1030 or 1030 plus
Quoted: 77 Post(s)
Liked 26 Times
1030 or 1030 plus
Now that the plus model is out, the 1030 is on sale for $400 off. Some of the new or fixed features of the plus will soon come to the 1030. Should I purchase the 1030? The only things holding me back, I think, is 1) the touchscreen on the plus is apparently much better, 2) the 1030 tech is pretty old at this point, and I suppose there will be a 1040 or whatever not too long.
I don't have a GPS computer at the moment and have been tempted to get one. At $400, the 1030 is only $40 more than the 830.
Quoted: 4245 Post(s)
Liked 1,351 Times
Garmin just released the 1030+. You won’t see a 1040 anytime soon.
The bigger screen of the 1030 is useful for navigation.
The 830 should be a good unit too (like the 1030).
The touchscreen on the 1030 seems fine.
Likes For njkayaker:
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
1030 regular. A year old Garmin has had most of its teething problems at this point.
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
If you get a 1030 watch for the Halo around the screen if it is old stock with older screen. Garmin will replace under Warranty. It can show up after a few months.
Likes For biker128pedal:
Quoted: 3230 Post(s)
Liked 2,079 Times
Any links to a dealer selling at that price ?
FWIW, the Plus is very slightly faster in operation, I’ve heard it can load a navigable course a big quicker. Touch screen is supposed to be that same as the 830 and less sensitive to rain and sweat. I’ve never had issues with either. Battery life is increased from 20 to 24 hrs. The improvements to to OS are supposed to roll out to the 1030 late in the year.
My 2 years on the 1030, after replacing the first unit I received, is a rock solid unit. Maybe twice per year I need to re-configure the BT connections, takes about 5 minutes. Still get 20 hrs of use, to never crapped, LiveTrack connects about 80% of the time, everything else, including navigation, works well. It’s a good deal at $400.
Quoted: 77 Post(s)
Liked 26 Times
$400 “off” would put a normally $599 unit at $199. I think you meant to type “$400”, or about $200 off ?.
Liked 2,079 Times
Liked 1,351 Times
Even still, my 1030 worked just fine on a ride this morning.
For a good deal on a 1030, it should be easy enough to live without the phone stuff for a bit.
Not true. You don't need a phone/connectivity to set it up. I've set them up multiple times without it. (Garmin might lead you to use the phone but it's still not necessary). One of the benefits of the Garmin (over units like the Wahoos) is that they don't need a phone to be useful.
Quoted: 680 Post(s)
Liked 947 Times
The phone related stuff doesn't work.
Liked 1,351 Times
No, it’s not more work. Certainly, not a lot. You don’t need the phone.
The set-up is like 5 questions about language, sex, weight, and age. Not that hard to do with buttons.
Anyway, the 1030 The OP is talking about has a touch screen.
