16 front 24 rear via 32 hole set
Bikes: 2000 Litespeed Appalachian, 1998 Litespeed BlueRidge.. 1977? Schwinn LeTour 12.2 'Rain Daze'
Quoted: 64 Post(s)
Liked 17 Times
Riding the rain day bike recently a noticed a rear wheel wobble....... Set from in an inbound bike.. Bontragers ... typical low NDS tensions. So.. with a good used set of $5 yard sale Alex 450's with 'hano hubs in the rafters the 'adjust-ment' was on. NDS tension was taken off.. 1x lacing heads in using 8 spokes.. ala the triplet concept. Tensioned to 25 'Park' right and 24 'Park' left gave a nice round tight rim.. albeit ONE spoke just a tad longish bottoming out. Out it came.. musta been a replacement being a tad longish. The box didn't contain a blk of a size workable... so.. there WAS this new set of SAPIM STRONG the right length... of RAD-ial lacing. I advocate 1x heads in on STRONG24's 16-8 lacings.. but... who needs all that tension in a triplet? Not many.
So the STRONG went on radial heads in... adjusting the final tension to 105 right and 95 left.. very uniform and ROUND... kgf's. Paired 3 design with the open hole. A triplet minus the expense... and high tension NOT required of a triplet.
Butttt.. the front didn't match now. So.. half of those came out... this one set 24.5 'Park' with the again 14 g spokes from this former 'build'. Very round and evenly tightened.. note the skip two routine heads again IN.. with each mate supporting the other at the 'slack sequence' of the wheel rotation. 16 of'm now carrying these 200 lbs...
This rain bike has utility rubber.. 60's psi. Tires and riding style means lots in wheels.. I be fine on these. And at less than ten bucks.. if I count the cost of the STRONG's just laying in the spoke box.
My MAIN consternation: is the 14mm rim width of these 490 gr 450's........ so out of line with the rage today to WIDE rims....
Quoted: 4212 Post(s)
Liked 3,883 Times
Sometimes it's not worth the effort to try to understand what's being said. This forum doesn't have a size limit, it's Ok to use complete sentences and grammar. Sorry but I'm off to work. Andy.
Quoted: 303 Post(s)
Liked 136 Times
Good luck with that effort to save on spokes and wheel truing time. Helps to have a very rigid rim to start with in adventures like this.
Quoted: 5888 Post(s)
Liked 3,472 Times
Quoted: 2026 Post(s)
Liked 1,096 Times
Reads like it was written by James Joyce or Hunter Thompson.
Quoted: 64 Post(s)
Liked 17 Times
Constant tinkerer
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
Meanwhile, you're the one asking for help (I think)...
Today, I believe my jurisdiction ends here...
Quoted: 18382 Post(s)
Liked 4,513 Times
I think Bike Friday typically uses 36 hole hubs and 24 hole rims on many of their builds.
You could probably use fewer nipples than holes in the rim too, but the nipple holes are often angled to one side or the other, so keep that in mind.
Bikes: 1993 Fat Chance Wicked Lite, 1997 Spooky Mothership, Litespeed Obed, 1996 Cannondale R900, 1995 Diamondback Vertex. Note: None of my bikes are original spec. All are custom build ups.
To be honest, I'm not sure I understand if this post is a question or a boast post about the wheel the OP posted pictures of.
Of course you should express your individuality in the way you see fit but when trying to get other people to comment on your post, it would help if it was a little less stylized and was easier to understand. There are plenty of people who could and would comment on this if it wasn't such a chore to decipher the meaning and intent. Frankly, I think the only fan of the rambling shorthand masquerading as a comment is the box fan in the second picture.
Nevertheless, good luck with your wheel and I hope it holds strong and true.
Quoted: 64 Post(s)
Liked 17 Times
Follow up.. I mean.. how many do such.
The 16H front performed flawlessly.. I road it wrong across tracks etc... never a whimper. 150 miles.. yes a small sample... the rim/s needed another project. Review that pic again.. in this configuration the elbows restrict the movement of the partner J bend.. nearly the effect of straight pull spokes. The 'under spoke' in the pairing did not require a washer to get the alignment I want of the bend coming out of the hole. Again the build tension wayyy higher than I normally use on fronts.. 115 kgf... very uniform.
I did loosen one spoke all the way down disassebly.. just to see how much deflection the rim would go... simulating a break riding. Yes more than the 32H scenario but surprisingly not enough I believe to cause major issue getting stopped in a breakage situation. I mean they all rub after a break.
Rear.. is just the Campy G3 design.. nice wheel design.. stronger and more durable than a 32... IF your not one of the top 10% riders for power. I am in the process now of doing a G3 in 27H... 18-9.
These older Alex 450's.. this set with eyelets... NICE ribs. Around 480 grams... are great finds in the used market.
Bikes: Drag Grizzly, Raleigh Pioneer Venture GT
Is it my vodka or is it really hard to decipher the intent of this thread? It really does look a bit like boasting to me, but I can't tell. If it is, congrats on truing that wheel.
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
I also am unwilling to put in more effort to understand the OP than he puts in to be understood, but the overall concept has merit. Removing a few grams from the most highly strained structural elements of a bike, without the aid of any structural analysis tools seems like a great idea.
Quoted: 64 Post(s)
Liked 17 Times
About... the all heads in lacing.. how that technique gives BOTH bends support. And.. testing the limits of spoke counts. Well made.. road with a drop of think.. less works well. Just testing... learning a few things. NOT recommending this lacing.. would I ride it cross country at 200 lbs? No... it'd handle it but there's no reason to skimp of a few when the chips are down.
'All heads in'.. >> left side rears at 1x .. does well using butted lasers.
As noted earlier.. the Alex 450's I have built are nice rims... strong and finish with very uniform tension. Cheap and practical... easy tensioning.
NO fudge on dish.. the G3 design being triplet.. no need to cheat over for tension left side rear. The Shimano FH used finished at 90% tension + left side vs right rear... using heads in left.
