Bike angle/optical illusion
Old 10-10-19, 02:49 PM
roadbikeChris
Bikes: Fuji Tahoe, Schwinn Sierra
Quoted: 75 Post(s)
Liked 25 Times in 18 Posts
It seems my bike has a bit of a slope from rear to front. Is this normal? I haven't noticed that anywhere else...
roadbikeChris is offline
Old 10-10-19, 02:53 PM
CliffordK
CliffordK's Avatar
Quoted: 18349 Post(s)
Liked 4,501 Times in 3,346 Posts
The first thing to do is to put it on a hard surface, and simply measure ground to top tube.
A back to front slope top tube is rare on bikes, other than "Funny Bikes" which would have a much more pronounced slope.
Are the tire/wheel sizes both 700c, and reasonably close in size (not 27")?
Does the black paint on the fork match the black paint on the head tube?
CliffordK is offline
Old 10-10-19, 03:00 PM
xiaoman1
xiaoman1's Avatar
Bikes: A few too many
Quoted: 1361 Post(s)
Liked 2,176 Times in 1,181 Posts
RC,
The bike appears to be at an angle to the rear wall, causing the appearance of the sloping tube...as mentioned best to check with a tape.
Best, Ben
xiaoman1 is offline
Old 10-10-19, 03:04 PM
noobinsf
noobinsf's Avatar
Quoted: 1088 Post(s)
Liked 1,204 Times in 700 Posts
Yeah, looks like your front wheel is a bit farther from the wall than the rear, which could be producing the illusion. Like mentioned above, maybe your front tire is a slightly smaller width/diameter than the rear. Nothing looks out of alignment, and this bike would have had a straight top tube, not angled.
noobinsf is offline
Old 10-10-19, 03:23 PM
roadbikeChris
Quoted: 75 Post(s)
The back tire is a 1/4 taller. And it appear that accounts for the difference.
Old 10-10-19, 03:26 PM
gugie
Bike Butcher of Portland
gugie's Avatar
Bikes: It's complicated.
Quoted: 4677 Post(s)
Liked 5,790 Times in 2,279 Posts
There’s nothing sacrosanct about having a perfectly level top tube. When I rerake front forks on vintage bikes, the front end typically drops a few mm. Almost no one notices unless I point it out.
gugie is offline
Old 10-10-19, 03:27 PM
jdawginsc
Edumacator
Quoted: 2428 Post(s)
Liked 3,088 Times in 1,947 Posts
Profile of the different tire might account for a bit.
jdawginsc is online now
Old 10-10-19, 03:46 PM
non-fixie
Shifting is fun!
non-fixie's Avatar
Bikes: Yes, please.
Quoted: 2192 Post(s)
Liked 4,572 Times in 1,758 Posts
Not all that unusual. Giant did it:
Are we having fun, or what ...
non-fixie is offline
Old 10-10-19, 04:31 PM
madpogue
Quoted: 2358 Post(s)
Liked 1,745 Times in 1,189 Posts
Whiskey tango, no one suggested putting a LEVEL on the top tube?
My vote is for the tire.
madpogue is offline
Likes For madpogue:
Old 10-10-19, 04:38 PM
roadbikeChris
Quoted: 75 Post(s)
Visual confirmation via level. I say tire as well.
Likes For roadbikeChris:
Old 10-10-19, 04:43 PM
Doug Fattic
framebuilder
Quoted: 614 Post(s)
Liked 1,911 Times in 653 Posts
It is not uncommon for a classic custom frame to have a top tube that is not level. I got an Italian made Masi in Milan in 1972 ($350 all Campy including the brakes). The top tube is off by a about 6mm. Others that owned Masis on the Classic Rendezvous list started to check how level their top tubes were and the range was anywhere from 3 to 9mm off.
Doug Fattic is offline
Old 10-10-19, 04:48 PM
xiaoman1
xiaoman1's Avatar
You will need a level surface too..it looks more than a 1/4 inch to my old eyes and that combined with the nonparallel bike to wall "exaggerates" the drop.
Ben
xiaoman1 is offline
Old 10-10-19, 04:49 PM
roadbikeChris
Quoted: 75 Post(s)
The floor on which I had the bike when checking level, is level.
