GRX vs. Ultegra
GRX vs. Ultegra
I'm in the beginning stages of planning the next gravel bike. It will be used for multi-surface rides and eventually bikepacking, but I also have a dedicated road bike for regular road duty. Been looking at building up a bike from scratch, and need some help deciding between a GRX groupset and a 105/Ultegra mix. I would like a clutch rear derailleur, so that will be either Ultegra or GRX. The big question is whether GRX would be worth it (suspecting it will cost more than a 105/Ultegra mix) or if I can save a few bucks and skip GRX.
So far I speced out a Niner RLT 9 steel with a GRX groupset (46/30 crankset, and 11-36T cassette) which came out to 3k. Also found Excel sports has a Niner RLT 9 RDO already built with Ultegra for 3K. Haven't really decided on a budget for this bike yet, but some input would be appreciated on whether to go with GRX or 105/Ultegra. Maybe some other frames to look at would be helpful (also saw the Jamis Renegade which might work but is a similar price to the Niner RLT 9 steel frame).
Dave
Dave
Some early "spy" shots/info on the 2020 Renegades leaked over on ****** and they've got a real solid lineup it looks like with GRX-based bikes.
/r/gravelcycling
I echo the poster's comments that the $1499 MSPR S3 looks like a hell of a deal.
Are you primarily interested in a steel frame? Or carbon?
There's not a lot of GRX bikes equipped bikes out there (yet) but based on your purchase timeline there probably will be. You'll probably still be able to build a 105/Ultegra RX with your 46/30 crankset for less, though.
/r/gravelcycling
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
My opinion is that the deciding factor is going to be low vs high gearing.
Assuming only Shimano supported configurations, GRX is going to support a slightly lower gear which will help when hauling tents, food and sleeping bags on hilly or mountainous terrain.
Ultegra will be higher geared for go-fast rides. Climbing the really steep stuff up in the Blue Ridge or Cohutta Mountains will be difficult however.
Going beyond Shimano supported systems, there is no doubt that I'm slower with the 46/30 ultra compact cranks than I was with Ultegra 50/34 compact road cranks but there is now way I could haul camping gear on repeated 5000 foot days without the very low gears. In fact, I don't think GRX is really low enough for bikepacking in the mountains. My low gear is 30f/42r or about 19 inches and it is nice. GRX and Ultegra are in the mid and high 20 inch range.
Once you start hauling 35 lb gear up in them hills you will likely need a very low gear.
-Tim-
-Tim-
Quoted: 1218 Post(s)
Liked 298 Times
I was looking at the Niner RLT steel but didn't like any of the Niner offerings. I thought I'd go a different direction but I have not yet pulled the trigger there. the Excel steel RLT frame price almost has me coming back to it. Especially considering I want GRX.
on test riding the Niner steel and RDO. they are both fun, but for multiday long distance riding I'd go steel first of those 2 bikes. Plus the steel version has room for 650 plus. I only throw that in because tubeless WTB horizons, bullet proof!!! A guy rides from Canada to Mexico without a flat on Horizons. WTB Horizon Road Plus ? Spoke'n'Fly
as for GRX, the big selling point for me is the new levers. different pivot point. different grip.
the Giant revolt is at the top of my list because of the 70 mm BB drop + carbon + front rack use + 700x45 or 650x47. How ever I do want GRX. So do I drop to Number 2 on my list Niner RLT steel and build it?
If I want a Niner RLT steel and GRX I'd probably just build it, because I can guarantee that I won't like what Niner chooses to offer as a GRX package built bike. *cough wheel choice* etc....
Quoted: 7 Post(s)
/r/gravelcycling
/r/gravelcycling
https://imgur.com/4nrjwTH
https://imgur.com/aJIfvpj
Images for the people that can't be bothered to go to ******.
Sunshine
Quoted: 10970 Post(s)
Liked 7,496 Times
From what I can see, an ultegra group with GX rear derailleur and an adventure crank from FSA or Praxis is effectively the same as GRX from what I can see.
For all intents and purposes.
