How do you know the exact, correct spoke length?
Quoted: 120 Post(s)
Say it's a brand new set up -- rim, hub... but then you need to know the length of spokes. And you need to know spoke length pretty much down to the millimeter from what I see. I've got a double walled rim on one wheel, so that would allow for some cheating, ie the spoke could stick out a bit but it's inside the rim so it's not going to poke the rim tape or tube.
It must just be measuring, right? You know the hub. You know the rim. And then you should end up with shorter drive side spokes and longer non-drive side spokes. How do you get that spoke length though, esp. if the rim is free and the hub is free?
I imagine there's a correct way. I'm picturing doing that correct measurement but then only ordering the "first round" of spokes for each side (every fourth one or something?). Order fewer of what I think is the correct length to make sure it actually is the correct length. Then once the first round of spokes are on, see that it is the correct length, and then order the rest. But that's just me.
I imagine there's a way to know that, "Yes, this is the exact, correct length for sure."
Quoted: 659 Post(s)
Liked 7 Times
There are lots of spoke length calculator sites online if you don't want to go through the geometric calculations from scratch. Here's one example:
Spoke Calculator for bicycle wheels | Prowheelbuilder.com
Quoted: 120 Post(s)
Very cool. I took a guess on remembering exactly what rim and hub I've got and I got the same spoke dimensions that I have now. That's a good sign.
What do you do if the parts aren't listed on a site though? Are there calculators for that? Just put in hub measurements, rim measurements... Same idea, the site does the rest?
Quoted: 659 Post(s)
Liked 7 Times
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times
Run measurements through a couple different calculators, just to be careful. Precut spokes usually come in 2 mm lengths, like there might be 290 mm and 292 mm but not 291 mm. If in doubt, get the shorter length.
Old fart
Quoted: 3615 Post(s)
Liked 3,444 Times
It takes a little trigonometry:
Source: Sutherland's 4th Edition
BITD, most mechanics looked up spoke lengths in published tables of hub and rim models. If you couldn't find it in the tables, you'd break out the calipers and slide rule. These days the formula can be embedded in a spreadsheet or javascript function.
Senior member
Quoted: 946 Post(s)
Liked 663 Times
Really Old Senior Member
I eally don't like to generalize too much on hubs, but if for example, both hubs are rear Shimano, the slight variations in CTF distances don't change spoke length to a noticeable degree. Maybe .1 to .2mm?
As long as the spoke hole "circle" is the same diameter. (PCD)
Some of us have pairs of "test spokes" of a known length. (nipple "glued on" so it doesn't move.
We put them in opposite holes and measure the distance between the elbows with a caliper where they "would" enter the hub.
Check in multiple places around the rim and average the length. (in case the rim is a bit oval)
We put t
We put t
Quoted: 550 Post(s)
Liked 325 Times
Then you drop that into a calculator - I like spocalc.xls.
Adjust for stretch. Very roughly in the front and rear drive side 2.0/1.5mm spokes stretch about 1mm at full tension and 2.0/1.8mm 0.5mm. NDS spokes stretch half that far.
Then you use logic to accommodate available spokes and rim diameter variation. Spokes come in 2mm increments; so in some cases your choices are either the nipple top or 1mm below the slot and prefer the top. If your rim is bigger than average you might get a spoke cut 1mm shorter instead so that when it bends/wears out you won't need new spokes (or to drill your nipples) if the replacement is smaller.
Quoted: 550 Post(s)
Liked 325 Times
It depends on where you're aiming. Use a 290mm spoke not a 291mm ending at the slot bottom risks broken alloy nipples especially if you neglected to measure and have a rim + nipple combination with larger than advertised ERD. 292 is better in that case assuming you correctly accounted for stretch because it'll end at the nipple top where you have -2.0/+1.5mm of tolerance not -0/+2.5mm with the 290 which will end 1mm below the slot if everything works as planned.
Damon Rinard's free spoke length calculator
Don't overthink this. It ain't rocket science. I use this spoke calculator and have had good luck.
