1Up Rack Hitch Pin Won't Engage With Lock
Old 09-03-20, 12:11 PM
GAtkins
Bikes: 2021 Trek Domane SLR7 Project One 62cm- 2010 Specialized Allez 61cm
Quoted: 93 Post(s)
Liked 70 Times in 37 Posts
All,
I can't get my 1Up hitch pin to engage with the inside of the lock mechanism. The pic below shows as far as it will go in before bottoming out on the internal female threads.
Of course the male screw thread is rectangular as well as the portion you can see right where it inters the lock. I think the non-threaded rectangular portion of the screw is supposed to go all the way in past the lip in the female side so that it can then be turned to engage the internal threads.
Seems that the pin bottoms out on the internal thread before the rectangular piece clears the opening in the lock.
The wheel locks have the same problem.
Any ideas?
Thanks much.
Glenn
GAtkins is offline
Old 09-03-20, 01:01 PM
dedhed
SE Wis
dedhed's Avatar
Quoted: 1474 Post(s)
Liked 967 Times in 657 Posts
https://www.1up-usa.com/services/#14...-e70d5c49-b88c
dedhed is online now
Old 09-03-20, 01:05 PM
GAtkins
Quoted: 93 Post(s)
That's awesome. I've already called and emailed them to no avail. I didn't see anything in your link related to my specific issue, but thanks for playing.
Glenn
GAtkins is offline
Old 09-03-20, 01:25 PM
MikeEckhaus
Quoted: 20 Post(s)
Liked 3 Times in 2 Posts
Seems strange that they all have the same problem. Stupid question, and please don't be mad at me for suggesting it, but have you made sure the key was turned counterclockwise all the way before inserting the male end? I know, it's like asking if the computer is actually on when you call Apple tech support, but I was just trying to think of what could cause all of them to have the same problem. Do they physically work and just not look right, or do they not work? IIRC, they do draw in a little as you are tightening the threads with the key. Also, I'm not totally sure they go all the way in when engaged. My 1up locks are at home, so I can see what mine look like when engaged later tonight.
MikeEckhaus is offline
Old 09-03-20, 01:48 PM
GAtkins
Quoted: 93 Post(s)
Well, it turns out that the computer was off. Gawd! That worked. Thank you. That is the single-most counter intuitive situation I have encountered in a very long time - tightening a bolt with a key - unreal.
Either that wasn't in the instructions or I missed it (more likely). I can't tell you how much I appreciate your help. Is it safe to use the rack with just the Security Hitch Bolt screwed in with the Security wrench? It seems so, but then again, I'm not sure. Again, many thanks.
Glenn
GAtkins is offline
Old 09-03-20, 02:29 PM
MikeEckhaus
Quoted: 20 Post(s)
Glad it worked out. Free fixes are the best kind. On your security bolt/wrench question, I assume you mean the hex key/Allen wrench that fits into the end of the hitch and tightens the rack to the hitch? If so, yes, it's totally safe. Everything beyond that is just insurance. Just make sure it's tight. The keyed hitch lock isn't for attaching the hitch, it's just to keep someone from stealing it. Enjoy!
Old 09-03-20, 02:31 PM
GAtkins
Quoted: 93 Post(s)
OK, that's what I thought but wanted to make sure. Thanks again.
Glenn
GAtkins is offline
Old 09-03-20, 02:52 PM
August West
August West's Avatar
Bikes: Domane SLR7 Project One. Fuel EX 8 GX
Quoted: 148 Post(s)
Liked 160 Times in 97 Posts
Glenn
I'd make sure to attached the safety strap to the hitch also. It will keep the rack from detaching from the hitch and skidding down the road with your bike should the tightening mechanism ever loosen up.
August West is offline
Old 09-03-20, 09:05 PM
Kapusta
Cyclochondriac
Quoted: 1728 Post(s)
Liked 991 Times in 595 Posts
If the OP has the lock that goes through the hitch pin holes, then it will take care of that.
Kapusta is offline
Old 09-04-20, 07:44 AM
GAtkins
Quoted: 93 Post(s)
What safety strap do you use?
Yes I do have the locking hitch pin.
Thanks.
