Happy about my worn out tire
Quoted: 1814 Post(s)
Liked 923 Times
Not sure the mileage as I swap wheels, but these are used winter & bad conditions.
Anyway- worn to the cords, no flats.
Likes For woodcraft:
Quoted: 4717 Post(s)
Liked 1,882 Times
That never happens in AZ. Some tires are obviously better than others, but the Phoenix area has so many thorns that every tire will puncture, after they are worn thin.
Farmer tan
I've got a stockpile of half used tires.
Flats are inconvenient at best, dangerous at worst, so I'd rather just change them early.
Likes For f4rrest:
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
Once and only once did a tire last long enough til the "wear dimples" were worn down to.
Most get cut from road debris that they never make it that far.
Kit doesn't match
Yep, it's mostly thorns, compounded by the fact that it has not rained for months and months, so the things accumulate... I tell ya, it's a minefield out there
Quoted: 6252 Post(s)
Liked 4,853 Times
Aw, com'on. Why didn't you keep doing "let's see if it'll last one more ride" thing? Weren't you curious how much longer it would go?
Quoted: 20810 Post(s)
Liked 9,456 Times
The tire that I just changed looked like that, but I run tubeless, so that's like cheating.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,571 Times
Nicely done, @woodcraft. It's been a while since I've worn a tire close to the cords. Now that I'm practically always on tires wider than 38mm, it seems that the tires always succumb to some other fate before I can properly wear them out.
Liked 923 Times
I may still push it a bit, but didn't want to on the previous weeks' long, solo, unfamiliar ride.
Edit- no, I did ride it then, but didn't this weeks long group ride.
Liked 1,882 Times
I'm not doubting your word, but it's my first experience with them, and I could use a measuring stick.
Liked 9,456 Times
Liked 9,456 Times
Likes For WhyFi:
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
The tires shown in this thread are way past their useful life. They should have been changed long before they got to the point where the cords are showing.
You will notice small threads or fibers poking through the rubber before the tire gets worn to the point where the cords show. When you see the fibers, its time to change the tire.
-Tim-
-Tim-
Liked 9,456 Times
-Tim-
-Tim-
- Soli Deo Gloria -
Liked 736 Times
Vittoria Rubino G+ Speed will be fine when leaving the house and four hours later there will be a two inch patch of cord showing.
So yeah, you are right.
-Tim-
Liked 9,456 Times
Likes For WhyFi:
shaken, not stirred.
Bikes: I've lost count.
Quoted: 1413 Post(s)
Liked 975 Times
You must have less abrasive roads/paths then.
vBulletin: snafu
Liked 9,456 Times
I'm fatterer. And yeah, these tires were on for the fall and spring, so lots of grit.
