Out of shape or bad gearing?
BMX commuter gone roadie
Bikes: Cheap ones
Quoted: 22 Post(s)
I took my new rig out for it's inaugural 21 miles after not much activity - cycling included - for many months. I know that I'm out of shape but a friend of mine, who is certainly in worse shape, was smoking me on our ride. I felt like I always needed to be in a gear between my two front cogs. Granted, I rode 9 miles to meet him so he was fresh but to keep up at about a 15 mph cruise, I really felt like I was having to exert myself and was searching for a gear that wasn't totally crossing my chains. New bike. Not terribly happy with the gearing though I may just really be in that bad shape.
Quoted: 1572 Post(s)
Liked 643 Times
"Inaugural ride." Your motor probably isn't broken in yet. It'll get better.
Bikes: No. 22 Bicycle Great Divide, Lynskey R260, Salsa Colossal Ti, Litespeed T5, Lynskey Peloton, Bianchi Vigorelli, CAAD 10, Giant FastRoad CoMax 1, C-Dale Quick 1
Quoted: 50 Post(s)
Liked 36 Times
"Gearing issue" sounds like perfect reason to acquire a new bike.
Quoted: 131 Post(s)
Quoted: 18372 Post(s)
Liked 4,507 Times
15 MPH isn't a bad pace. It can be a number of things slowing you down including bad tires.
A lot depends on your terrain and gearing.
I like a fairly tight rear cassette with quite a few single steps between sprockets.
Others like tightly spaced chainrings on the crankset, and more space between individual rear sprockets.
Nuvinci CVR internal gear hub is Continuously Variable with in its range.. so you just turn the gripshift handle till it feels ok..
Quoted: 6191 Post(s)
Liked 4,807 Times
Unless you have some unorthodox home brewed creation, big big and small small are the only combinations that should remotely give you any issues from cross-chaining. Even then the biggest issue is usually just the embarrassing noise. To a much less extent, there is the issue of wear.
However if those are the gears you find you have to ride in for most of your ride, then you probably need to think about changing front or back gearing. If you are only in those gears for a small part of the ride, no big deal.
But yeah, it does take time to get the buildup and crud out of the motor when it's not been run at high speeds in a while .
Quoted: 590 Post(s)
Liked 445 Times
Perhaps the friend was secretly keeping his cardio up when you were slacking, but also consumed tons of extra calories to keep up the fatty facade of a slacker?
Quoted: 4559 Post(s)
Liked 2,802 Times
Even after you're in shape you'll still find some rides when no gear combo feels quite right. Mostly a matter of conditions -- terrain, wind -- and conditioning.
A couple of times over the decades I've swapped freewheels or cassettes, or cogs in a freewheel or cassette, to suit the conditions I most often encountered so I could stay in my preferred cadence and effort. That was mostly for commutes when I didn't want every ride to be a workout and just preferred the smooth sensation of being in the perfect gear for a given scenario.
Yep. I start out in the 14-15 mph range every spring. With hard work I always expect to be averaging 19-21 mph by the middle of June. Don't give up; chasing your buddy is actually a good workout!
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Cadence too low, mashing?
Learn to spin.
Learn to spin.
Sophomore Member
Quoted: 1628 Post(s)
Liked 1,057 Times
Agreed. There's always gonna be someone faster than you. Would you rather have had to sit up over and over again to let him catch up? You don't get any better riding with someone like that.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
So you don’t exercise for many months, then ride 9 miles before riding with someone totally fresh and you have trouble keeping up.
I hate to break it to you, but your gearing is not the issue. I think you already know what the problem really is.
You need a lighter wheelset.
Bikes: Cheap ones
Quoted: 22 Post(s)
My thinking the whole time was "where is that easy gear!?" though it's pretty clearly a conditioning issue. Trying the commute a few days next week, which should go a ways towards freshening up the legs. But yeah, it felt like I was mashing the whole time and anything lower was spinning too much. I miss the 55 gear-inches of my old bmx. That's where I'm most comfortable, though I'm not sustaining 15 mph on flats with that gear.
Thank you for your input. I often ask questions I already know the answer to. Time to ride some more and clean the crud out of the motor.
Sophomore Member
Liked 1,057 Times
Do some fixed gear rides if you can, to work on your spin. Also, get your position nailed down before putting in any serious miles.
For example, I had gotten lazy and was using my rounded lower back to pedal with instead of my glutes, which caused me some back problems. I have to constantly remind myself to keep my back flat and pedal with my butt muscles and not my lower back. And also stretch to remain flexible. YMMV.
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
I know this is a religious issue for some people, but I firmly believe that some of us are natural mashers. I ride frequent solo centuries in high gears, and I find high cadence/low gear spinning incredibly inefficient for me. Don't be afraid to play around with different gear combos/cadences, I think there's way too much one-size-fits-all thinking on this issue.
I will now prepare to duck and weave.
Quoted: 2482 Post(s)
Liked 2,952 Times
If you're not racing, though, mashing gears works fine.
Quoted: 169 Post(s)
Liked 84 Times
A couple of years ago, I specifically targeted high cadence riding. It paid off in a big way. On group rides I would sit and spin past people standing on the pedals and often beat them to the top of climbs. It was odd but effective for me. It does feel good to stand sometimes.
For the OP... Motor. Only one way to fix that.
Quoted: 18409 Post(s)
Liked 15,524 Times
Liked 15,524 Times
Some guy named Greg something or other (his last name escapes me at the moment, road monster gears on his way to winning some long race somewhere in Europe (Finland maybe?). IIRC, he won it three times.
Tragically Ignorant
Liked 9,098 Times
I'm much slower spinning. It also doesn't come naturally to me, so I have to focus on doing it, and I find that incredibly tedious and boring.
Mind you, I'll spin like a madman on hills. The high gear is my normal cruising method
