how to cut cable housings clean
Sorry if this is basic. But I've been having trouble cutting brake cable housings cleanly; at least half the time the housing is sort of mashed at the end where I've made the cut, and I have to either push hard on the cable to make it go through, or (sometimes) I stick a nail in to open things up.
I'm using a brand new Park Tools cable / cable housing cutter. I've tried doing it fast, and I've tried it slow, and it doesn't seem to make any difference. Any suggestions?
Thanks...
Thanks...
On brake housing I use the park cutter then follow that with some cleanup with a flat file and then a nail to make sure the inner lining is opened up. Some people use with a rotary tool (dremel) with a cutoff wheel. I try to cut at 90 deg but this never seems to happen cleanly with the spiral steel housing so the file is nice to clean up with.
Bikes: Giant CRX
Thanks...
Thanks...
Bikes: Giant TCR Comps, Cdale R5000, Klein Q-Pro, Litespeed Siena, Piasano 105, Redline Conquest Pro, Voodoo Bizango, Fuji Aloha
Dremel does a fantastic job at cutting cables. On my first try, it wasn't perfect. So, thereafter, I just put a small piece of black tape around the cable to be cut and I got excellent cuts from the Dremel.
Quoted: 2026 Post(s)
Liked 1,096 Times
One trick to using a cable cutter for brake housing is to be sure the upper jaw is positioned to slip between the coils of the reinforcing wire. That way you avoid crushing it as you cut. Then use a flat file to smooth up any small burrs and a big needle or small nail to round out the liner.
Actually, I find a pair of quality side-cutter pliers works better than specific cable cutters for brake housing. The purpose-built cable cutters are far better for shift housing and all inner wires.
I've tried a Dremel too and find the cutting heat tends to melt the outer cover so you have to work slowly.
Formerly Known as Newbie
I put a piece of old, discarded cable inside the housing, then cut through both the housing and cable. The cable prevents crushing well enough.
--J
--J
To err is human. To moo is bovine.
Who is this General Failure anyway, and why is he reading my drive?
Become a Registered Member in Bike Forums
Community guidelines
Brake housing, side cutters then look at the end to make sure you didn't bend the wire over so it interferes with the hole. If you did, just nip off a piece till it is clean.
Der cable housing, dremel.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
I had the same trouble with the Park Tool. No matter how you position it you often get a partially deformed housing that has to be re-formed - and you almost always have file work to do. The Dremel with cut-off wheel works very well, the high rpm cutter buzzes through the housing more cleanly, without deformation. I cut cable housing by resting it on a block of wood.
If you still have trouble, try using a soft copper or aluminum rod or wire as an inner mandrel like our friend in Helsinki, then bring the Dremel down straight through the whole enchilada.
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
Any sharp cutter followed by a touch to the old grinder.
Today, I believe my jurisdiction ends here...
Quoted: 29 Post(s)
Sounds like your running the tool too slow. The longer it takes; the more it allows heat to build up. Run your tool as fast as you can safely use it and cut it quickly. Be sure you're using a cutting disk too, and not a grinding stone.
Liked 1,096 Times
My Dremel is a single speed so I have no choice. I did use a cut-off wheel, both the brittle very thin type and the thicker, more durable fiber reinforced ones. Both wanted to melt the housing cover unless I fed it really slowly.
I just use a pair of side-cut pliers and to smooth it down, use a grinder, electric sander or tape a piece of sandpaper to your bench and rub the cable across until flat. As previous posters mentioned, Dremels or any rotor-like device with sanding capabilities works great.
Klaatu barada nikto
My advice is pretty basic ... I get clean cuts reliably by just making sure I do a strong and fast cut. Don't be afraid to use two hands. Squeeze those cutters fast and as strong as you can. If you dillydally about the cut, you are almost guaranteed a lousy cut. Think ninja/samurai ;-)))) Clean up brake housing with a grinder. If you need to clean up shift housing, you are doing something really wrong.
Steel Member
Bikes: N + 1
Quoted: 7 Post(s)
anything wrong with a good, stout pair of general cable cutters used briskly as described above. I've got a huge (like, 24") set for car repair, though I've been meaning to pick up a smaller set for bike work anyway.
Just make the cut quick, and then trim off any misshapen metal by angling the cutters to just cut off the part thats deformed... so:
1) Cut to length
2) Use the same cutters to do some detailed clean up to make sure theres no bent coil protruding.
If you have a bench grinder, thats a plus. You can put the housing to the grinder and get a perfect, 90 degree, perfectly filed end. If you don't have a grinder, don't waste your time with dremels and files. The snip and cleanup method works just fine. In this department, perfectionism probably won't pay off with improved function.
1) Cut to length
Thanks...
Thanks...
- djmod
Quoted: 1612 Post(s)
Liked 2,594 Times
If I'm making alot of cuts, I'll put an abrasive blade on my mitre saw. Ice pick to clean up end.
Holly crap. I dunn think the OP is looking to do THIS MUCH work. He's got what is, a specialty tool for the job, so he was expecting one-tool, one cut (yeah right).
Bikes: 1974 Raleigh Sports
Wow, ya'll are really making me want to get myself a Dremel...I had one as a kid, but my older sister eventually ran off with it to college, and I never saw it again.
For me, diagonal pliers and a file do the job, albeit slowly. I'd agree that one only gets a good housing cut about half the time with pliers; when the housing gets messed up, move inward 1/8" and try again. I almost always get a good cut in 2-3 tries. When the housing has a reasonably good cut, I use a file and mill the face of the housing down until it's really flat and round and perpendicular to the cable axis.
Regardless of the method, my experience is that it pays to be psycho about getting the housings just right. An extra 10 minutes here gives your brakes an action as precise and solid as a bank vault.
Bikes: 1999 Norco ht mtb/2006 C'dale road bike/2007 Colnago CLX
I use the Park cable cutter as well. I use a small screw driver to open it back up and widen the opening, use the cutter again to trim the edges so it's flat, then file it a little. To me, the trimming part is important for the brake cables to get the surface smooth. As for the derailleur cable, I use the crimping part of the cutter gently to make the cable circular again.
Quoted: 2338 Post(s)
Liked 2,827 Times
Does the park tool have a little gizmo on the side with a pin.....just for opening up the mashed housing? My cable cutter does....forget the brand...got it at Performance.