Glenn
GAtkins is offline
Old 09-04-20, 09:01 AM
August West
Quoted: 148 Post(s)
Good point. Mine is one of the original 1 " w/ 2" adapter bolted on so I wan't thinking of the 2" with the through pin.
Old 09-04-20, 09:06 AM
August West
Quoted: 148 Post(s)
Thanks.
Glenn
Then you won't need the strap. Mine is has the 1 " w/ 2" adapter where the locking hitch pin isn't an option. It came with a velcro strap that would keep the rack from sliding out if it came loose. I kind of wish my was the 2" and if I used it more than I do I'd probably upgrade it but since it doesn't get a ton of use I'm just keeping the 1 " + adapter.
Old 09-04-20, 09:10 AM
GAtkins
Quoted: 93 Post(s)
Good to know, thank you.
Glenn
GAtkins is offline
Old 09-04-20, 12:31 PM
Kapusta
Cyclochondriac
I had the 1-1/4 version and upgraded it to 2 by buying the 2 hitch bar with side plates: https://www.1up-usa.com/product/2-hi...h-side-plates/
Kapusta is offline
Old 09-04-20, 01:33 PM
sarhog
Bikes: Canyon Grail, Salsa Cutthroat, Santa Cruz Tallboy
Quoted: 97 Post(s)
Liked 119 Times in 59 Posts
I had to do the opposite. I originally had the 2 version, but I traded my truck for a VW GTI, and I had to go with a 1 1/4 receiver, so I bought the parts from One Up USA to convert the rack to a 1 1/4.
sarhog is offline
Old 09-04-20, 01:38 PM
Kapusta
Cyclochondriac
Well, shoot. We could have just traded.
Kapusta is offline
Likes For Kapusta:
Old 09-04-20, 02:53 PM
BoraxKid
Quoted: 325 Post(s)
Liked 103 Times in 67 Posts
All,
Any ideas?
Thanks much.
Glenn
Those parts all look brand new. If they don't fit together easily, I would suspect a manufacturing defect from shoddy worksmanship. It might be best to return that rack and buy a Thule instead.
BoraxKid is offline
Old 09-04-20, 07:45 PM
Kapusta
Cyclochondriac
Originally Posted by BoraxKid View Post
Those parts all look brand new. If they don't fit together easily, I would suspect a manufacturing defect from shoddy worksmanship..
Nope
Kapusta is offline
Old 09-04-20, 08:15 PM
Rogerogeroge
Bikes: Trek Emonda SLR 9; Moots Routt YBB; Trek Fuel EX8+; LeMond Poprad
Quoted: 114 Post(s)
Liked 79 Times in 48 Posts
That is one of many reasons they are awesome, but sorry that in a way you had to 'downgrade'.
Rogerogeroge is offline
Old 09-04-20, 08:17 PM
Rogerogeroge
Quoted: 114 Post(s)
Really? OP already found the silly solution. Have you ever used a 1Up?
Likes For Rogerogeroge:
Old 09-04-20, 09:50 PM
phughes
phughes's Avatar
Quoted: 535 Post(s)
Liked 413 Times in 248 Posts
Glenn
What a wonderful person you are to be so kind to someone who actually offered help. Wow.
phughes is offline
Old 09-04-20, 11:00 PM
GAtkins
Quoted: 93 Post(s)
Thank you.
Glenn
GAtkins is offline
Old 09-05-20, 01:58 PM
August West
Quoted: 148 Post(s)
Do you still have the 2" hitch and side plates that you want to get rid of?
Old 09-07-20, 07:11 AM
sarhog
Quoted: 97 Post(s)
I do. Are you interested in buying it?
sarhog is offline
Old 09-08-20, 11:23 AM
BoraxKid
Quoted: 325 Post(s)
Haha, yeah I guess I should have read farther down the thread before smashing reply. Operator error strikes again!
Seriously though, IME if something doesn't work when it's brand new, it usually either operator error or a poorly designed product. OP's situation seems to be a product of both, as it is not common at all to use a key to screw something into place. If the 1UP rack were designed better, its operation would have been intuitive for OP and there would have been nothing to post about.
BoraxKid is offline
