Legnano City Bike dilemma
I dug out this thrift store score I've had sitting in the cellar for a few of years. They didn't really know what it was other than they were able to read the headbadge, so my investment to date is less than a bottle of decent bourbon. I was hoping that the blue paint, some of which literally fell off when I disassembled it, would come off pretty easy and I might have a useful lizard yellow patina underneath. The chrome is in great shape, the chainguard is almost perfectly straight, cranks and handlebars will clean up and it has the original brake levers. Yeah, someone also painted the rims white so I will just salvage the hubs. We have the companion donna/ladies Legnano city bike in very good shape, so it has a partner in waiting.
These are the before pictures, and in the next post I'll show the paint stripping outcome.
Likes For ldmataya:
Quoted: 3015 Post(s)
Liked 3,808 Times
What people are thinking, I haven't a clue.
Good luck with the cleaning. Maybe heat on the stubborn bits?
The after blue paint stripping results. I see why they sprayed it with something, many places where all the original paint was gone and/or surface rusted. I'm a big fan of patina but I didn't get very much original paint back. So now I'm trying to decide if I do a partial refinish, just lay some clear coat over everything and fake some distressed transfers? Has anyone else tried a partial refinish as in just put some paint back in the bare spots and go with that. I'm not a fan of the cost of a new lizard yellow paint job given this is going to be a rider. When I fix up a single speed city bike, I can always find someone to ride it.
Liked 3,808 Times
Skip the clear, car wax will do just fine, unless you ride it in the wet.
Likes For iab:
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,100 Times
Yeah, tough call, but I think for a cruise around town purpose looks alright. Cool bike!
For the peanut gallery - a couple of lines on the stripping technique?
Quoted: 3814 Post(s)
Liked 3,345 Times
bottom bracket shell appears Agrati pattern "SPORT" Nr. 005.8057
fork crown is NERVEX pattern Nr. 5
have not before seen a NERVEX crown on a Bozzi product
certainly does not mean none were ever employed
wonder if fork original
contour of blades more resembles a french product than an italian one
you could check steerer to see if it is metric
do fork ends appear a good match for dropouts?
chainset is mixed
drive side arm appears it may be a Way-Assauto
non-drive side arm appears more of a generic replacement
chainguard appears a Mazzucchelli product
original handgrips would have been REG (Rampinelli); here is a set on a Legnano -
chainset is mixed
Likes For juvela:
On the chrome I just used a heat gun to soften the paint- then it comes right off with steel wool. But I didn't think that would work on the painted surfaces and my spot check confirmed it - heat was quickly melting both layers. So I used a non-toxic chemical stripper, tried to just apply to the blue. It took 2-3 attempts and I couldn't wait very long before it would start melting the original paint - about 30-45 minutes before I started removing. After scraping with a body filler spatula, I used fine steel wool and lots of water to get the remaining blue off.
The Huffmeister
Bikes: '79 Trek 938, '86 Jim Merz Allez SE, '90 Miyata 1000, '68 PX-10, '80 PXN-10, '73 Super Course, '87 Guerciotti, '83 Trek 600, '80 Huffy Le Grande
Quoted: 1227 Post(s)
Liked 3,561 Times
Thanks for the other info - finding the bar grips might be a challenge.
Thanks, yes I have not attempted to uncover that yet. Note these function as both the emblem plate and a plug to cover the stem expander bolt hole. It was already separated into two pieces but if I can restore the emblem it will function fine with a plug made from plumbing leftovers.
Liked 3,345 Times
another item to treat with gloves of kid is the machine's seat binder
readers report them to be a challenge to locate...
Quoted: 566 Post(s)
Liked 1,053 Times
Likes For RustyJames:
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
