Rear wheel spoke actually pulled thru hub
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Lol, thats funny. Today I became unlazy. I did pull my bike outside , removed the wheel and did the inspection. And what I found I don't like . I have been asked to post photos and I really wanted to because I have a question about how I may or may not repair this. On further inspection it appears it is happening to other holes as well , wow , thats really blowing me away. Its weird the forum says I cant post a photo. I am new here.
Likes For Homebrew01:
Quoted: 4201 Post(s)
Liked 3,857 Times
I will try a spoke tomorrow and see how it sits but as I noticed earlier ( unless I'm just not seeing the true nature of the issue ) it appears other holes are being elongated . As like the metal has softened all of a sudden. And as I commented earlier, though Idk why , maybe these 25mm tires put some kind of new "pressure" on the wheel ?
Yes I might still have the broken one, good idea if I do to inspect it.
Now if you were to build up new spokes and rim on this hub (in it's self not a bad idea) care to maintain the spoke/flange orientation is needed. This way the original indents will again line up to the new spokes. Flanges break more readily when the second set of spokes don't line up as the originals did.
For the flange's material to have changed it's softness would require enough heat to change the metal's basic grain structure. I think you'd know if your rear hub got up to 1000* F Andy
AndrewRStewart
AndrewRStewart
Stress relieving for al is around 400 F and it melts at 1400F. I would guess, without a pic, that the spoke head broke off.
I included 3 pics ,maybe someone can give me an idea on what happened , and maybe a place to buy online a new hub quickly .Can't find the broken one ,I looked for the broken spoke because I cut it off in the dark , I could of sworn it was in my cycling shirt rear pocket. Here are some more pics of the hole. One or two things happened ( neither ever in my life ) . The mushroom end wore down and pulled thru or the hole wore bigger and it pulled thru.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Quoted: 430 Post(s)
Liked 460 Times
Thanks for the pics. Still looks like the spoke head failed. Hub hole looks typical for a previously laced hub.
Ohhh k , soooo how/why would the mushroom end ( lack technical wording ) fail , never seen that happen ? Then if it did, its only time till the rest do the same .
Quoted: 1188 Post(s)
Liked 1,154 Times
I wish that was true that they were cheap and nasty but it is not the case. Strong solid spoke and nipples , laced it myself about 5 years ago . Never one spoke broken.
Quoted: 430 Post(s)
Liked 460 Times
Joking aside, I assume it's probably suboptimal tensioning during the build compounded by years of hard use leading to fatigue at the spoke head, resulting in failure. Very possible that more spoke failures will follow. Time for a new wheel or rebuild.
Likes For tFUnK:
So if someone educated ( in that kind of thing ) could take a look at the hub holes and give me your thoughts if its time to get a new hub ,probably is . I like my wheel and guessing I will probably need to find a identical hub and new spoke and nipples. I've been searching online for a 24 hole 10 speed rear hub cant seem to locate one , well one I can afford .
@tFUnK Ok I hear ya . Have you ever seen a spoke ( mushroom end ) pull thru a hub ? I never have ( unless the hub is ruined somehow ) and Im 50yo. Worked at bike shops when I was younger , never happened on any of my bikes , its baffling. As I mentioned in an early post I recently switched from a 23 mm tire to never before 25 mm tire . It definitely seemed heaver and bulkier even though its the same brand , maybe that was enough to put new type of pressure on the spokes , idk .
Quoted: 430 Post(s)
Liked 460 Times
Here is a prime example of a spoke head failing. This looks more probable than a widened hub hole. If you have an extra spoke it would be easy to check your hub to determine whether it's worth rebuilding.
What brand of spoke are those? I can't quite make out the ID mark on the heads. I think you can replace the spoke and check the tension of the others. When the wheel dies replace it with one with more spokes properly tensioned. 32 is good, 36 is better.
Likes For davidad:
So I have put another spoke in thru the hole and of course at the moment not under pressure it seems ok, but the hole looks all chewed up. I do not have any nipples to pull it tight.
Why is 32 or 36 hole better ? I just found the box with some spokes in from quite a while ago . It shows a brand on the outside the seller sent me , but then it says the color is black on the other end and these are silver , so idk how to identify what brand im using are .
If you want a reliable long lived wheel you need at least 32 spokes unless you are a 140 pounder.
So hear is a good question , how long should spokes last ? If I buy replacement spokes /and a few extra on hand, Im thinking I will just loosen all them and have a shop tru up the wheel and see how that goes. At the moment the wheel is completely wonky(not straight at all ), but its missing a spoke that was probably over tension .
Just need someone to answer my question up top there , and or also give me a link for a good deal on a rear hub or wheel/hub combo that is black rim/black hub. Thanks!
