Why the curved (as opposed to sloping) top tubes?
Bikes: Skunkhumper Team, 05 Poprad
I've loticed a LOT of carbon frames with curved TTs.
Frankly I figured it was a styling affectation and had spread across brands because everyone uses the same factory to make them.
Is there a mechanical reason to have a curved TT? Because it sure is uglier than a plumber's pimply buttcrack.
Inquiring minds and all....
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Quoted: 551 Post(s)
Liked 277 Times
According to a few Specialized interviews from cycling news, it is a design to promote rider comfort and better fit for a wider range of riders. In reality, only Specialized knows and no one over there is really going to give you the reasoning behind the design other than what they want to tell you.
pan y agua
Quoted: 1447 Post(s)
Liked 727 Times
I think it's mostly aesthetics, and branding.
However, that said, why should a top tube be striaght? With metal tubes, that's a logical default. However with a molded CF frame, you can shape the frame pretty much the way you want.
A curved top tube arguably could provide some "vertical compliance, while being laterally stiff." but agian I think its mostly marketing.
You could get lost and die.
You could hit a tree and die.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,179 Times
Because everyone uses the same factory to make them isn't a reason. Factories make to customer requirements.
I assume its purely aesthetics. It looks better than straight, especially if everyone has straight. Just like cars look different from each other
Quoted: 20810 Post(s)
Liked 9,456 Times
Old fart
Liked 3,400 Times
Liked 9,456 Times
Treble Member
Bikes: '07 Cervelo P2C, '12 Specialized Roubaix SL3 Expert, 2011 Specialized TriCross Comp.
Liked 9,456 Times
ka maté ka maté ka ora
Bikes: breezer venturi - red novo bosberg - red, pedal force cg1 - red, neuvation f-100 - da, devinci phantom - xt, miele piste - miche/campy, bianchi reparto corse sbx, concorde squadra tsx - da, miele team issue sl - ultegra
Quoted: 25 Post(s)
I like women with curves. Can't i like a bike with curves too?
pan y agua
Liked 727 Times
No accounting for taste.
Ghost Ryding 24/7
Bikes: Giant Defy with Dura Ace group, & Ksyrium SL's,Specialized Allez Shimano mixed/mashed,2011 Opus Sentiero,2008 Kona Jake the Snake,Custom built track/fixed,Stumpy Hartail,Kuwahara/ET bike.
I like the Wilier, but can't stand the "bejeweled" look in the Pina.
Curves on women doesn't necessarily effect how a woman performs(1 way or the other) either...
Administrator
Liked 2,179 Times
Descends like a rock
I'll vote Christina Hendricks, but I like my top tubes straight. What does this mean?
Quoted: 1020 Post(s)
Liked 463 Times
Curved top tubes may not have a mechanical advantage but there is that "sprung-bow-ready-to-release" look tha tmakes the bike "look" fast.
Straight top tubes don't have that same "spring" look or feel.
Straight top tube in my Colnago C59 sloping frame...not much of a slope.
Curved or bowed top tube in my Bianchi Infinito.
I like the straight top tube in the Colnago, but the curved top tube in the Bianchi also has certain appeal.
Bikes: Moots Vamoots, Colnago C60, Santa Cruz Stigmata CC, and too many other bikes I don't ride
Quoted: 152 Post(s)
Liked 7 Times
How is that marketing?
Are all the facts debatable now? If you are short, the lower end of the top tube allows you to be able to stand over without hitting the top tube. How is that marketing?
The compact geometry has its real benefits... unlike the fugly curved top tube, especially done by Speicialized
Bikes: 1989 Schwinn Traveler Sol d, 2012 Ted Wojcik, 2012 S pecialized Roubaix, 2016 Motobecane Titanium
Giant was the first. Its all about riding position and comfort.
