Anyone have any experience with Shimano's new quick-link?
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Shimano XTR/Dura Ace and XT/Ultegra chains can now be purchased with an optional quick-link.
Anyone have any experience with these? I worry about the chain coming apart while I am riding, or not shifting as smoothly. Is this warranted?
My new Ultegra 11 chain came with a quick link. I have no concerns about it coming loose, as it took some extraordinary effort to snap it in place.
I eventually resorted to the trick where you put the part of the chain with the link at the top of the drivetrain, and then with the brakes pulled hard, stomp on left pedal to apply tension to that part of the chain. During this: the reassuring 'click' of engagement.
I've put a hundred miles or so on this chain: super smooth shifting and quiet running. Shimano makes great chains.
Occam's Rotor
Liked 2,331 Times
I have the Park chain link tool. Will that not work?
Bikes: Trek Emonda SL6, Santa Cruz Tallboy 27.5+
Quoted: 37 Post(s)
Liked 9 Times
Put about 2500 miles on CN-HG901 with included Shimano quick link. Then changed out 6800gs for R8000gs rear derailleur and had to remove links. All my LBS stocks is KMC so one of those is on now. Coupling pins work fine, both links seem ok too. So I do not have an operational preference. It is possible to install the links wrong, they are directional.
Bikes: 2017 Colnago C-RS, 2012 Colnago Ace, 2010 Giant Cypress hybrid
Quoted: 408 Post(s)
Liked 122 Times
Yes! That will work. Probably easier and better than stomping on the pedal. I would also use a piece of stiff wire that will fit into the inner links. Put a hook on one end and cut it to a length that will allow slack in the chain when you pull the derailleur forward. Put a hook in the other end and attach it to the chain. This will give you slack in the chain and will make removal and installation of the link a lot easier since you won't be fighting with a tensioned chain.
HCFR Cycling Team
Ride Safe ... Ride Hard ... Ride Daily
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
Bikes: Soma Saga, 1980 Schwinn Voyageur 11.8, New Albion Privateer
Quoted: 76 Post(s)
Liked 9 Times
I have been using SRAM and KMC chains with quick links for years and have never had any issue whatsoever. Currently, I am even riding a chain that I put a in a second quick link to extend its length a bit. Frankly, I am surprised it has taken Shimano so long to provide this as an option.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
No worries. I've used them on several bikes without issue including a gravel bike which sees rough service.. They are equal or better in quality than KMC links.
As an aside, they are not optionally purchased but come with every 105, Ultegra and Dura Ace 11-speed chain. If you get a chain with a pin instead of a quick link it is old stock. Everything should have quick links now.
-Tim-
-Tim-
Quoted: 86 Post(s)
Well, isn't the chain slightly weaker at the quick-link/master link/whatever? So maybe that's why. Maybe they thought adding it would boost sales, and decided that the slight change in the chain strength wasn't a significant factor. I'm just throwing out uneducated guesses.
Occam's Rotor
Liked 2,331 Times
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12768 Post(s)
Liked 7,683 Times
The ones pictured are designed for both install and uninstall. Some are only shaped for uninstall.
I imagine it won't be too long until the pin ones will be difficult to come by.
As for my personal experience, I've installed a couple dozen and shifting is great. And I haven't heard of any failures.
Quoted: 70 Post(s)
You will need to scrape down the wax to get them on if you dip wax the chain.
The chains are still compatible with the older pins that are sold in 3 packs. I did this ("belts AND suspenders") and I only use the pins when I screw up chain lengths.
For piece of mind you can throw a spare quick link into your saddle bag. If the originals fail you will not need removal tools and road side installation is easily done with the "brakes and stomp" method. Simpler and lighter than carrying a chain breaker and etc.
- Soli Deo Gloria -
Liked 736 Times
If by "Stomp" you guys mean slam the pedal, there is no need. Hold the brake and put force on the pedal but there is no need to slam the pedal with your foot. It only needs as much force as you can apply with the pliers, which isn't very much compared to foot pressure.
The pliers are better if you have the luxury. Sometimes the pin one side doesn't fully engage and the pliers offer more control. Either way, foot or pliers, make sure to visually inspect before riding off.
-Tim-
-Tim-
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
I love it. On the rare occasions I have had a chain fail, it has always, without exception, been been at the pin which linked the chain together. When the link is installed properly, it works well, but even good mechanics sometimes don't get it right. I've been using quick links for some time now, and have yet to have one fail.
Quoted: 408 Post(s)
Liked 122 Times
-Tim-
-Tim-
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
Bikes: 89 Paramount OS 84 Fuji Touring Series III New! 2013 Focus Izalco Ergoride
Quoted: 285 Post(s)
Liked 74 Times
I have always opened/joined my chains on the return side, going back to many years using conventional chain/chaintool. So using the pliers is a no-brainer for me now with quicklinks.
scott s.
scott s.
I do not miss using a chainbreaker tool on non-quick-link chains.
I'm guessing SRAM's quick link patent expired so now Shimano is finally selling them.
Sunshine
Quoted: 10963 Post(s)
Liked 7,490 Times
Kmc links for all my chains regardless of chain brand.
that cheap pin that shimano pushed for so long pushed me to kmc links and I haven't had a reason to go back.
Quoted: 8 Post(s)
I was disappointed to discover that the 11spd. KMC quick links are A) Not reusable and B) Require a chain tool to install.
Its my understanding that the Shimano quick links are not reusable as well. Please correct me if I’m wrong.
Quoted: 408 Post(s)
Liked 122 Times
I think Shimano QLinks are like all the others. They all tell you that they are not reusable, but you can reuse them several times on the same chain. I think the "non-reusable" statement is meant to keep you from using the same link from a stretched chain on a new chain that doesn't come with a Quick Link. Since the Quick Link stretches at the same rate as the other chain links, using it on a new chain can cause problems. KMC does make reusable links that aren't that expensive but, from what I recall, are sold separately. I reuse the Quick Links on my FSA chains several time in order to soak the chain or perform other maintenance where it's easier to do with the chain off the bike.
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
Liked 406 Times
Shhh, don't type so loudly...I think I can here Kontact racing here to lecture us all about how you're GOING TO DIE if you re-use a quick link
