Do cold temps affect batteries?
Bikes: 2016 Masi strada vita due, 2019 Kona Dew Plus
Quoted: 268 Post(s)
Liked 80 Times
As we all know, low temperatures are generally bad for batteries. Has anybody else noticed?
Today, I did a short ride @ 27degF. My headlight started to get drained @ 15 miles, where it usually last almost 25 to get drained.
Quoted: 3323 Post(s)
Liked 2,162 Times
You are answering your own question. Nothing to add except Yes.
Quoted: 6340 Post(s)
Liked 4,936 Times
Depending on the type of batteries, yes there are limit of various sorts. Some you shouldn't charge until they get to a certain temperature if you were operating them in colder temps. And many batteries will deplete quicker as the temperatures go down.
Find the manual for your lights and anything else that uses a battery. In the spec's they probably list those temperatures.
Quoted: 7395 Post(s)
Liked 2,563 Times
Yes. And dynamo lights are not affected by temperature, as far as I have noticed.
Most people, when they try dynamo lights, ask themselves why they didn't try them sooner.
Likes For noglider:
Liked 3,103 Times
Yep.
cold causes battery life shrinkage.
-Oh Hey!
-Oh Hey!
Bikes: 2021 Trek FX Sport 4, ~1996 Mongoose Crossway 4.50
Quoted: 96 Post(s)
Liked 1,370 Times
I have a Cygolite Hotshot Pro tail light. I get three 20-miles rides out of one charge when it is warm, but only two in the cold.
Mark
Mark
Quoted: 3521 Post(s)
Liked 1,497 Times
You should not charge Li Ion batteries below freezing temperature. But I suspect your light warmed up pretty fast when you got it inside, so it was probably warm enough to charge once you started charging it.
I am surprised the light had roughly 60 percent performance (15/25 miles) at below freezing. I would have expected less than 50 percent.
If you have your phone on during that time and if your phone is not kept warm, if it was running apps and had the screen on, that battery drains fast too.
Quoted: 1843 Post(s)
Liked 3,462 Times
You can find this info from the manufacturer's web sites. For instance, on the data sheet for the Panasonic 18650 lithium ion battery, you can see that the capacity is reduced at -10C relative to room temperature...
Also note that the terminal voltage decreases with temperature too. If the light cuts off at a certain battery temperature, it will cut off quite a bit earlier in cold temperatures.
Steve in Peoria
Steve in Peoria
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 337 Times
I have integrated dynamo, lights, and lithium batteries integrated systems that run year-round, one of them a decade presumably now. They do fine, and that decade-old powers a horn that draws far more current than lights.
Liked 1,497 Times
I called Peter White a few years back and asked if there was a problem using my B&M Luxos U (now discontinued) headlamp in sub freezing temperatures. If you are not aware, that dyno powered headlight has a pair of built in Li Ion batteries. He said he had never heard that about Li Ion batteries and sub freezing temperatures, so he suggested I would have no problem. But I chose to unplug my dynohub whenever I rode that bike in subfreezing temperatures anyway.
Liked 3,462 Times
For this discussion, the key points are that you shouldn't charge them below 10 degrees C, and shouldn't discharge them below -10C.
-10C is 14 degrees F, which is as cold as most(?) cyclists will ride, so it's probably not a big impediment.
For things like standlights, which will be getting charged when the bike is ridden in the cold, it's probably best to use a super capacitor instead of a lithium-ion battery. Interestingly, NiCad batteries are much more tolerant of charging in very cold temperatures, which is what I use in my home-built dynamo lights. Nicads are pretty nearly impossible to buy now, so I expect to switch to supercaps for any future work.
Steve in Peoria (where is it is currently below 0F)
Likes For steelbikeguy:
Quoted: 840 Post(s)
Liked 337 Times
Obviously, there are lithium batteries for cars, and these must tolerate low temperatures, so the technology is there. If you Google around, you can find low-T versions in 18650 such as here.
Liked 3,462 Times
Steve in Peoria
Quoted: 840 Post(s)
Liked 337 Times
Liked 1,497 Times
The battery manufacturers are pretty clear and consistent about how they want their lithium-ion batteries treated, and they publish their recommendations on their web sites. This is what Panasonic said when I last checked:
I use a lot of those for a variety of things. But rarely use them below freezing.
