Carry extra tire?
Uber Goober
Speaking of spares...and spare frames...
Consider:
Spare shift cable (buy tandem-length, and it'll fit regular single bike or tandem or recumbent)
Spare pump/inflator
Spare spoke or two (Fiberfix, for example)
Patch kit and spare patch kit- and rotate them, the glue will dry out even if the tube's never been opened.
Quick-links to fit your chain
Chain tool
Spare cleat and spare cleat screws
That's all pretty small stuff. I've had the broken pump, dried patch kit, broken chain problems. I've seen the broken shift cable, broken spokes, and broken cleat or missing screw problems.
Consider:
Spare pump/inflator
Chain tool
just another gosling
Quoted: 3885 Post(s)
Liked 1,938 Times
Consider:
Spare pump/inflator
Chain tool
Consider:
Spare pump/inflator
Chain tool
Results matter
Results matter
Randomhead
Liked 3,687 Times
I carry a spare tube for 25mm tires because people that use that size seem to need them more often and they are weight weenies, so they only have one tube. Silly, I know, but I was riding with someone that had a double flat and I felt bad I didn't have a tube to give them. I have given one away so far. But no, I'm not carrying a spare 25mm tire
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
RUSA #7498
Originally Posted by noglider
Yes. I carry a spare tire. Sometimes brand new, sometimes slightly worn.
I've had a couple of occasions to use it myself ... and I've bailed out fellow randonneurs.
Slightly OT: After spending FAR too much time trying to find the cause of a mystery flat on a 200km,
I've started carrying rim tape. And it has seen some use.
Cyril
Cyril
Fixed Gear Randonneur
A cult within a cult
Bikes: FM098-V2, '16 Synapse
Quoted: 81 Post(s)
For 400k and up in remote areas, I use a Topeak Tri-Backup Tirebag. It's made for a tubular but takes a clincher, two tubes, and tools. And, a decent-sized pump on the outside.
Folding technique: push one half into the other; repeat a few times; wrap in cling film.
EDIT: a worn 25c GP4000sII.
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
I've been known to carry a spare tire, especially if I'm planning to ride solo for extended periods of time. I have a GP4000SII that's in decent shape but has a few thousand miles on it; it's folded up and ready to go in my box of bike stuff.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
I'm somewhat curious about the popularity of various wheel sizes on randonnees. I'm sure 700c is the most popular size, probably followed by 650b, but after that I'm not sure at all. I've used other 26" sizes (650a and 559) but I can't recall seeing anyone else using those. Recumbents often have one or the other 20" sizes. Someone might still be on 27" tires, but I rather doubt it.
What would that be statistically? 700c over 80%, 650b over 15%, maybe? Has anyone seen quantified studies?
Anyway, apropos this thread, people using 700c tires can pretty safely assume there's another rider with a spare tire, and 650b riders can make that assumption a little less confidently. Anyone else better carry a spare.
Quoted: 1216 Post(s)
Liked 183 Times
Bicycle Quarterly has some stats from PBP a while ago but they indicated tire width and not wheel size.
https://postrestant.co.uk/wp-content/...quipsurvey.pdf
I’d be shocked if 650b was more than 5%, that wheel size seems to have taken off everywhere except for actual randonneurs riding brevets.
Randomhead
Liked 3,687 Times
I don't think you are going to find a spare 650b tire on a randonnee. I wouldn't count on it anyway. I ordered some 38mm 650b tires by mistake, I intend to use one of them as a spare for the 44mm tires I'm using on the bike.
Quoted: 4792 Post(s)
Liked 3,918 Times
Ben (who brings home all his new wired Paselas in his panniers)
Quoted: 5888 Post(s)
Liked 3,471 Times
I've ridden with other folks who pack an extra tire for long brevets. And I did ruin some crusty old Panaracers on my second RAGBRAI -- I was fortunate that there are bike shop tents in most towns on that ride and I was able to find a couple more 700x25C tires for cheap.
