Too much pressure on QR on new carbon frame, cracks...
Hello everyone, I’m really freaking out, I bought my first carbon road bike some weeks ago, and when I removed the back wheel today, I found thad the frame was a little bit worned out and probably delaminated on the inside of the handle (I can put a very thin paper sheet on one of them)
I think I put WAY too much pressure on the QR…
What could I do ? Is it safe enough to put some epoxy in the cracks on the inside of the drops ?
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
going to need pics I think for a reasonable diagnosis. Never heard of this happening so I would also check with the shop if the bike is new might be a mfg defect.
You didn't say what bike......very curious.
Likes For sdmc530:
It's an "Origine" bike, it's a french company.
Here is a picture of the part where there is cracks on the inside of the drops : hostpic.xyz/images/2020/11/11/original_2bf5c0af-ddf4-4583-9422-0a2308dfc2ab_20201111_0158031.jpg
Quoted: 1439 Post(s)
Liked 1,094 Times
From the way the paint goes around the edges I wonder if the original bond might have been less than perfect, especially if both sides have similar appearance. I think that someone knowledgeable who can put hands and eyes on the frame should be consulted.
Quoted: 7069 Post(s)
Liked 11,144 Times
I don't think you did that with the qr skewer, and I also don't think it's a problem. But if you are worried, take it into the shop (where you bought it) and have them look it over.
Bikes: 89 Paramount OS 84 Fuji Touring Series III New! 2013 Focus Izalco Ergoride
Quoted: 286 Post(s)
Liked 74 Times
No expert, but to me a non-issue. It looks like it dug through the paint a little, which I don't think is uncommon.
scott s.
scott s.
Likes For 02Giant:
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
I too would have the shop look at it. My carbon frame has marks but nothing that bad, but the paint coming off in that area is a normal thing. have an expert look at it but probably just the frame layup and it is what it is?
Likes For sdmc530:
Not a newbie to cycling
Bikes: Omnium Cargo Ti with Rohloff, Bullitt Milk Plus, Dahon Smooth Hound
Quoted: 356 Post(s)
Liked 323 Times
It only looks like thick paint being scrubbed off. Have you tried hitting it with a screwdriver or some such. If there is delamination, it will not sound as "taut" as a solid piece of CF. It will then sound more like a "thud" rather than "thonk" (yes, that's the closest I can come in writing).
Likes For CargoDane:
Quoted: 252 Post(s)
Liked 67 Times
Aren't those end pieces made of some alloy, which is then inserted into carbon stays some distance away from where the QR attaches?
I believe my bike didn't have the paint where the QR grips or where the axle rests in the end-piece. It was covered before paint was applied.
You probably look at the 'crack' like depression, I think that's a flaw in casting that end-piece which they spray painted over but I'd say, nothing to worry about. In any case, like in comments above, I don't believe you did that with QR. For piece of mind, you can have the shop look at it.
Likes For vane171:
Quoted: 6284 Post(s)
Liked 4,873 Times
It's likely nothing. Don't do any "fixing" of it yourself. Wait until you hear back from whomever you bought the bike from and whomever manufactured it. Let us know what they said.
Likes For Iride01:
Likes For maxotru:
