Extreme climbing cassete
Old 09-08-20, 12:37 PM
acsoaresbr
Hi there!
I will be facing climbs that are steeper than my legs would allow me to (over 25% gradients) and I was considering to use a 11-34 Ultegra cassete. I have a 11 speed Shimano Ultegra groupset, long cage rear derailleur, 34/50 crankset). However, I noticed the 11-34 cogs are 11-13-15-17-19-21-23-25-27-30-34 - meaning I have a 4t jump to my last gear, which is a bit too much. I looked at my existing 11-32 cassete (cogs: 11-12-13-14-16-18-20-22-25-28-32), and realized mixing them would be ideal. I could potentially end up with a 30-32-34 bigger cogs. However, the last cogs seem to be machined together! So, that is not an option... quite frustrating.
Is there any way to get a 11-speed Shimano compatible cassete that would look something like: 12-14-16-18-20-22-25-28-30-32-34?
Is there any company that build custom cassetes?
Thanks in advance!!
acsoaresbr is offline
Old 09-08-20, 12:44 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Liked 1,302 Times in 817 Posts
Triple crank is your next buy ... Shimano Ultegra had a 130 -74 _ 50 -39- 30, 74bcd will take a 24t..
fietsbob is offline
Likes For fietsbob:
Old 09-08-20, 12:48 PM
trailangel
trailangel's Avatar
Bikes: Schwinn Varsity
Quoted: 1716 Post(s)
Liked 435 Times in 265 Posts
If you are climbing 25% grade you will be in the 34 cog on the rear all the time. Consider 11-36 cassette instead, if you can get it to work.
trailangel is offline
Old 09-08-20, 12:52 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 1249 Post(s)
Liked 439 Times in 343 Posts
I'm not upon 10 & 11 speed stuff, being happy as a clam with my 3X9.
The cheaper 9 speed cassettes don't have the 3 largest cogs mounted on a spider. (Tiagra)
I'm not sure what the lowest 11 speed level is, but you might look there.
I think you'd actually be disappointed at your 6% jump from your lowest gear vs an 18% jump at your highest.
Is there a smaller "small" ring you can install? A couple teeth less there and keep your current cassette would probably give more "balanced" gearing.
Bill Kapaun is offline
Old 09-08-20, 01:00 PM
Iride01
Hits [ENTER] b4 thinking
Iride01's Avatar
Bikes: '20 Tarmac Disc Comp '91 Schwinn Paramount '78 Raleigh Competition GS
Quoted: 2180 Post(s)
Liked 917 Times in 688 Posts
It's not as big as you think. When in the 34 ring the difference in ratio between your 11 and 12 cog is a bigger difference than your 30 and 34 cog.
(34/11) - (34/12) = .26
(34/30) - (34/34) = .13
So actually the change in gearing from that 4 tooth difference is only half the change of a 1 tooth on the small side of your cassette.
You need to figure out how long that section of 25% actually is. If only a few hundred feet, then maybe not so big deal if the rest of the section is only 6% or something less.
Iride01 is online now
Likes For Iride01:
Old 09-08-20, 01:03 PM
fietsbob
Bikes: 8
Issue the carrier for all but the smallest cogs solved, was the cog spline digging a divot in the cassette driver spline
due to the concentrated force of going up hill against gravity , has on the thin edge of the cog interface ..
fietsbob is offline
Old 09-08-20, 01:10 PM
gesta
Quoted: 12 Post(s)
Liked 11 Times in 3 Posts
Is it currently too big of a jump as well?
I think I have 10spd SRAM cassettes where 3 largest cogs are riveted together, but I have never measured if the carrier dimensions are the same for both. If they are, it should be easy enough to mix and match.
gesta is offline
Old 09-08-20, 01:27 PM
GAtkins
Bikes: 2021 Trek Domane SLR7 Project One 62cm- 2010 Specialized Allez 61cm
Quoted: 93 Post(s)
Liked 70 Times in 37 Posts
25% gradients on a 34-34?
Glenn
GAtkins is offline
Old 09-08-20, 01:45 PM
acsoaresbr
Indeed... just found a ZTTO 11-36 which I will consider. Thanks
Old 09-08-20, 01:47 PM
woodcraft
woodcraft's Avatar
Quoted: 1623 Post(s)
Liked 648 Times in 390 Posts
The jump makes no difference when you are only going ~ 4 mph,
and 1:1 is not that extreme- mtn bikes go 1/3 lower.
woodcraft is offline
Likes For woodcraft:
Old 09-08-20, 01:48 PM
acsoaresbr
Got it!
Old 09-08-20, 01:52 PM
blamester
Blamester
Bikes: Peugeot teamline
Quoted: 192 Post(s)
Liked 56 Times in 48 Posts
Buy a single 34 cog and remove one of the smaller cogs you don't want and use the spacer from it. And you can go back to your normal one when you want.
blamester is offline
Old 09-08-20, 02:59 PM
BoraxKid
Quoted: 325 Post(s)
Liked 103 Times in 67 Posts
Hi there!
Thanks in advance!!
Since you already have a long-cage derailleur, and you want an extreme climbing cassette, you might consider installing an 11-40t. This will take your derailleur capacity from 39t to 45t, but a long cage should be able to handle it. You would end up with a ~23 gear-inch low gear, which should guarantee you can sit & spin up a 25% grade. The downside is you'll have a 5t change from your penultimate gear to your lowest gear, but it should feel like a comfortable change at only a 14% difference.
BoraxKid is offline
Old 09-08-20, 04:46 PM
tomato coupe
Quoted: 1036 Post(s)
Liked 1,347 Times in 561 Posts
Funny stuff.
tomato coupe is offline
Likes For tomato coupe:
Old 09-08-20, 05:02 PM
HillRider
Quoted: 1595 Post(s)
Liked 424 Times in 330 Posts
The last generations of both Ultegra and Tiagra triples had the granny chainring bolted to the middle chainring like the old TA cranks. The granny bolt circle was about 92 mm and a 30T chainring is the smallest that will fit.
Shimano's last "true" road triple was the 10-speed 105 FC-5703 that did indeed have 130/74 bolt circles but they have been out of production for several years and finding one is not easy. Shimano still makes "Trekking" triple cranks but they aren't available in the USA, only in Europe, and most European dealers won't ship Shimano or SRAM components to the US.
HillRider is offline
Old 09-08-20, 05:05 PM
kingston
Jedi Master
kingston's Avatar
Bikes: https://stinkston.blogspot.com/p/my-bikes.html
Quoted: 1487 Post(s)
Liked 281 Times in 190 Posts
I just did the calcs. An average sized person on an average bike would have to push about 365 watts to spin at 90 rpm up a 25% grade with a 34/40.
Edit: I mixed up MPH/KPH on the calculations. It's actually ~580 watts. I thought the first one seemed a little low, but they're both too big for me anyway, which must be why I struggle on 25% climbs
kingston is offline
Likes For kingston:
Old 09-08-20, 05:16 PM
BoraxKid
Quoted: 325 Post(s)
Originally Posted by tomato coupe View Post
Funny stuff.
huh? I gave advice on how OP might adjust their drivetrain to better suit their preferred riding style. Everything I said is technically valid. What are you trying to say with your comment?
BoraxKid is offline
Likes For BoraxKid:
Old 09-08-20, 05:18 PM
BoraxKid
Quoted: 325 Post(s)
Can you show your work? How much power would be needed to spin up a 25% grade at 65-70 rpm?
BoraxKid is offline
Old 09-08-20, 05:38 PM
kingston
Jedi Master
kingston's Avatar
I cannot. I just used some online calculators. I also just realized that I mixed up MPH/KPH: It's actually ~580 watts
https://www.bikecalc.com/ to calculate speed at cadence by GI
Bike Calculator to calculate power by grade, speed and weight
About 350
kingston is offline
Old 09-08-20, 05:50 PM
DiabloScott
It's MY mountain
DiabloScott's Avatar
Bikes: Klein, Merckx, Trek
Quoted: 2706 Post(s)
Liked 662 Times in 386 Posts
Word.
The idea that you're going to be in a 32t and save the 34t for a bailout on a 25% grade is just hooey. As is the idea that the 32t is the ideal gear for hills that are only 20% grade.
DiabloScott is offline
Old 09-08-20, 05:54 PM
tomato coupe
There aren't many cyclists who are going to "spin" their way up a 25% grade with that gearing.
Old 09-08-20, 05:56 PM
GAtkins
Quoted: 93 Post(s)
I'd like to see someone spin up 25% with a 34/34.
Glenn
GAtkins is offline
Old 09-08-20, 06:02 PM
tomato coupe
Glenn
You need about 7 W/kg at 80 RPM.
Old 09-08-20, 06:07 PM
BoraxKid
Quoted: 325 Post(s)
How else do you do it then? No matter what gear you're using, you still have to spin the pedals in a circle to make the bike go. Otherwise, I guess you just admit defeat and walk?
BoraxKid is offline
Old 09-08-20, 06:22 PM
trailangel
trailangel's Avatar
You can stand on it instead of spinning.
Likes For trailangel:
