Critique these two sets of components.
I am being offered two bikes
Both hwve their very good points.
Cqn you tell me which set of components is better?
I realise one list is more comprehensive.
Can you still tell generally speaking which set is better?
Sram NX drivetrain, Sram Level hydraulic disc brakes
T6HEADSETSEMI-INTEGRATED FSA NO10 SHIS: ZS44/28,6 ZS50/40FRONT RIMSALLOY 36H
80MMREAR RIMSALLOY 36H 80MMFRONT HUBALLOY QR 150MMREAR HUBALLOY 190MMSPOKESTAINLESS 13GFRONT TIREVEE TIRE SNOW AVALANCHE 26X4.8 TUBELESS READY
REAR TIREVEE TIRE SNOW AVALANCHE 26X4.8 TUBELESS READY
FRONT BRAKESHIMANO HYDRAULIC DISC M365REAR BRAKESHIMANO HYDRAULIC DISC M365
FRONT DISCSHIMANO 180MMREAR DISCSHIMANO 160MMCRANK SETSSAMOX 28TCASSETTESHIMANO 10S 12-36TCHAINSHIMANO 10S
REAR DERAILLEUR:SHIMANO DEORE M6000 10S SHADOW+REAR SHIFTERSHIMANO DEORE M6000 10S SHADOW+HANDLEBARALLOY 740MMSADDLEMOOSE BICYCLE
- Sun Ringle MuleFut 80 SL, Maxxis Colossus 26x4.8 tires
- Norco Alloy stem, handlebars and seatpost
- Norco Sasquatch Fat X6 Alloy frame (197x12mm rear axle), Norco Carbon fork (150x15mm axle)
SPECS
ALUMIMIUM 6061 T6FORKALUMIMIUM 6061T6HEADSETSEMI-INTEGRATED FSA NO10 SHIS: ZS44/28,6 ZS50/40FRONT RIMSALLOY 36H
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
This means nothing to me. I look for a decent fit first.
Fit is first and foremost, however I am not a fan of Sram hydraulic brakes. Been there, won't ever go back. Shimano hydraulics are good to great, and it is hard to lose with them. As for shifting, meh, either one works. The rest of the components are equal between the two. Get the one that fits correctly, then make changes down the road a ways if needed. That is what I did with the Sram brakes. Rode them for 2 years and upgraded to Shimano. The Sram drivetrain was very good, just those lousy brakes! Never could keep them from rubbing and squealing. Constant bleed issues, etc. Shimano, just put 'em on and they work great.
Thank you very much for an informed well balanced answer,
My question now is still regarding components.
The bike with the Sram brakes fits me very well.
Would you still buy a well fitted bike with P.I.T.A. brakes?
