Smallest hand pump
Quoted: 6195 Post(s)
Liked 4,810 Times
I'd think a good group would have a diverse way of inflating their tube/tires. I'd hate to be riding with a group that only had one type of inflator. I wouldn't want to be in a group that all share the same opinions either. That would be boring.
Quoted: 344 Post(s)
Liked 20 Times
There are those in our group from time to time that are "newbies" and need to learn how to properly use a hand pump. We encourage it. So if a time comes and someone who only has a hand pump to inflate a tire, those with experience will coach them on how to repair a flat. We wait. No one is reprimanded, look down upon as rude or referred to as a "chump" for caring only a hand pump as opposed to a co2 inflator.
Quoted: 4717 Post(s)
Liked 1,882 Times
The group I ride with doesn’t have newbs. We are all competitive cyclists or duathletes. Our group rides aren’t casual/social rides. After the ride we might meet for a beer or coffee, but the ride itself is a serious workout.
Quoted: 344 Post(s)
Liked 20 Times
I ride both competitive and casual. But I still do not consider those who carry a pump, serious and social "chumps" as you have refer them as.
As for the OP, this is the pump I carry. I never leave on a bike ride without one.
Realize that the smaller ones will take longer to pump. Like 200+ strokes. I strongly advise getting one with a hose connection, the direct ones can bend and/or wreck the valve if you are in a hurry (like when you are angry at your stupid flat!).
I honestly prefer CO2 for group/club rides to save time, pump for solo rides when time not an issue.
don't try this at home.
Quoted: 974 Post(s)
Liked 512 Times
If you carry a CO2 and a pump backup: Do you carry multiple spare tubes? and/or patches? I'll use an available spare tube before patching, of course. (Group rides are great, I only carry one tube and one CO2. The group shares as needed.)
Instant patches:
I got one of the Park instant patches to work once. I scuffed the tube with the included sandpaper, pressed on the patch, and pressed hard with a tire lever to stick it on tight.
I've had other instant patch failures. They are certainly easy to carry, but don't seem reliable.
Glue
I carry a fresh glued patch kit if I'm riding solo, where I won't have an emergency pick up available. I don't trust even unopened tubes that have been carried around for a while.
Glued patches are reliable, just about all the time. I've had maybe one failure in 20 uses. Of course, some cuts are too big for a patch.
I usually am riding with at least one patch on a tube. I save punctured tubes and patch 4 or 5 at a time, using up a whole tube of glue. It's fast to do them all at once, at home. I finally had one patch fail after riding it for a few months, it had an extremely slow leak from under the patch.
Tire boots
A boot to temporarily fix a large tire cut.
Park Tool tire boot: I had a quite new tire with a small cut, and decided to boot it "just in case" with half of a Park Tool boot patch. No. The edge of the boot wore through the tube, causing a flat a week later. Grrr. They do say it's for temporary fixes only...
The Park boots are stiff, and the adhesive back doesn't really stick to the inside of the tire. So they are difficult to use, anyway.
Now I carry squares of Tyvek. I've used pieces of an event ride's pinned on rider number. These are very good for wrapping the spare tube in the seat bag.
I've seen a few riders get a flat from their spare tube -- the folded crease got a bit worn while being carried for months. That spot gave way after riding a short time with the spare tube installed.
Folded dollar bills work good, too. I've ridden home with the green color showing through the tire cut. Very strong paper.
Instant patches:
Glue
Tire boots
Quoted: 87 Post(s)
Liked 28 Times
Got a flat on a ride. I had 2 co2 canisters. Filled the tire and moved on. Must have gotten a pinhole because I had to pull over twice more. I used my first canister. 2nd pull over we we t through 3 canisters and 2 different co2 guns to get it filled. 3rd stop I pulled off and put my new tube in and filled it with our last remaining canister. Never ride without a pump and 2 new tubes now. The pump will always be plan b on a ride but I'd rather be safe then sorry. Cant imagine a worse feeling than being stranded 50 miles out on the country.
Non omnino gravis
We have this type of guys locally. I've seen these guys. These guys are the self-proclaimed "serious cyclists." These guys are the absolute worst.
Bikes: Habanero Titanium Team Nuevo
Quoted: 399 Post(s)
Liked 185 Times
What goes around, comes around. The group I ride with is a pretty close group of friends, and we don't worry about giving a friend a CO2 cartridge if someone is having an unlucky day(multiple flats). We all carry 2 cartridges, and I can't recall the last time our group got multiple flats on a ride
I'm not saying it's a bad Idea for someone to carry a mini-pump, but I'd be irritated if someone started using a pump when CO2 is available,
I'd hate to be the chump that holds up the group by using a pump.
If your friends give you a hard time about needing a CO2 cartridge, maybe you should find some better people to ride with.
Liked 1,882 Times
I ride solo 6 days a week, but our Saturday ride is a nice change. We chat a little as we warm up, but after about 6 miles the roads start to open up, and the pace starts to rise as well. If someone flats we all stop until it's repaired, and then move on as a group.
This ride is just about going fast, and waiting for someone to use a pump is a buzzkill.
After the ride we stop for a coffee or a few beers, and sometimes we head over to one of our homes for a swim/BBQ. It's not a social ride. There's plenty of time for that afterward.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
This thread started out as a discussion of mini-pumps...
Outdoor Gear Lab has nice reviews and comparisons including this comparison of frame and mini-pumps.
https://www.outdoorgearlab.com/topic...est-frame-pump
I find their reviews to be unbiased and realistic. They actually test every product they review.
-Tim-
-Tim-
staring at the mountains
Bikes: Obed GVR, Fairdale Goodship, Salsa Timberjack 29
Quoted: 394 Post(s)
Liked 197 Times
Lezyne Road Drive. easily fits in jersey pocket. gets the job done.
Quoted: 394 Post(s)
Liked 197 Times
Non omnino gravis
Quoted: 4560 Post(s)
Liked 2,802 Times
