liked 60 Times
I’d like to find the correct ones in torx. Though, I guess it shouldn’t matter.
Do you know the size of the stock pinarello ones?
thanks
Quoted: 1067 Post(s)
Liked 259 Times
Measure one.
Set screws are specified by their diameter x length. e.g. M5 x 12.
You will also need to specify if you want a regular socket screw (hex) or torx.
Likes For Dean V:
