Torque spec for cleats?
Quoted: 643 Post(s)
Liked 1,526 Times
I've got specialized SPD-SL shoes and have struggled to keep the cleats from moving. I've got good allen wrenches and have tightened about as much as I dare without risking stripping the threads or damaging a tool.
Is there a proper torque for these screws? Other trick to keep the cleats from moving? I've considered putting some friction tape on the bottom of the shoe thinking that might make it less likely to slip.
Quoted: 551 Post(s)
Liked 277 Times
5-6 nm
Quoted: 26 Post(s)
Liked 12 Times
Go ahead and tighten them hard, the old German torque spec of "gutentite." I also have Specialized shoes, 3 pair over the years, and I find tighter is better. Never had any damage and never had one come loose. If that makes you nervous, maybe try some Loctite at a lower torque. Disclaimer - not a good tactic for tightening actual bike parts, of course, just shoes.
Likes For goenrdoug:
Quoted: 20810 Post(s)
Liked 9,456 Times
Unless things have changed very recently, the bosses in Specialized shoes are easily and cheaply replaceable (if you remove the insoles, you should see the faint outline of an access flap in the felted liner), so don't worry about it too much. Torque 'em down.
Bikes: 2015 Ridley Fenix, 1983 Team Fuji, 2019 Marin Nail Trail 6
Quoted: 337 Post(s)
Liked 228 Times
Never thought about torque specs before on my cleats, I just crank on em until I think, " yeah those ain't shifting", and then I crank a bit more.
I do like the german phrase "gutentite" though.
Likes For Zaskar:
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
grease em (or thread lock what ever you like) and tighten them. Don't want any slippery sloppiness in cleats.....I have never put a torque wrench to a pedal cleat. Probably the ONLY bike bolt I don't actually. Like states most better shoes have parts that can be interchanged. I usually wear out a set of shoes before this happens though.
Tagaproject6's answer is what is on the instruction sheet that comes with SPD_SL cleats from Shiman - 5-6 nm.
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times
5-6nm I believe. Just tight them with your wrench or Allen Key until your hands are no longer able to. I usually tight them until they're snug, and give them another good 1/4 of a turn. It's probably a lot more than 5-6nm, but whatever, I never had any issues.
Loctite isn't necessary, but can always be useful!
lol!
lol!
rumrunn6
Bicycle Mechanics
9
07-09-18 02:38 PM
W F Collins
Bicycle Mechanics
5
04-06-13 09:42 AM
