Bottle dynamo output voltage
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
I’m working on an old bike with an Enwell bottle dynamo. The bike is a 67 and I expect the dynamo is of the same vintage. However I am not getting the lights to work. What voltage should I expect from something like this? I’m getting 1.5 volts AC. Continuity is good from dynamo to bulb so I wanted to confirm expected voltage before condemning the dynamo.
Quoted: 3461 Post(s)
Liked 1,467 Times
I believe that the bulbs are rated at 6v, 2.4 watt headlamp if taillight used, taillight at 0.6 watts. But if no taillight, then 6v, 3 watt.
I know that I I did not answer your question, but I have no clue how much resistance you have in the circuit, if you have a higher wattage bulb then the voltage might not be very high. Look at your bulb(s) to see what they are rated at.
If you go fast down a hill you can blow out incandescent bulbs. I used to run zener diodes across it so that if voltage went above about 8 volts, the excess power would be drained off through the diodes.
Randomhead
Liked 3,699 Times
It really depends on the load. If it's a dead short, zero volts, if it's open circuit, 100 volts.
If it's the correct size light bulb then I would expect around 6v.
Quoted: 1829 Post(s)
Liked 3,376 Times
The output voltage is related to both the speed and the resistance of the load. If you are going 10mph or more, I'd expect to see over 6VAC if there is no load connected. If the wrong bulb is installed, that might be pulling the voltage down (as mentioned earlier).
Or you might just be having trouble with a heavy layer of oxide on the dynamo connections? Some (well, a lot) of the old dynamos relied on the bike frame as the return path for the current, and this can easily be a very high resistance connection. Of course, some also use a little spring clip that could have a lot of resistance too...
How much current do you get from the dynamo when it is running at 10mph or so??
Steve in Peoria
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
Thanks all for all the ideas. I had one of these on a bike when I was a kid, but not since. I just always assumed these were DC generators and didn't realize they were AC.
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
They didn't have "brushless" BITD
Not that I know anything about bottle dynamos, but at this point, if it's dead already, then there is no downside.
Sounds like the internal brushes may be corroded. Age has a way of doing that. The good news is that contact cleaner can be sprayed in & the wheel spun to simulate in service use to clean the contacts.
Failing that the dynamo may be disassembled & a burnishing tool can be used to mechanically scrub the corrosion off.
If the brushes are worn to nothingness, Ace Hardware has a variety of electric motor brushes in stock in the assorted fastener aisle.
Could be a bad diode or capacitor if it has such a thing. A few minutes with a soldering iron isn't really a chore if you are so inclined.
Car dependency is a tax.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
Sadly, were disassembly an option, I would have already done the exploratory surgery. Contact cleaner I would imagine will wash away any lubrication to what I would imagine are sleeve bearings. The bike is going to be raffled off in a fundraiser most likely this fall, so I have time to explore options to resurrect it.
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
Are you setting the meter for a sensible range, i.e., 20VAC or so in this case? Are you measuring off the dynamo or farther away? Are you just spinning the wheel fast enough? Apologies if the questions sound insulting, but many people struggle using meters.
Liked 1,467 Times
I do not think there are any brushes in a bottle dynamo. Just spins a permanent magnet inside of a non-rotating armature with the windings. Can't get any simpler than that. I have never disassembled one, so maybe I have that backwards and the windings spin in perminent magnets? But that would be the hard way to build one.
The bottle dynamos I had (Union brand from Germany) had no holes to shoot in any tuner cleaner, they were supposed to be sealed against the weather.
I have never heard of any capacitors or diodes in them.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
Liked 1,467 Times
You mentioned a electric drill, but how fast was the wheel really spinning. You probably need two revolutions per second to approximate 10 mph.
I would not worry about old lubricant for only a few minutes of experimentation.
I used a bottle dynamo on my errand bike because I wanted a front to-be-seen light in the evenings for short rides near home. But otherwise, bottle dynamos are a major inconvenience in my opinion. The LED light options out there for a low cost are much better options than the options that were available when bottle dynamos were one option. The noise, the poor light, the drag on the tire, the chance that a downhill run would blow out your bulbs, these were reasons to want something else. I think the drag was not that bad, but the noise made you think that the drag was much worse.
Is this a restoration project?
I am potato.
Liked 1,629 Times
I had forgot that "bottle dynamo" is a misnomer. "Magneto" is actually the correct term for what is used on bicycles.
I was thinking it may have had a commutator &/or may have had a rectifier for some reason. DC generators & dynamos have brushes & contacts to be cleaned & serviced. Whereas magnetos don't.
As to being sealed up tight: On bicycles they probably never saw enough age or use to justify maintenance access. And in, magneto there just isn't anything to "go bad." So there's no reason to consider maintenance at all.
On a resistive bulb electricity "type" would hardly have mattered, anyway...OP: Flip the AC meter to DC & see what it reads. That'd tell us what kind of device you have.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
I would call it more of a preservation project than a restoration project. Everything is original except the tires, chain and spokes. The spokes were so dingy that nothing could be done for them so I replaced them with stainless steel. The Schwinn monogrammed seat is being touched-up by someone and should be done shortly. We tossed around the idea of repainting, but liked the idea of original paint. We are wanting to do the same with lighting.
Less than 500mv DC.
Less than 500mv DC.
Liked 1,467 Times
Paint looks very good for that era. Chrome looks like new. Looks like an old coaster brake single speed. Small womens model.
Since you are working to keep it original, then picking up another bottle dynamo out of a spares box at a bike coop or charity would be unlikely to provide the right brand and model. Plus, those usually were for the front wheel with built in light.
Headlamp looks like a battery model, not a dyno powered one. Dyno powered lights do not need a switch, you move it away from the tire to turn it off.
Nice project.
Nice project.
Liked 3,376 Times
I've got an old Schwinn dynamo light set in my parts box, and maybe it can be a helpful reference.
It uses the dynamo body, brackets, and the bike frame for the "ground" connection, which is a potential source of troubles.
The other connection is through a weird terminal in the bottom of the dynamo that is shaped like a cup, and relies on shoving in wire and hoping it contacts it. I think perhaps you are supposed to wrap the bare copper wire around the little post in the plastic plug that gets shoved into the cup? As someone who has worked with electrical connectors for decades, it is hard to think of a worse way to make a connection.
a couple of pics....
the light set:
the bottom of the dynamo, where the connection is made:
If you've got a connection like this, check it and see what can be done to minimize the effects of oxidation or corrosion, and perhaps see if the wires can be made to fit tightly against the metal terminal?
Steve in Peoria
the light set:
Steve in Peoria
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
Nice project.
Nice project.
Palmer
Quoted: 1670 Post(s)
Liked 1,825 Times
Fun fact: Some modern Shimano hub dynamos, like the S701, are rated at 6V, 1.5W.
