Drilling holes for internal brake cable mod
I bought an used 2014 Ridley aluminum frame road bike to use as my indoor trainer bike, it has external rear brake cable and internal shift cables, none of these mean much to me until I have to mount the bike at the repair stand, since the bike frame is a bit bigger than I normally ride, I end up having to clamp the bike at the top tube because there is not enough seat post left.
The rear brake cable keeps getting pulled enough that it will cause the brake to drag or even lock up, I want to drill 2 holes in the top tube so I can run a new cable housing from brake lever to brake caliper, can't find much info online so I thought this may be a good source
I already contact Ridley bikes twice and my first respond was " we don't recommend drilling into carbon fiber frame " I submitted the same question again and this time I didn't get any reply
Any input will be greatly appreciated, it looks like a simply job but I worry it may compromise the structure integrity of the frame by drilling holes into the top tube
Bikes: MBK Super Mirage 1991, CAAD10, Yuba Mundo Lux, and a Cannondale Criterium Single Speed
Quoted: 344 Post(s)
Liked 297 Times
If the cabling is only a problem when you put the bike up on the work stand, either a) adjust your seat height when using the work stand or b) get a different work stand, which will be a lot cheaper than a new frame.
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
Indoor trainer bike?
Brakes?
Work stand?
I think a trip to the LBS is in order before installing drillium.
Brakes?
Work stand?
Quoted: 761 Post(s)
To things
Firstly, you can't ride the bike off the trainer if you do this. Your comprising the structural integrity of the frame. Secondly, you kill the resale value (Customer: 'What's that dot I see there' ... Reminds me of that famous Seinfeld episode about the sweater and the red dot).
Bad example
Quoted: 828 Post(s)
Liked 214 Times
Scorpiox, there was a recent thread about Miyatas that had internal cabling, and cracked at the holes because the holes had no reinforcements.
The simplest answer IMO would be to get a quick-release seatpost clamp so you can extend the seatpost when you put it in the workstand. You can also get a small band to clamp around the seatpost at the edge of the seat tube, so you can re-insert the seat post at the same depth.
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
Burning Matches.
Quoted: 4077 Post(s)
Liked 1,002 Times
My vote is for marking the seat post, then moving it up as req'd in the workstand. How often do you intend to put your trainer bike in the workstand anyway?
ElJamoquio didn't hate the world, per se; he was just constantly disappointed by humanity.
Master Sarcaster
Bikes: 2018 Allez Sprint, 2016 Trek Crockett Canti
Quoted: 190 Post(s)
I would recommend AGAINST drilling an Aluminum frame even more than I would against drilling into carbon. Any hole in the wall of AL tubing is just asking to develop cracks and structural failure if not done properly. That's why you don't see many AL frames with internal cable routing, and when you do, it's on higher end frames and often with additional support welded/bonded in place.
If that frame will only ever see life on the trainer and will NEVER see road use again... fine, do it at your own risk and it probably will survive, but I would do it under the assumption that if you drill it the way that I think you're wanting to, it's a dead frame and should never be ridden on the road again.
Bikes: 1979 Raleigh Team 753
Quoted: 3375 Post(s)
Liked 371 Times
You know the disclaimers.
I prefer to drill carbon fibre way more than anything else.
Reason is many/most times it is made with some bladder and the wall thickness varies anyway and it there is lots of extra material built into it. Then, even broken the stuff is tough. An alloy post/part will snap. Steel with bend and CF will crack. Of course enough force and it will snap too, but materials are different and the tolerances are different.
An Extralite (brand) part will hardly ever be modified. It is already perfect. A CF bar I have no issues drilling, but I understand where the stress points are.
Anyway - your bike is on a trainer. Drill. If you do not know where it is safe to drill, don't. But I think you are fine. Alloy will have tighter tolerances and you do want to be careful.
For example - for a cable - I'd drill in the side toward the middle of the head tube. Not a lot is going on there. If the welds are huge, maybe a weld. If they are finely filed -not a weld. If in the TT...careful. A butted tube in the butt/thicker section farther from the weld would be preferred over the thin area. Since alloy is typically not butted, an inc from the weld is good.
You might feel this with the fork / seat post out.
Non omnino gravis
Quoted: 4416 Post(s)
Liked 1,569 Times
I don't know what work you'd need to do on a trainer bike that can't be done while it is clamped in the trainer.
Liked 371 Times
Sight unseen - I may be off. But drill through the head tube (as per last post). Go around the steer tube, and take it out right before the seat joint.
I assume you can't take it down the down tube under the BB and to the chain stays. Thought I'd mention.
Do you plan on the housing going in side the frame? Think about smaller holes and stops. There are also stops used for this (for bigger holes) so look for them.
Liked 1,569 Times
You have to route the housing through the frame, otherwise the brake wire would cut the frame or steerer over time.
Quoted: 4806 Post(s)
Liked 3,932 Times
Ben
Liked 371 Times
A small hole and stop for cable only, or sleeve, not housing in the TT is my suggestion. In several of my frames I could do that. I do similar with Di2 cable, but that is not under tension.
Still, if I read correctly this is a stationary indoor training bike.
Why are brakes needed?
Liked 1,569 Times
How did you do that without having the bare cable touching the inside of the frame in spots? What kind of stop do you use for an angular exit from the side of the TT?
Liked 371 Times
The exit, I explained has after market stops. I think you have seen them. I can look if needed.
Quoted: 1067 Post(s)
Liked 259 Times
I would drill the top tube in a similar place to where they usually are. Probably close to where the existing rear brake cable stops are. Then with a pin punch or even just the parallel shank of the drill lever the holes a bit so the housing can enter at the appropriate angle more easily. Then run a continuous brake housing from lever to frame. An advantage of this is that your sweat won't get into the brake cable and corrode it.
If you were worried about structural integrity you could fix the housing to the outside of the top tube by other means and not drill it.
