New Cranks v. Crank arms v. Helicoils
Quoted: 25 Post(s)
Liked 14 Times
hey all. I recently picked up a 2007 specialized allez expert with full Ultegra for $200 from the Facebook marketplace. It’s in beautiful shape, garage stored and barely ridden the only issue is, the joker I bought it from cross threaded and stripped the cranks when he wrenched in his crappy platform pedals.
So my question is this:
Should I have them retapped and helicoils installed for $70, which my bike mechanic friend suggested,
Should I replace the entire crankset with a new Tiagra set for $155 which my LBS suggested
Or should I replace the crank arms with same era Ultegra crank arms from eBay which I’m leaning towards?
Here’s the bike just because. she looks like she’s going fast just sitting there
Bikes: 2015 Ridley Fenix, 1983 Team Fuji, 2019 Marin Nail Trail 6
Quoted: 336 Post(s)
Liked 223 Times
If it were me, I'd go with either option 1 or 3, just to keep the original crankset look.
Coffin Dodger
Quoted: 794 Post(s)
Liked 292 Times
I have performed option 1 on several customer bikes, and it is as good or better than new.
As long as the crank is not too badly stripped, and the the insert is installed straight, it's a solid repair.
$70 for both side is reasonable.
I'd go Ultegra. Lighter, better looking and who cares about originality on a late model budget bike.
I'd go Ultegra. Lighter, better looking and nobody cares about originality on a late model budget bike.
Should Be More Popular
Quoted: 22579 Post(s)
Liked 8,919 Times
Quoted: 608 Post(s)
Liked 352 Times
A new crankset would cost more than the what you paid for the bike. Plus, it is always easy to spend someone else's money. Have it fixed and take pride in the fact the whole bike was $270.
bike whisperer
Quoted: 1523 Post(s)
Liked 716 Times
Tiagra crankset is a boat anchor, IIRC.
Nothing wrong with properly fitted helicoils. They can be regarded as an improvement.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Quoted: 3241 Post(s)
Liked 2,512 Times
I'd take what's behind door #3 .
Old fart
Quoted: 3583 Post(s)
Liked 3,395 Times
Properly done, a helicoil repair can be stronger than the original threads. What's not to like?
Heli-coil all the way, unless you can find a vintage ultegra crank for less. Nice thing with the old 5-arm cranks is that rings are pretty cheap for 'em these days.
Quoted: 25 Post(s)
Liked 14 Times
Thanks for the advice! I put in a bid on eBay on a set of arms, if I get outbid I’ll go the helicoil route. I use those for drum hardware at my job but wasn’t sure how they’d hold up under constant duress, I just have visions of them spinning out of place when I’m 30 miles from home. But I’m seeing lots of pro helicoil responses. Thanks!