Liked 1,497 Times
I have read that Tesla is switching to a heat pump instead of battery heaters, as it is more energy efficient for maintaining battery temperatures.
But, I do not have an EV, so I can't say any more on the topic. More than half of my miles are long distance trips of several hundred miles, the charging networks are not well enough established for me to consider an EV yet.
Liked 3,462 Times
and one for the Energizer AA NiMH.
For my use in standlights, NiMH doesn't look like a good choice because the manufacturers only provide specs for charging at or above 0C. They are a bit more particular than nicads in terms of continuous charging, but that's not hard to accommodate.
As for discharge characteristics, Panasonic does have specs for temperatures down to -10C. No graphs or info on how much the capacity is reduced, though.
Energizer only specs discharge down to 0C, so I don't know if they are being conservative or if their batteries are less suited for cold than Panasonic. The datasheet does include the admonition "NOTE: Operating at extreme temperatures will significantly impact battery cycle life".
Energizer does provide more generalized info on NiMH batteries in their NiMH Handbook.
In general, all batteries operate by the use of chemical reactions to generate electron flow. Chemical reactions occur slower in cold temperatures than in warm, so it's to be expected that performance will drop when things cool off. Super capacitors offer better performance in the cold (although I haven't checked the datasheet...), but have to be much, much larger to provide an equivalent amount of energy.
Steve in Peoria
Liked 1,497 Times
Here's the datasheet for the Panasonic AA NiMH.
Steve in Peoria
Steve in Peoria
FYI - I prefer rechargeable batteries, thus I am not considering buying Lithium AA or AAA batteries. But, my camera owners manual specifically says for cold weather use Lithium AA batteries. And suggests having a spare set that is in a warm pocket. So, if I needed to have working batteries in very cold weather, I would try those out. My camera uses Li Ion batteries, but has an optional adapter to use AA batteries.
Randomhead
Liked 3,781 Times
I switched to dyno on my fatbike after I had 2 hotshot taillights die on my 7 mile commute. It was 5F though.
It's possible I left one on the bike all day, don't recall.
Liked 3,462 Times
Thanks.
I'm not sure if the lithium performs better than NiMH, or if the difference is due to the lithium having a nominal voltage of 3.7V versus the nominal 2.4V of the two AA NiMH of my earlier Canon. I suspect both used similar technology circuitry that had similar minimum voltage requirements.
I do like the idea of having a AA adapter for a camera! It would be nice to have a cheap alternate power source when needed. ...although... I imagine that the adapter costs about as much as a spare lithium battery?
Steve in Peoria
LR÷P=HR
Bikes: 1981 Holdsworth Special, 1993 C-dale MT3000 & 1996 F700CAD3, 2018 & 2019 Cervelo R3’s & 2022 R5, JustGo Runt, Ridley Oval, Kickr Bike 8-)
Quoted: 887 Post(s)
Liked 1,235 Times
Rechargeable Lithium (Li Ion) cells don't really like cold weather. Ask any EV owner living in a cold climate.
Lithium "Primary" cells (non-rechargeable) are a great option in cold weather.
All the best
Barry
Likes For Barry2:
Quoted: 840 Post(s)
Liked 337 Times
Clark W. Griswold
Quoted: 4485 Post(s)
Liked 4,158 Times
Count me as one of those people. I think it was 2016 or so when I got my first Dynamo but I first looked at them back in 2011-2012 and said "nah too heavy, too this, too that". Silly me. Now with the Supernova M99 Pro DY light I have essentially a car headlight with high beam ability powered by my front wheel moving from my pedaling is there anything better? Granted the light isn't installed yet but soon will be
Liked 2,563 Times
My niece bought a Tesla a few years ago, just before covid. My niece's hubby was telling me that they get very poor "mileage" in winter because there is an internal battery heater that keeps the battery warm in cold weather. He is talking about Portland OR to put "cold" weather into perspective. When I have been there in winter, it was in the 20s and 30s (F) for temps.
So with extra machinery and software, you can use these batteries in cold weather, but all of that comes at a cost. It's not a cost that makes sense for a bicycle light.
