Frame Pump Choices
Frame Pump Choices
I have a mini pump which I am very unhappy with. Would like to go back to a standard sized frame pump. The last one I bought was 18 years ago and an old zefal. Any new or better versions. Blackburn vs Zefal vs Topeka. Which seems to be strongest and best.
Really not so interested so much in the looks as the function, but thanks for the response.
Due to the casual usage of such an item, I'd say the more convinient physical size trumps the smaller air volume per push of a smaller pump.
U do have an honest-to-God shop pump at home for the b4r ride replenishment right.
Bikes: Surly Steamroller, IRO Groupbuy, Trek 520, plus a bunch of homebrews
Well, now back to the question.
My only experience is with Blackburn frame pumps. They work well enough for what they are meant to do. I definitely wouldn't want it as my only pump, but for fixing a flat in the middle of no where they get the job done.
Klaatu barada nikto
The best frame pump to come out in years is the Topeak Road Morph. It's praises have been sung by many, and often, on this forum. I liked my first one so much I now have two, so I don't have to move it from bike to bike. If you have never used one, get to a shop and try one out.
aka Phil Jungels
Topeak Morph series - mine works great, every other day!
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times
Frame pumps are for noobs. If you're only interested in function then the only pump you'll ever need is a topeak road morph with gauage.
Bikes: Homebuilt steel
Quoted: 2193 Post(s)
Liked 425 Times
CO2 and a mini pump for emergencies. Why carry around a heavy, clunky frame pump when you will only use it on rare occasion?
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,180 Times
Frame pumps look like something out of the 70's. They are big, heavy, and come off the frame at the worse possible times
The best pump I have used is the Topeak Road Morph easy to use and I like that it has a hose, I also have a Innovation Secound Wind Road Mini Pump It can be uses as a CO2 or hand pump or both, it works great as well.
It may not be fancy but it gets me were I need to go.
https://www.jtgraphics.net/cyclist_bicycles.htm
Ferrous wheel
Bikes: 2004 Gunnar Rock Hound MTB; 1988 Gitane Team Pro road bike; 1986-ish Raleigh USA Grand Prix; mid-'80s Univega Gran Tourismo with Xtracycle Free Radical
The Zefal HPX works very well. It's not heavy at all, and it comes off the frame only when you want it to. Plus it looks like something out of the '70s.
To hell with looks. For the higher pressure road tires I want as long a pump as I can fit in the darn frame. I've got a couple of Zefal HPX's that I treasure and recently had to go with a Planet Bike version of the same sort of spring expanding pump since the place doesn't handle the Zefals at the moment. But at least the PB pump seems like a good alternative. Had to pump up a tire due to a slow leak and it got it back up to around 100 psi in short order.
I use mini pumps on my off road bikes only because the longer frame pumps won't fit the oddball frames and I also want to lash them in place in the clip with the velcro strap.
The longer pumps provide more volume when the pressure is low and more volume at pressure when you're up near the end. A win-win compared to the shorties.
Randomhead
Liked 3,699 Times
I just broke my frame-fit Silca. I guess smacking all those dogs with it back in the '80s wasn't such a good idea after all.
MUP Pup
I have a road morph, & an HPX.
They both get the job done, I like the road morph for the reasonably accurate gauge (results may vary), & it's mounting system which is not prone to getting bumped off as the HPX did before I strapped it down. Basically it's a bit easier for me to remove if needed.
I've seen the Platnet Bike frame pumps & debate one for the back of my kogswell, but haven't found sufficient need to change yet.
Bikes: Surly Troll
I have a couple of zefal hpx which are not easy to find these days. Planet Bike roadie frame pump from AE Bike for $17 is a good one too. Nashbar formerly sold the same exact pump under their house brand for about $12. I don't get a lot of flats but have used all 3 of these pumps enough times to be confident they will work fine when needed. I use 700-35 tires that have pretty large volume and run at 70-75 psi. It takes me takes me about two strokes per psi to fully inflate my tires using either the Planet Bike roadie, nashbar house brand or zefal hpx. The planet bike roadie has a good handle with soft kraton rubber ends that won't wear the paint off the frame like one end of the zefal does.
Bikes: 1983 Dawes Galaxy, 2006 Raleigh Airlite, 1982 Sun Solo (fixed)
Zefal SP-?
I use the 4 becuase it fits my frame.
pumps tyres up like nothing i have ever used before
A group for all Dawes Galaxy owners to give and recieve information about them
https://flickr.com/groups/dawes_galaxy/
i jam my thumbs up and back into the tubes. this way i can point my fingers straight out in front to split the wind and attain an even more aero profile, and the usual fixed gear - zen - connectedness feeling through the drivetrain is multiplied ten fold because my thumbs become one with the tubing.
Bikes: Specialized Rock Hopper, Felt F-70, lemond Buenos Aires, Trek T900 Tandem, Bianchi Volpe
I use the Topeak MasterBlaster. Full-size and reliable.
Steve
Steve
Try the Barbieri Carb One (if you are able to find it)
Amazing light and small (80g - 20cm) ande very effective.
Without too much effort you get 6 bar and with a little of patience 7-8.
Erect member since 1953
Bikes: Trek 520 Grando, Roubaix Expert, Motobecane Ti Century Elite turned commuter, Some old French thing gone fixie
Quoted: 121 Post(s)
Liked 38 Times
Topeak morph or mini morph. Best.pump.around.
really. Do a search. But by a water bottle side holder from performance as their holder is ugly.