Quoted: 18883 Post(s)
Liked 10,646 Times
-Tim-
-Tim-
https://zpacks.com/products/plexamid-tent
That's the lightest solo tent available with bug mesh etc. It's waterproof, roomy for one person, packs small, and comes in under a pound. PCT thru hikers attest to its quality and durability.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
The clutch is nice if you have a long cage and big gear range in the rear. Ultegra doesn't really need a clutch if you keep it stock, but that limits the size of your cassette.
- Soli Deo Gloria -
Liked 736 Times
This is unrelated to the topic of the thread, but may be of interest to bike packers willing to spend on comfort.
To the point of this thread, after tent, bag/quilt, pad, food, stove etc, it is easy to pack 25 lb and 35 lb is more likely for a multi day trip. Fully outfitted my bike is easily 45 lb and close to 55 lb set up for a five day trip as seen below.
The question I would ask is how likely bikepacking is to start, or is this going to be ridden unloaded on normal gravel rides for a time. Bikepacking in the mountains of the southeast will require a gear down in the teens. If bikepacking is a future goal rather than a today need then it makes sense to do a normal GRX group to start and then look at lower gearing as needed when bikepacking enters the picture.
-Tim-
Likes For TimothyH:
I'd say get the Niner RLT RDO 4 star build from Excel for under $3k, but I'm biased! The Ultegra works flawlessly, and it has the clutch if you choose to engage it. For that price, I'm beyond happy with this bike. At under 3k, you're basically getting the entire bike for what a frame/fork normally runs.
- Soli Deo Gloria -
Liked 736 Times
I do agree that 3k is a nice price for the four star build and IIRC some of Excel's "Demo" bikes are actually new in box, never been assembled or ridden.
The Jamis is a killer deal as well.
-Tim-
Well, Jenson USA had Niner RLT 9 RDO frames on sale for $1750 a while back.
-Tim-
-Tim-
The whole topic of ultralight gear is fascinating and the only thing which stopped me from getting a Plexamid was the need for a trekking pole. In hindsight, the external frame on my Nemo Hornet is cumbersome and I should have gotten the Plexamid with a carbon pole instead.
-Tim-
-Tim-
It is probably unlikely that I would start out bikepacking, but it would be nice to start out with something that doesn't have to be changed later on. From what i can tell, if the GRX RX-812 rear mech is used in the initial build, the only swap that might be needed later on is a cassette. The RX-812 supports up to a 42t cassette. With a 11-36 cassette and a 30t chainring that would be 23 gear inches. Would that be low enough for bikepacking? Got about 26 gear inches on the current bike.
Was able to eek a few more bucks out of the 3K bike build, but not much. More than likely this will be a gradual build, but going with the Jamis frame instead of the Niner would save $250. Going to look at the geometry on both and see if it would make sense to go with the Jamis instead.. If so, maybe putting more $ into wheels would be good? Currently have Mavic Allroad tubeless disc wheels in the plan, not sure if they are a decent set of wheels or not.
Dave
Quoted: 1975 Post(s)
Liked 232 Times
Tim,
Dave
Dave
https://bikerumor-wpengine.netdna-ss...parts-list.gif
Dave
Looks like the min low sprocket is 40t (not 36t).
https://bike.shimano.com/en-NZ/produ.../RD-RX812.html
Back to the drawing board.
Liked 232 Times
Looks like you're right on that one, according to this link it only works with a 1X11 wide setup:
Dave
Dave
Liked 232 Times
Likes For redlude97:
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
https://imgur.com/5CVrj8o
nothing to see here
Quoted: 218 Post(s)
Liked 145 Times
As mentioned already, what is your intended use? That should define what type of gearing you want or need. When you decide that, 1x or 2x, electronic or mechanical can then be worked through. Since you already have a dedicated road bike, a more trail oriented gravel bike with low gearing might be what you are looking for. If low gearing isn't your thing it's hard to beat a 105 with an RX derailleur if you want to ride fast and keep your initial costs low.
The GRX Di2 seems like a nice set up and has peaked my interest. Until I can ride a bike with it and the costs come down a bit I'm not going to bite.
Dave