But for most of my riding, I rely on my generally good luck with tires and tubes, rather than packing extra tires. Now watch me ruin both of my Compass tires on the commute home, now that I've jinxed myself.
Liked 2,563 Times
Maybe I like to live on the edge! I did ride a 650A bike on PBP 2015 -- wonder if I was the only one to do that, and if any bike shops in all of France would have that size in stock.
multimodal commuter
Liked 574 Times
Oh, they have those in France, don't they? I thought it was common across Europe, certainly anywhere where a Raleigh could be bought (i.e. anywhere).
Liked 2,563 Times
I guess I don't actually know. I figured 650A wouldn't have gotten as much of a foothold in France, between 650B in the early years, and 700C after that.
Randomhead
Liked 3,687 Times
during PBP, you're probably stuck for tires or wheels if you don't have a 700c bike. I know two people that had wheels replaced in 2011, and I thought about it. Main thing that stopped me (other than the fact that I was still rolling) was the amount of time the control bike shops take to do a job like that. Couple of hours to replace a wheel.
Quoted: 112 Post(s)
Liked 25 Times
I don't carry an extra tire on any of the brevets (even 1000k). I have had cuts on the sidewall and tread which are the worst because the patch keeps rubbing on the ground and fails. I have used bills for the sidewall that hold up, but get worn after a few klm if used on the tread. I have used the Park tool tire patch that didn't fair much better on the tread. The best solution I have found for cuts on the tread is a piece of juice carton (tetrapack). They hold up much better than the Park tool tire patch or a bill. Last year I completed a 200k brevet with the carton patch in the cut tread for 100k. I carry pre-cut pieces on all my rides whether training or Brevets.
Bikes: Trek Domane 4.5, Trek 1500
Quoted: 20 Post(s)
I carry a spare tire for the double centuries I ride in California (the California Triple Crown series) . that is partially because I dont want to drive all that way over to the ride, and DNF because of a sliced tire.
Liked 2,563 Times
Kamen Rider
Bikes: Fuji Transonic Elite, Marechal Soul Ultimate, Dahon Dash Altena
Quoted: 351 Post(s)
Liked 277 Times
I brought a spare tire for my 600k brevet, but not for last week's 400k -- bike loadout was different, I didn't have enough space unless I carried my larger seat packs which only happens if I need to bring extra change of clothes (i.e. 600k and above).
But on last weekend's 400k, one of the riders I was with had a cut in the sidewall right in front of me. I heard the pop, saw a large stone fly away, and her front tire was instantly flat. We still managed to patch the tire and continue... but I guess in those instances a spare tire would have been a lot better. Although I have to comment, I see a lot of people ride these Continental GP4000 tires with weak sidewalls on brevets (ok, not sure about where you guys ride, just commenting on my own region and experiences). Why ride those racing tires on long distance brevets? I get that they are extremely popular due to supposed durability (I haven't seen it -- I keep seeing people flatting with them in both brevets and sportives/races) and great rolling resistance (can't argue about that one)... but personally I'd rather minimize flats than have to deal with them. Especially on brevets where night riding in remote regions is a thing...
Quoted: 3455 Post(s)
Liked 1,454 Times
About a week ago I suddenly realized that I had a big bulge in the front tire on one of my bikes. Based on tread depth, that tire had been used for less than half of its lifespan. Fortunately I was home at the time, that tire was changed within an hour of seeing the bulge. I suspect I hit a bump too hard and tore some of the fabric in it.
Bikes: Rodriguez Adventure Touring, Rodriguez Tandem, Trek Mtn Bike
I wouldn’t think a tire would be needed. Something (like a dollar bill) might do in a pinch.
Randomhead
Liked 3,687 Times
not only that, say you have 100+ miles still to go in the dark in the rain. Do you really want some kind of lash-up tire hack keeping you from a face-plant? Sure, if you're 20 miles from home or it's the only way to avoid ubering, but a tire is a much better solution.
