Changing tires from 26x2.125 on a 36H rim, how narrow?
If you have a large tire and a small tire and they both deform the same percent, then the volume of rubber undergoing hysteresis is larger in the large tire. Same shape change, greater size.
Calamari Marionette Ph.D
This brings us full circle so I'll quote myself.
We both know we are not going to ride the small tire all mushy (massive rolling resistance) at 60psi, and we wouldn't ride the big tire inflated to (unnecessary) granite status. Where does that leave us? If we determined the perfect desired amount of energy required to roll the tire and defined it as "rolling resistance X", we would be able to achieve that with either tire by fine tuning pressure, but ultimately the large tire would require less. The result is the same rolling resistance, but better ride quality with the large tire. That's why I say that for noncompetetive cruising applications, nobody will notice a speed difference, but they will notice a bump absorbing difference.
I can't say I remember the exact number, but 14.83 MPH is stuck in my head for some reason as the threshold over which greater tire width started to suck up energy due to air drag. So folks interested recreational speedy riding would certainly benifit from narrow tires, and that's what I'd recommend.
Why would anyone do that in the real world though? A 50mm tire will achieve ~15% deformation at a much lower pressure than a 35mm. And that's the whole point. The 35mm MUST be inflated to a harder state in order to offer the same deformation/rolling resistance as the 50mm.
The narrower tire can withstand a greater percentage of deformation than the wider tire to have the same rolling resistance. it will have the same rolling resistance at 20 or 25% as the wide one will at 15%
It will probably still be at a higher PSI.
The ride just doesn't get that bad with a narrow tire at high PSI because it can deform easier than a wide one at high pressure, especially over lengthwise cracks or bumps.
If the tire is larger and deforms the same percent, it is deforming more rubber.
Liked 5 Times
Hey Squidley.... I'd throw in the towel on this one. He's right; skinnier 26"s will make your bike lightning-quick. From what I understand, GSGT regularly wins Cat 1 races on his cruiser, rolling 35mm Kojaks.
Oh, and when I say Cat 1, I'm serious. And the cat is usually arthritic or weak sighted, or both. But I smoke him more often than he beats me.
Liked 5 Times
The skates roll pretty good, but I'm thinking I might switch from 62mm to 650b, if they'll clear the skates' undercarriage. I think the larger diameter will be tremendously helpful offroad-- I use my skates for road races and XC as well.
I think a Fuji Cape May has 25mm wide rims. How much do you weigh? Perhaps look here.
hekuk
General Cycling Discussion
9
10-31-14 07:36 AM
haplorrhine
Bicycle Mechanics
9
10-25-12 10:28 AM