Old 10-10-19, 05:30 PM
due ruote
due ruote's Avatar
Quoted: 904 Post(s)
Liked 527 Times in 320 Posts
Speaking of level, I would suggest that the handlebar woes you mentioned on the other thread may have a lot to do with your saddle angle. I would level that out and ride some more before going nuts with the bars.
due ruote is offline
Likes For due ruote:
Old 10-10-19, 05:39 PM
roadbikeChris
Quoted: 75 Post(s)
Please clarify "Level out" the seat. How is it out of whack? I did not realize that the seat was also adjustable fore and aft. How's this?
Old 10-10-19, 05:48 PM
thook
(rhymes with spook)
thook's Avatar
Quoted: 919 Post(s)
Liked 745 Times in 546 Posts
too many variables have to be accounted for that level to even be an accurate representation.
thook is offline
madpogue
To my eye, the horn (front) of the saddle is too low. There's plenty of room for personal preference, of course, but look, just as a f'rinstance, at @non-fixie 's pic in post # 8.
And yes, fore-aft position is a significant fit factor. You can also look for a seat post with more or less setback.
How many is "too many"? The floor? The tire profile? Tire pressure? Seismic activity? Granted, a measurement on a non-carpeted surface would be marginally better, but the OP's finding is enough to confirm that it's not an optical illusion.
madpogue is offline
Likes For madpogue:
Old 10-10-19, 06:01 PM
thook
(rhymes with spook)
thook's Avatar
Quoted: 919 Post(s)
no need to be snarky. i've built alot of walls. so, yeah, the floor, the carpeting thickness, the tire pressure and/or actual size, actual level of foundation even. and, a small tiny level like that is very sensitive to variation compared to a longer tool. the better way to really determine would be a measuring square; top tube against the dropouts.
i'm not saying the top tube is or isn't level, btw. i'm just commenting on the method
thook is offline
Likes For thook:
Old 10-10-19, 06:04 PM
roadbikeChris
Quoted: 75 Post(s)
I think I will take the bike to the bike shop tomorrow and get it on a level floor and recheck it. The rear tire is 1/4 taller than the front. And the level I used bears that out. I don't want to create a lot of controversy here.
Old 10-10-19, 06:06 PM
slow_runner
Bikes: Early Shadow handcycle plus R20 project
Quoted: 19 Post(s)
Liked 12 Times in 9 Posts
My 2c.
Cumulative error?. Your rims appear to be differing types as are your tyres? Yes?
Image perspective may not be square on?
Unless it is a 'funny bike' for a sideshow all slight variables can be compensated for with height/angle adjustment.
Why to the bike shop?
Does it ride well, no dropping to one sides, keeps a straight line?
Save yourself some time, money and possible jesting(?).
Do you have a tape measure?
If you are wanting some perfection, use Pythagoras (3,4,5) to check for square (or a square, or level).
You do not require a perfect level surface; a 180 degree flat surface is all you require.
slow_runner is offline
Old 10-10-19, 06:07 PM
thook
(rhymes with spook)
thook's Avatar
Quoted: 919 Post(s)
well, level or not top tubes are pretty controversial
thook is offline
Old 10-10-19, 06:09 PM
roadbikeChris
Quoted: 75 Post(s)
The rims are matching ARAYA 700c
Old 10-10-19, 06:15 PM
Unca_Sam
The dropped
Unca_Sam's Avatar
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times in 696 Posts
Unca_Sam is offline
Likes For Unca_Sam:
Old 10-10-19, 06:18 PM
roadbikeChris
Quoted: 75 Post(s)
Originally Posted by Unca_Sam
Hilarious!!!!!
Old 10-10-19, 06:51 PM
slow_runner
Quoted: 19 Post(s)
Here is the thing with levels, especially the garden non-calibrated variety, they are often 'out'. Hook and others will be aware of what I am speaking. A long base level will give a more accurate reading whether it is this bike frame, a wall, whatever,
So to eliminate error requires a better level or as a 'need must' the level needs to be reversed and viewed again.
Regardless a levels amount of response or rated accuracy, always confirm the level is indeed an accurate one by reversing the level and ensuring the bubble has not shifted.
End of amateur instruction lol.
Likes For slow_runner:
