Di2 Battery Drain Over Winter / Non Use?
Old 03-27-19, 10:06 AM
NoWhammies
NoWhammies's Avatar
Quoted: 800 Post(s)
Liked 512 Times in 306 Posts
Last summer I managed to get approx 2,600km out of my Di2 batter before charging it.
After charging the Di2 battery and riding it for the remainder of the summer, I hung the bike up for the winter. The bike hung in my unheated garage, but the temperature never dropped below freezing.
After approx 1,900km the battery indicator is now a solid red. So a charge is needed.
My question is, did the winter/lack of riding suck the life out of my battery?
Thank you.
NoWhammies is offline
Old 03-27-19, 05:14 PM
bbattle
bbattle's Avatar
Bikes: 2014 Trek Domane 5.2, 1985 Pinarello Treviso, 1990 Gardin Shred, 2006 Bianchi San Jose
Quoted: 62 Post(s)
Liked 28 Times in 13 Posts
Yes. The same happens to my Vespa scooter.
Cold is the enemy of batteries.
bbattle is offline
Old 03-27-19, 06:50 PM
Jakedatc
Jakedatc's Avatar
Liked 10 Times in 7 Posts
Just sitting is going to lose some charge. I'd say getting as much as you did is pretty good. Charge it up and good to go
Jakedatc is offline
Old 03-28-19, 03:23 AM
srode1
Gravel Rocks
Bikes: Trek Domane and Crockett, BH G7, Niner RLT9, RLT9 RDO
Quoted: 124 Post(s)
Liked 38 Times in 29 Posts
Batteries exposed to cold for extended periods of time lose capacity. The colder and longer the exposure without charging the bigger the loss. Either charge it periodically or bring it inside if you wan't to preserve the life of the battery.
srode1 is offline
Old 03-28-19, 10:01 AM
NoWhammies
NoWhammies's Avatar
Quoted: 800 Post(s)
Thanks folks! I'm going to eek out a couple more rides with the Di2 battery showing solid red and then put it on the charger. I heard someone call it "Di2 batter roulette" which I suppose is apt. I don't plan on doing any long rides though until I do charge it up.
Cheers.
Old 03-28-19, 10:21 AM
2manybikes
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times in 169 Posts
A little loss over the whole winter is typical. Also when the battery is cold it will be weak, but when it warms up it will go back to normal. This is also typical of any battery. You may have more of a charge than you think if you bring it inside and let it get to room temp. Don't charge it while it is cold. Riding in the cold will shorten the useable ride time, while it is cold.
Over the winter bring it inside and charge it a few times.
2manybikes is offline
Old 03-28-19, 12:08 PM
surak
surak's Avatar
Quoted: 871 Post(s)
Liked 726 Times in 436 Posts
Is your battery Li-ion? If so, you shouldn't try to drain it down before charging it. Worst possible way to condition Li-ion batteries are to charge when cold or fully drained.
surak is offline
Old 03-29-19, 09:43 AM
NoWhammies
NoWhammies's Avatar
Quoted: 800 Post(s)
I'm not sure what the battery is @surak. It's whatever the battery is that came with my Di2 system last year. Most likely Li-ion is my guess.
Old 03-29-19, 08:56 PM
JohnJ80
Bikes: N+1=5
Quoted: 875 Post(s)
Liked 244 Times in 181 Posts
Cheers.
Why don't you just charge it more frequently? You won't hurt the Li-ion battery which don't really like to be fully discharged anyhow. Most Li-ion batteries can be charge 500+ times or so before they start to lose capacity. I'd guess in a cycling application, they batteries are more likely to die from old age and not from charge cycles.
JohnJ80 is offline
Old 03-29-19, 11:02 PM
Seattle Forrest
Seattle Forrest's Avatar
Quoted: 18883 Post(s)
Liked 10,646 Times in 6,054 Posts
Cheers.
I lost that game once and couldn't shift chainrings, 20+ miles from home. The RD still works for who knows how long, so I kept thinking "do I really need to shift, or should I save it for later?"
Seattle Forrest is offline
Old 03-31-19, 08:44 PM
NoWhammies
NoWhammies's Avatar
Quoted: 800 Post(s)
Battery has been charged! I'm tracking the charge/km usage in Garmin so I'll see how many KM's I get form this charge.
Old 03-31-19, 09:20 PM
2manybikes
Bikes: 2 many
The cold weather will give you less than warm weather.
NoWhammies
Road Cycling
10
10-01-18 09:18 AM
bikerlee
Road Cycling
12
06-23-18 02:28 AM
lennyparis
Road Cycling
36
08-18-16 08:40 PM
halocon
Road Cycling
3
07-05-16 11:06 PM
azza_333
Bicycle Mechanics
1
08-09-15 06:09 PM
