Tubes are faster
Quoted: 9656 Post(s)
Liked 6,366 Times
Tubes are faster
Well, tubes are faster. Says so right here -
Quoted: 7043 Post(s)
Liked 11,087 Times
Does that factor in the time spent on the roadside fixing punctures?
Likes For Koyote:
Liked 6,366 Times
You don't have a support vehicle?
Bikes: Giant Propel, Cannondale SuperX, Univega Alpina Ultima
Quoted: 672 Post(s)
Liked 419 Times
Great. Some guy I never heard of conducts a n=1 test on youtube with no/poor experimental control, and the results are supposed to reflect anything other than one guys experience on one day? Why not skip the test and just assert his opinion? It'd carry the same weight.
Formerly fastest rider in the grupetto, currently slowest guy in the peloton
Likes For bbbean:
Should Be More Popular
Quoted: 22638 Post(s)
Liked 8,953 Times
Likes For datlas:
Quoted: 3246 Post(s)
Liked 2,531 Times
Quoted: 20810 Post(s)
Liked 9,456 Times
I believe him. Lookkit the size of his melon - he must be smart!
Likes For WhyFi:
Quoted: 390 Post(s)
Liked 255 Times
He weighs 200 pounds. 120 psi is not extremely high for his weight. The bike path looked smooth. The same tires, tubeless at 72 psi might be way too low for him. Tube might very well be faster in this instance, maybe not in others.
Likes For Jack Tone:
Quoted: 18883 Post(s)
Liked 10,646 Times
He needs every advantage he can get, rocking an aerobeard like that. It's like how a giant tail is a setback for a peacock, only the strongest ones can pull it off. Dude must be using red tubes to be fast enough to have a beard like that.
Quoted: 1418 Post(s)
Liked 1,936 Times
Likes For t2p:
Liked 1,936 Times
agree - 200 lb riding skinny clinchers @ 72 psi would be an invitation for snake bite punctures
Likes For t2p:
Liked 6,366 Times
Likes For Mojo31:
Liked 11,087 Times
I quit watching when I saw the valve caps.
Likes For Koyote:
Liked 2,531 Times
Likes For seypat:
Liked 2,531 Times
WHAT IS FASTER? *TUBE'S OR TUBELESS?* (POWER METER TEST!!) - YouTube
Quoted: 441 Post(s)
Liked 469 Times
Might as well have made a video of himself running 72psi on a tubed setup and getting a pinch flat. Would have been just as informative.
Quoted: 4466 Post(s)
Liked 4,941 Times
120 psi on our rough local roads would be a non-starter for me. It's plenty bad enough running 60 psi tubeless. His roads looked super-smooth so hardly a shock result here.
Quoted: 338 Post(s)
Liked 408 Times
Not comparing tires at the same pressure what's the point of that? I mean... "I'm running a tubeless setup at about 72 psi" - well, what do you expect? That's too little for a narrow tire.
When you use normal hooked tubeless rims and just ride tubeless at 90-100 psi (or whatever is appropriate for your weight) tubeless tests faster than any tube type bar latex in every single test, all things being equal. Hookless tubeless wheels which are limited to 72,5 psi don't make any sense with anything thinner than a 28mm tire, and even that is going to be a bit low pressure wise for most riders if you're looking for maximum speed on a decent road surface.
Bikes: SL8 Pro, TCR beater
Quoted: 999 Post(s)
Liked 588 Times
Tried 75 and 80 (not recommended, I know), and I prefer 70. The part of the rear tire that touches the tarmac does not deform (flatten?) very much when my arse is on my saddle. I could probably go even lower without any significant increase in RR.
Liked 8,953 Times
Still over-inflated IMO even if his roads are smooth and he is a fattie. He would probably have a more comfy ride and same speed (or even higher) at 100 PSI. 120 should be saved for the velodrome.
Quoted: 338 Post(s)
Liked 408 Times
However, tubeless 25s on 72.5 psi (or if the pump is off, "somewhere under 70 psi") is definitely way below ideal for a guy of 200 lbs.
The corollary of that is that hookless wheels with 72.5 psi limit and tires below 28c just don't make sense as a combination and even those are borderline on good surfaces. I'm fortunate to have plenty of them.
Liked 8,953 Times
On 25s for a heavy guy on a good road Silca suggests that about 100 is ideal for going fast. Pump manometer being off by 10 psi at 120 psi wouldn't be unheard of; mine is off by 7-8 psi at 100 psi - so 120 psi on his pump could be fairly close to ideal. We don't know.
One of my pet peeves, though, is cyclists who think the MAX pressure on a tire is the IDEAL pressure. Rarely is that the case, at least for clinchers.
Liked 4,941 Times
Geraint Thomas in his Podcast once said he was typically running approx 75 psi on his Contis. Those guys ride pretty fast.
Liked 8,953 Times
Likely more off-topic drivel, but I cannot tell you how many novice cyclists I know who brag about their new fancy carbon fiber frames and say how smooth and comfortable it is compared to their aluminum frame, but they are pumping their tires up to 115PSI. You will do much better (and save a crap-ton of $$$$) if you stay with that aluminum frame and just drop your PSI down to 80 or 90.
/end rant
/end rant
Quoted: 338 Post(s)
Liked 408 Times
https://www.researchgate.net/publica...sure_Influence
What happened in the meantime is that rims and tires both got wider, and a wider tire at the same pressure is effectively stiffer, meaning the optimal pressures went down, while maximum allowed on a 25mm tire is still around 110 psi. So the old ways don't make sense on 25mm tires, and even less on 28mm, but at one point, they did.
