Campy Centaur front derailleur issue
Bikes: 1980's Spectrum 10 sp Campagnolo Centaur, 1990 Eddy Merckx 10 sp Campagnolo Centaur, Bushnell Tandem, Co-Motion Speedster Tandem
Quoted: 185 Post(s)
Liked 102 Times
I put a Campy 10 speed compact group on my mid 90's Eddy Merckx. The frame of course was built before compact gearing so the front derailleur braze on tab seems to be too high on the seat tube for the 50x34 set-up. The bike shifts very poorly and can not seem to get it shifting well. As you can see it doesn't really look that high above the chain ring. This is my everyday rider so I don't really care what brand the der is but want good shifting. Does anyone have ideas for this?
Quoted: 6172 Post(s)
Liked 4,789 Times
It's shifting poorly on the front? In what way?
Did you just change rings or did you change the entire crank? If the entire crank then is the chain ring spacing different on it than what the original is? A close up pic of the front DR from both the right side and directly above might help us decide for ourselves if height is a problem or not.
I don't have any experience with Campy stuff other than my old Raleigh when friction on the downtube. The Campy front DR worked very well with a 53/39.
You might consider if you can get the gearing you want by going back to the original size chainrings, changing the cassette and maybe rear DR.
Quoted: 185 Post(s)
Liked 102 Times
The bike was originally built up with 9 speed Durace in 53x39 and I switched it over to the compact 50x34 Campy Centaur 10 speed group that I pulled from a donor bike. The derailleur seems to be close enough to the large chain ring but it drops the chain on the outside if I'm switching from the small to large if I'm in one of the smaller cogs and then it won't shift out of the big ring sometimes. I love the compact set-up as a 66 year old but it has been a pain. I will take a closer picture when I get home. This is the only one I had available. More to come, thanks for any help you all can provide.
Likes For bikeshopben:
Quoted: 550 Post(s)
Liked 325 Times
You can adjust height using a Wickwerks fitlink
https://wickwerks.com/products/fit-link-adapter/
but probably have a high limit too outboard and/or tail too inboard.
Likes For Drew Eckhardt:
Quoted: 2026 Post(s)
Liked 1,095 Times
Hard to diagnose without seeing the bike in person but this sounds like a high limit screw mis-adjustment.
Likes For HillRider:
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
I'm with BikeshopBen on this one. It sounds from your description to be an adjustment (tune up) issue. If the stops had been set properly, no matter which rear cog you were in, it wouldn't climb over the chain ring. Did you set the little screw inside that presses against the seat tube for alignment. Lots of people miss that one. Good luck
Liked 4,789 Times
Besides the high limit adjust mentioned above, did you notice if the new crank changed your chain line to the rear cogs?
I went from Campy 10 regular to C10 compact and didn't have any problems. It just worked. I'm on my third crank now, a Chorus UT compact, the prior was FSA, the original was Chorus 53/39 square taper.
Quoted: 185 Post(s)
Liked 102 Times
Thanks for the insight, I'll look into these.
On this, I'm not sure I knew about a separate set screw. I'll check that tonight.
[QUOTE=...Did you set the little screw inside that presses against the seat tube for alignment. Lots of people miss that one. Good luck[/QUOTE]
A couple of more pictures.
Quoted: 550 Post(s)
Liked 325 Times
The height is probably OK. The rotation is not - the tail is too far inboard which in turn requires the high limit screw to be set too far outboard which leads to dumping the chain.
Shift to big ring x small cog.
Make the deraileur cage parallel to the chain.
Set the high limit for 1/16" of clearance.
Reference the Park Tool instructions: https://www.parktool.com/blog/repair...eur-adjustment
The tail on A is too far outboard, B too far inboard like yours, and C is correct
Quoted: 2952 Post(s)
Liked 3,106 Times
Yeah, it's a bit high, but I would think you'd have a little more adjustment down in the braze-on slot. Are you sure you have it all the way to the bottom of the slot?
You have an old 9S front derailleur (on the left).
As Campagnolo and now you found out, it will not reliably shift a 16 tooth difference (which is why the early square taper compacts came with either 50-36 or 48-34 rings)
Either get the proper 10S compact derailleur (on the right) or a post 2009 10S derailleur.
That should eliminate 99% of the problem.
Likes For Mackers:
Quoted: 550 Post(s)
Liked 325 Times
Quoted: 185 Post(s)
Liked 102 Times
