Licenses for E-Bikes?
#101
Quoted: 761 Post(s)
Thanks. You're clearly and informed and educated rider.
I'm sure yourself and other people in this forum will not get into trouble on an e-bike. But I started this thread to focus on the many people who are the opposite of you. People who arent educated about ebikes or riding in general but still ride them.
Maybe a fruitful discussion would be on what could be on the license test? And who would need to take the test?
You get to pick the number... IF, you have an E-Assist, with a pressure sensor in the crank or the axel. If you don't then you get the % of assist that the motor puts out on whatever level you have it set to and your input is not considered in any way except for having to rotate the crank, (rotation sensor) you don't actually need to put any "pressure" onto the pedals . Then there is the throttle, you don't even have to pretend to pedal...
On my set up I have 4 levels, level 1=35%, level 2=75%, level 3=150%, level 4=300%, what that means is... When I put in lets say 1lbs or 10lbs of pressure onto the pedals, I will get...
Level 1; 1lbs=0.35lbs of assistance, 10lbs=3.5lbs of assistance up to a max of 6.6lbs of assistance.
Level 2; 1lbs=0.75lbs of assistance, 10lbs=7.5lbs of assistance up to a max of (cant find the number)
Level 3; 1lbs=1.50lbs of assistance, 10lbs=15.0lbs of assistance up to a max of (can't find the number)
Level 4; 1lbs=3.00lbs of assistance, 10lbs=29.5lbs of assistance as that is the max assistance number. I would not get the 30.0lbs...
ALL levels; I MUST put pressure onto pedals to go anywhere... Just like a bicycle... Whenever I ride and am going faster than 32Km/Hr, I am the only motivating force on my bicycle.
Depending on the "type of E-Bike" some of them have so much rotation resistance from the motor that you can't really even pedal them on your own, even when you want to or need to if the battery runs out... On my set up I can, and do, ride my E-Assist bike as a regular bicycle whenever I want...
#102
#103
Just a person on bike
Bikes: 2015 Trek 1.1, 2021 Specialized Roubaix, 2022 Tern HSD S+
Quoted: 132 Post(s)
Liked 86 Times
People for Bikes, which is an industry funded group, is pushing model legislation across the U.S. It defines three classes of e-bikes. Class 1 is a pedal assist up to 20 MPH, Class 2 is throttle up to 20 MPH, and Class 3 is pedal assist to 28 MPH. It clarifies they are to be treated as bicycles and can use all bike infrastructure, on and off street.
People for Bikes
People for Bikes
The value of your life doesn't change based on the way you travel. - Dawn Schellenberg (SDOT)
#104
Quoted: 761 Post(s)
Interesting Article about Dutch E-bikes
https://www.treehugger.com/bikes/87-...years-old.html
Not surprisingly, they are seeing the effects of e-bikes before the US.
Surprisingly, they limit motors to 250w and they top out at 15.5mph.
#105
Quoted: 132 Post(s)
Liked 86 Times
#106
#107
Quoted: 132 Post(s)
Liked 86 Times
and.. we should learn from that... Here in N America. I, said 350 watts 20MPH and no throttle, with 7 year's of experience riding an "E-Bike"... and they, they say 250 watts 15.5MPH... With a whole lot more experience then I, They, recognise that regulating the manufacturer, not the operator, is the way to go, for keeping an E-Bike a bicycle...
#108
That is 100% true... BUT, what IS, a bicycle... When you start to compete it with cars... The bicycle will loose 100% of the time, unless you are very consciously WANT to ride a bicycle, with a bit of assist, not a moped...
#109
Quoted: 132 Post(s)
Liked 86 Times
I understand what you're saying. To me, it's not so much about competing with cars as about being comfortable riding with cars. I feel comfortable riding at 15-20 mph among cars (i.e. while taking the full lane).
#110
EDIT; there are now 4,000 watt +, E-Bikes out there to buy, and they are actually "legal " because all you needs do is .. flip a switch and it cuts the power down to 750 watts and cuts the power out at 28MPH when you are on a public road... Now, how is that a bicycle..??? I am 100% sure you can't buy one of those in the Netherlands... Legally I mean...
#111
Quoted: 132 Post(s)
Liked 86 Times
and, there in lies the overall "fail" eventually of the "E-Bike" as it has been set up here in the N American continent... It has morphed into, A MOPED, in a word, and the same thing will befall it (E-Bikes) as with the MOPED, eventually, things catch up in the regulatory system and... MOPEDS are now licenced/insured vehicles, their reign as a "pretend bicycles" has ended. ... Why not keep the assist low enough, and slow enough, to run "under" the radar so to speak... as was originally INTENDED... sales,.. and more sales... I suspect...
#112
I think it depends on the environment in which to ride e-bikes, too. In the Netherlands, where people typically ride at an average speed of 12 mph (or less) in safely segregated bike infrastructure, a limit of 15.5 mph will be sufficiently fast. Here, OTOH, people often have to ride faster (15+ mph) in order to ride safely (i.e. not necessarily to compete against cars), which would make a higher power assist limit of, say, 20 mph more adequate. And we're talking about bikes with power assist, which cuts off at the governed speed. For that reason, I can see how Class-3 e-bikes (power assist up to 28 mph) can make the line between bikes and mopeds blurry.
#113
and.. I can see the difference between me pedalling at lets say 250Watts, going all out, and the difference riding a horse at 750Watts doing nothing but staying in the saddle... NOT, the same thing... a vehicle is a vehicle above a certain speed, (meaning a powered vehicle)… Horse powered or human powered is totally different. The main reason this E-bike thing got started was to get more people onto bicycles with a (little bit of help)... NOT MOPEDS... as it seems to have ended up, even tho today they still look like bicycles. IMO. Powered vehicle should need a license, assisted vehicles should NOT... You know, like wheel chairs...
The reason we have E-bike is to satisfy our growing insatiable craze for lethargy. Now we have E-bikes? So what are gears for?
#114
Cycleway town
Seems to me that this topic was created by someone who doesn't ride an e-bike, or even a bike at all. It's interesting to see the comments though, again, mostly by people who have no e-bike experience.
I'd like to put a point in, here; e-bikes are typically slower than regular bikes.
There's absolutely nothing exceptional about a bicycle doing 20mph (e-bikes are limited to 15.5 here in the UK and EU - including the vinyards of France). So the argument that more people are going out and actively learning how to survive life is flawed.
I recon i'd done more than 20mph by the time i was 7yo on my first geared bike.
What do we licence next, rock climbing shoes?
#115
#116
Quoted: 2495 Post(s)
Liked 739 Times
Several older and very recent posts keep repeating how it is necessary to have a 20mph top assisted speed for 'keeping up with cars', 'taking the lane' and nonsense like that. 20mph is an easily attainable speed for a motor car in 1st gear, and it is ludicrous to imagine a bicycle is safely riding among traffic at that speed. A bicycle needs time to get to 20mph, a car does not. Few bikes are assisted in any case, I haven't seen one in months, and few cyclists are capable of maintaining 20mph for more than 5 or 10 minutes at a time. Lets get real. Bicycles cannot ride IN traffic safely and most do not. They can ride alongside traffic more or less safely and when doing so do not need to maintain the prevailing traffic speed which in any case is 25mph, in most cities, and 30, 35, 40 and higher on the big arterials some of which are legal for bicycle use. Just a reality check. Carry on.
#117
You'd need to maintain at least a constant 30 mph to ride safely in traffic. Personally, I would never ride in traffic because motorist quickly adapt to the expectation of you being able to keep up. Not recognizing that unlike their vehicle, a human being's capacity to maintain that speed quickly declines with time and distance. Especially at the rate of energy expenditure (90-100%) needed to achieve and maintain that speed.
#118
If this were the case, i.e. all three classes treated the same as unpowered bicycles, then there would be no need to distinguish the three classes. If you look at their proposed legislation, they recommend that by default Class 1&2 are allowed on bike paths and MUPs while Class 3 is not although in both cases the local authorities can pass ordinances reversing the default position. They also propose that Class 3 have a minimum age requirement and a MHL.
#119
Bikes: 36" Unicycle, winter knock-around hybrid bike
Quoted: 930 Post(s)
Liked 393 Times
Electric motorcycles are no more "bicycles" than fuel ones of comparable performance, and we require registration for those.
This is important, but it's mostly a factor of political will and putting them under a transportation department rather than a parks one. Key issues are things like open hours (especially in the winter when it's dark during most commutes), maintenance, snow clearance, etc.
greenways... because I want them to be part of the transportation system and not just an amenity.
#120
Liked 739 Times
#121
Liked 739 Times
Most passenger sedans have top speeds ~120 mph on level ground. This is partly a byproduct of the excess potential that is left over from the requirement that said vehicle be able to lift its weight plus payload over 6% gradients at a reasonable rate of speed. Even on the Interstate what percent of road users exploit that potential at any one time? What about in town? What percent of urban drivers regularly exceed even 55mph in residential areas? I will agree that it is necessary to limit bicycles to 20mph top assisted speeds when passenger sedans have electronic limiters that prevent them from exceeding posted speeds in urban or residential areas. When we are trying to beat a stale green light to the yellow on our morning commute me and mine can easily get our tandem to 25mph in a few seconds and hold that speed long enough to do plenty of damage to pedestrians or other cyclists or private property. But we do not. Because we aren't crazy or possessed of a death wish. Why do people imagine that because an e-assisted bike can reach a speed of 28 mph, that its rider will, at the first opportunity, ram it into an 85 y.o. pedestrian at speed, killing him instantly? Why do people imagine that requiring the cyclist to have a license will prevent this? Does the requirement for licenses prevent motorists from ... from the things they do?
#122
Quoted: 761 Post(s)
Another two articles
These two are about e-scooters, but I think the comments are justified for e-bike rentals as well. The companies just want to make money and are renting these things out to anyone. Interestingly e-scooters are capped at 15mph.
The first article https://www.cnn.com/2018/08/16/opini...vox/index.html is by a doctor. His point is that many people are riding these who don't have the skills/experience and are really hurting themselves. There is an interesting note by a user who broke her arm. Apparently her car insurance and health insurance refused to pay her bills.
The second one you need to register (but not pay) to see https://www.law.com/therecorder/2018...perfect-storm/ It's interesting because it talks about lawsuits by individuals hit by e-scooters and how cities foot the injury bill.
#123
Bikes are 100% human powered. Anything beyond that (with a motor/engine) is something different and should be categorized as such.
#124
Liked 739 Times
License aren't designed to make you a perfect rider/driver. Rather, their purpose is insure that you understand the basics of safely operating these machines, know your responsibilities, and if necessary, to have a way to track and penalize any individuals that violates or ignore those safety standards.
#125
So explain how that will apply to e-bikes. Written tests? Road tests? Really? How many cars are tracked by their licenses after a wreck? Admit it. No one has really thought this through. Just a knee jerk reaction to what looks like some people getting away with something.
You had to go to one of the main hubs and take the test where they gave you a pass that needed to be displayed and if necessary submitted to security offices for inspection.
